45% Silver Solder for Jewelry?
Home Forums General Questions 45% Silver Solder for Jewelry?
Viewing 14 posts - 1 through 14 (of 14 total)
  • #544902
    Blue Heeler
      @blueheeler
      Can anyone tell me if 45% silver solder is 'safe' for a copper bracelet jewelry repair that will be worn against skin?
      Of course common lead solder would be bad, but what makes up the other 55% of a 45% silver brazing stick?
      #28166
      Blue Heeler
        @blueheeler
        #544906
          about 30% copper and 24% zinc with a few traces of others.
          #544908
          Blue Heeler
            @blueheeler
            Posted by JasonB on 14/05/2021 08:25:03:
            Thanks Jason, do you think its ok to use in skin contact?
            #544909
            Paul Lousick
              @paullousick59116
              65% silver solder is often used for jewelery and available in a paste/flux for fine work. Lots of information available on the internet. Do a search.
              Paul.
              #544911
              Hopper
                @hopper
                Zinc should be ok. Same stuff as used on galvanised water piping. Ditto copper.
                #544912
                David George 1
                  @davidgeorge1
                  Hi the correct silver content for jewelry is higher around 67% but I don't think if you are using it on copper it would make any problem. If in doubt ask Cup Alloys for more details on metal content. I have jewelry solder and if you only want a small amount I could send you some.
                  David
                  #544926
                    As Said I don't think you really need "Easy" (67%) jewelry solder on a copper bangle and could even use less silver content for a darker joint line but the down side of both is the need for higher temps to get it to melt.
                    Edited By JasonB on 14/05/2021 09:27:38
                    #545114
                    bernard towers
                      @bernardtowers37738
                      Of course what you must remember is that although the solder ingredients before use are not necessarily what is left after the joint is made some is burnt off. Best ask Keith Hale about that.
                      #545115
                      bernard towers
                        @bernardtowers37738
                        #545140
                        Keith Hale
                          @keithhale68713
                          There are three different alloys containing 45% silver.
                          There is a quaternary alloy with copper, zinc and cadmium. Banned in the EU because of a perceived danger caused by licking or sucking jewellery. But banned all the same.
                          Another quaternary alloy sees the cadmium replaced with a small %ge of tin
                          Then there is a ternary alloy where the cadmium is simply removed.
                          Which one are you using? Check your supplier's data sheet.
                          Personally (and with no medical qualifications whatsoever) I believe that you would come to no harm no matter which one you used.
                          Of more concern is the ugly and appalling colour match of these alloys on copper. Make it less obvious by the application of a heavy hammer to the thumb 👍
                          Or use a glue.
                          Then spray the bracelet with copper paint
                          Keith
                          #545250
                          Tim Stevens
                            @timstevens64731
                            Some people are allergic to jewellery containing Nickel – and this may well be used in hard solders to make the more silver-looking rather than brassy.
                            And I suspect that people do much more than suck or lick cadmium plated components. For example angle-grinding or welding. Fumes are the worst pollutants.
                            Cheers, Tim
                            Edited By Tim Stevens on 15/05/2021 16:17:31
                            #545294
                            duncan webster 1
                              @duncanwebster1
                              Copper plate it when you've finished?
                              #545348
                              Keith Hale
                                @keithhale68713
                                If you want to make your silver brazing alloy (hard solder) more "silvery" add more silver. See ISO 17672.
                                In the general scheme of things, the use of nickel bearing silver brazing alloys is not very common. It is used to join ferritic stainless steel components that are subject to crevice corrosion. It is cheaper and more convenient to use austenitic stainless steel.
                                Under certain circumstances the nickel can improve the "wettability" of the carbide, at the expense of fluidity. The resultant larger fillets / joint thickness may be advantageous with regard to joint strength dependent on the joint design. See also JMM data sheets 1100:122 published June 1973 and 1100:185 published Feb 1976. Other sources are available!
                                Keith
