33mm Spanner
33mm Spanner
Viewing 25 posts - 1 through 25 (of 35 total)
  • #487621
    MC Black 2
      @mcblack2
      I purchased a R8 Stub Milling Arbor 1" from Arc and discovered that the flats on the Left Hand nut were 33mm apart.
      I then found that 33mm spanners cost around the same as the arbor.
      However a plumbers Compression Fitting spanner from Toolstation (code 62263 costing less than £3.00) has 24mm and 32mm ends
      It only took me a couple of hours or so to file the 32mm jaws to 33mm. Well worth it to save £20 to £30.
      I had already filed the 24mm end on a couple of these to fit the ER16 Collect chuck on my Taig/Peatol Lathe so easy although NOT quick!
      #30750
      MC Black 2
        @mcblack2
        #487638
        peak4
          @peak4
          I would suggest that it's actually 3/4" Whitworth or 7/8" BSF.
          Perhaps the arbor was made in India, where that's quite common on machine accessories imported to the UK.
          Bill
          #487651
          not done it yet
            @notdoneityet
            Even so, a cheap spanner is a money saver – although there are often good quality, suitable used spanners sold at various locations, often for as little as 50p a throw. I can often buy a whole toolbox of spanners for £3, just for a couple of specific secondhand items.
            However, filing for a couple of hours seems over-energetic, when 0.5mm could be accurately milled away quite easily and quickly (that is what a mill has helped me do, for years).🙂
            #487653
            john halfpenny
              @johnhalfpenny52803
              That's a good spot for a large mouthed, slim spanner that is not too long. I'll be getting one to keep by my mill.
              Edited By john halfpenny on 26/07/2020 08:44:29
              #487656
              ega
                @ega
                The highly-regarded Campagnolo brand cycle spanners appear to have been finished by filing.
                #487658
                MC Black 2
                  @mcblack2
                  Posted by peak4 on 26/07/2020 02:23:07:
                  Bill
                  I asked Arc and was told that it was 33mm.
                  I will check my late father's toolbox and see if he had an open-ended spanner in either of those sizes.
                  But I suspect that 3/4 Whitworth would have been a bit small for the company's work (Architectural Ironwork) before WWII !
                  #487661
                  MC Black 2
                    @mcblack2
                    Posted by not done it yet on 26/07/2020 08:25:05:
                    I have only owned my Mill for a couple of weeks and NOT yet developed sufficient skills to do what you suggest.
                    I'm sure the filing would have been quicker for a young chap (or lady) but I have bicipital and supraspinatus tendinitis which limits what I can do with my right arm.
                    #487664
                    Maurice Taylor
                      @mauricetaylor82093
                      33mm = 1.299inches
                      A. 3/4 whit spanner is 33.02 mm across flats.
                      #487673
                      Martin Connelly
                        @martinconnelly55370
                        I like DIN 894 single ended spanners for specific uses like this. They are cheaper than double ended or combination spanners and easier on the hands when using them. I have a 36mm one for use with my ER32 collet holder and they are available in 32mm and 34mm a/f as well. I don't think I have seen a 33mm one.
                        Martin C
                        #487675
                        Norman Billingham
                          @normanbillingham91454
                          Propane cylinder spanners are 30mm AF, cheap and fairly easily modifiable
                          #487677
                          MC Black 2
                            @mcblack2
                            Posted by Martin Connelly on 26/07/2020 10:10:25:
                            Martin C
                            My ER32 Collet holder has little recesses rather than a hexagonal nut.
                            My ER16 Collect holder on my lathe has hexagonal nuts.
                            I'm getting used to the new wrench having filed the end spigots to fit.
                            #487681
                              Posted by MC Black 2 on 26/07/2020 09:14:19:
                              Seems logical for MCB to file the spanner he needs to tighten the mill's collet chuck to size, because milling with a cutter loose in the chuck is no fun.
                              How long it takes to file a spanner is individual too. A spanner might be hardened, whilst best choice of file and ability to use it accurately at speed can't be taken for granted. I was terrible with a file at first, better now, but I still have to take it slow to get reasonable results, not always successfully. I'm not one of those blokes who file perfect 1" cubes in 20 minutes!
                              PS May I ask MCB to stop capitalising the word 'not' in posts? Nothing wrong with appropriate emphasis, but unnecessary capitals on the Internet cause posts to come across as ENRAGED, losing sympathy and maybe altering the meaning. I'm not really enraged, but it's irritating to read NOT and have to decide if it's a Declaration of War, or innocent!
                              #487688
                              MC Black 2
                                @mcblack2
                                Posted by SillyOldDuffer on 26/07/2020 10:54:15:
                                My computer automatically capitalises "not" for the avoidance of doubt.
                                It emphasises the meaning where without "not" the negativity of the statement might missed or ignored.
                                But I will try to help Dave and others by changing the relevant word back to lower case when I remember.
                                Apologies in advance to any reader who is upset or enraged.
                                MC
                                #487690
                                Mike Poole
                                  @mikepoole82104
                                  Martin C
                                  +1 for DIN spanner’s and keeping it where it’s needed.
                                  Mike
                                  #487703
                                  Martin Connelly
                                    MC Black 2, the 36mm spanner is for the collet body flats.
                                    Martin C
                                    Edited By Martin Connelly on 26/07/2020 12:50:11
                                    #487707
                                    Peter Sansom
                                      @petersansom44767
                                      Try 1 5/16" af, I used to use 3/4" Whitworth for the tow ball nut, which is actually 1 5/16" af in Australia.
                                      #487711
                                      not done it yet
                                        @notdoneityet
                                        I am confused by this poster’s response to capitalised ‘not’.
                                        He previously posted this as a response to me: “Thank you "Not done it yet" for taking the time to respond.”. Perhaps the computer only changes lower case only ‘not’?
                                        Replying with ‘don’t’ or ‘haven’t’ would easily avoid the unnecessary shouting.
                                        #487715
                                        MC Black 2
                                          @mcblack2
                                          It capitalises "spacenotspace"
                                          If there's another character immediately adjacent, then there's no capitalisation.
                                          I have already undertaken to try to remember to reverse capitalisation and apologised if fail to remember
                                          Both my GP and a Consultant orthopaedic surgeon have strongly advised me to minimise computer use as a response to a physiological problem about which I have consulted them. I can just about cope (by using specialist software) with brief communications such as this.
                                          MC
                                          #487719
                                          MC Black 2
                                            @mcblack2
                                            Arc told me that the flats on the Arbor were 33mm and I have modified an inexpensive spanner to fit.
                                            If I had wrecked the spanner, the other end would still be useful for the ER16 Collet holder on my lathe.
                                            I posted the original message in case other subscribers could benefit from what I deem to be a quick solution to a problem.
                                            It's interesting to know that certain size Whitworth or BSF spanner will fit but little help if one doesn't own one that size.
                                            #487727
                                            ega
                                              @ega
                                              Surely the computer could be "told" not to autocapitalise?
                                              At a guess, it was "told" to do so in the first place.
                                              Correcting other people's English is a minefield.
                                              Edited By ega on 26/07/2020 14:33:49
                                              #487728
                                              Nicholas Farr
                                                @nicholasfarr14254
                                                Hi MC Black 2, I think I would have done the same thing rather than spend £20 or £30 on one spanner that would be used for one thing and if it wears out, just get another cheap one.
                                                Regards Nick.
                                                #487735
                                                  Posted by ega on 26/07/2020 14:33:34:
                                                  Autocorrect is funnier than most comedians, text message as received:
                                                  Happy Birthday to You,
                                                  Happy Birthday Dead Husband,
                                                  Happy Birthday to You.
                                                  Edited By SillyOldDuffer on 26/07/2020 15:19:32
                                                  #487738
                                                  Clive Brown 1
                                                    @clivebrown1
                                                    Posted by SillyOldDuffer on 26/07/2020 15:18:16:
                                                    Perhaps that's a new slant on predictive text, be afraid.sad
                                                    #487743
                                                    ega
                                                      @ega
                                                      "Happy Birthday" is so well-known that, if predictive text means anything at all, you would think it would get this right.
