Reply To: Running 380V 3-phase motor on 230V 1-phase
Home › Forums › Electronics in the Workshop › Running 380V 3-phase motor on 230V 1-phase › Reply To: Running 380V 3-phase motor on 230V 1-phase
#854011
Robert Atkinson 2
    @robertatkinson2
    On Pete Rimmer Said:
    On Robert Atkinson 2 Said:
    If the Steinmetz connection was an effective method of running electric motors it would be used in industry. It isn’t used in industry as part of the standard design of equipment.  You will always get the odd outlier example but it is not common practice. Show me one piece of commercial equipment that is DESIGNED to run on single phase and uses a 3 phase motor with a Steinmetz connection.
    Robert.
    I’ve already given one example of that. It’s true that I was surprised to find it but the fact remains nevertheless. This was not installed at some tin-pot establishment either it was at a very swanky building in Canary Wharf.
    No, you gave me an unsupported anecdote. How do you know it was designed to run on single phase as opposed to being designed for 3 phase and modified for that installation?
    Do you have any evidence? Photos of the equipment rating label and motor rating label would do. Make and model of the equipment?
    Even domestic electric gate openers use VFDs these days. It makes complying with safety regulations on closing force etc a lot easier.
    And don’t forget that 3 phase motors over 750 W now have to meet minimum efficiency levels. You would not be able to meet those running the motor on Steinmetz.
    Robert.
