I always try to buy 20mm holders and then mill them down to 18.53mm which is the exact height of the Smart & Brown model A which I use.
I have milled down at least 25 down, including Kennametal, Stellram, Sandvik, Iscar, Korloy, Seco, and others including Chinese, and they are all similar hardness. I use a Ceratizit 50mm shell mill with 5 RPHT12 inserts in it. The inserts can be indexed six times per set, and milling down just one tool uses up an index.
If you only have hss, then keep a good flow of coolant and use a very slow speed.
