I have decided to go with the oilites for the axles. I was speaking to a guy yesterday who used them on a twin bogie/4 axle electric loco. The loco is 5 years old and the oilites are still good today.
I had an idea, knowing that oilite bearings like to be bathed in oil I thought of a simple way of achieving it.
The rough sketch shows the 9mm hole for the suspension spring which sits centrally above the oilite. I thought if I drilled say a 3mm hole down through into the bearing location (before I fit the bearing) it would provide a well to feed the bearing. I,m guessing but say 3 or 4 drops of oil just to sit in the bottom would probably be enough and it could be topped up as required.
Whether it is worth doing I dont know but it certainly cant do any arm and is very simple to do.
Ron
Edited By Ron Laden on 18/05/2018 09:59:58
