Loose driving wheels
Home › Forums › Beginners questions › Loose driving wheels
Viewing 3 posts - 1 through 3 (of 3 total)
  • #347567
    robin brown 1
      @robinbrown1
      have a 5 inch loco and one of the driving wheel is showing sines of movement
      On the axial it’s been quartered with 3 set screws which is the best way to refit it
      #9143
      robin brown 1
        @robinbrown1
        Best way to fix
        #347574
          Probably using a a suitable grade of loctite to suit the gap. Choose one with a slow setting time so you can get the quartering right.
          Google "Loctite selection guide", the pdf that shoudl come first is very useful. Slow curing 640 retainer is probably a good place to start, it should give you plenty of time to set the quartering and nip up the set screws.
