Links for Workshop and Model Engineering STLs and other files.
Home › Forums › 3D Printers and 3D Printing › Links for Workshop and Model Engineering STLs and other files.
  • #853330
      There are other sites such as Thingiverse (among several others) that provide useful repositories of free or reasonably prices STL and other files.
      It makes more sense to use these repositories than to try and emulate them on this website, but it’s been suggested we have this thread as a place for members to post links to the files for their workshop and model engineering projects.
      I request that discussion is kept to a minimum – ideally discuss the projects in their own threads.
      Just use this thread to post a link and a description, also a link to any thread discussing the project if you like.
        I haven’t uploaded many of my workshop accessories to Thingiverse – many of them are either too basic or specialised.
        This one is a solder fume fan I made a good few years ago, it uses a 4″ computer fan to suck fumes through a double layer of carbon filter from generic cooker hood refill material.
        https://www.thingiverse.com/thing:6922387
        temp
        #853340
          I made it Sticky for you rather than drift down the list.
          #853355
          DC31k
            @dc31k
            Could you also change the thread title FROM UPPERCASE to a more polite rendition.
            If we had a competent magazine editor on hand, they might advise concerning what looks good in print and what hurts the eyes.
            #853427
            John Hinkley
              @johnhinkley26699
              As there seems to be plenty of room on the bandwagon and it’s been far too hot to venture into the workshop, I offer the following files for the fitment of an ELS to a mini lathe. I designed the mounts and gears in Alibre Atom 3D and thet were printed on my BambuLab X1C.
              They are rather machine specific, that is to say they were designed to utilise the mounting holes on the original AMA714B mini lathe to avoid having to drill into the castings, but might well fit others of the same ilk.  The prints allow the fitting of a rotary encoder to the main spindle and front mounting of a NEMA23 stepper motor to drive the standard leadscrew.  In my case it was coupled electronically to a single-axis ELS device from This (French) supplier.
              The 3D print files can be downloaded from Thingiverse.com, here.
              They are in STL format only on here but I exclusively work with STEP files at home.
              There are a couple of videos on my YouTube channel showing the installation, starting with this one.
              Happy to answer any queries and/or supply STEP files if anyone wants to tread the same path.
              Gerard O’Toole
                @gerardotoole60348
                These are motorcycle related and might have a very limited interest here.
                Two similar projects, A pointer and timing disc holder for Velocette Venom/MSS/MAC  and the same for 1960’s on Matchless G3/AJS 16.  They both incorporate a micro adjustable pointer making it easier to read the disc.
                For Velocette
                https://www.thingiverse.com/thing:4324114
                For Matchless/AJS
                https://www.thingiverse.com/thing:4324130
                And two for the BMW F800 series. One is a simple tool to undo the cap on the front brake master cylinder
                https://www.thingiverse.com/thing:4315595
                And covers for the throttle bodies. These aid servicing as they throttle bodies provide a wide opening to allow fallen screws or other undesirable items fall down into the engine
                https://www.thingiverse.com/thing:4324084
                And, more workshop related,  Worms and wheels for a Pittler B2 lathe.
                https://www.thingiverse.com/thing:5983017
                Videoframe_20230422_142657_com.huawei.himovie.overseas
                #853504
                Pete Rimmer
                  @peterimmer30576
                  A working model of a Balzer relieving tool. This was my first ever design (in sketchup) and printed on my Ender 3 printer. Nowadays I use Fusion to draw 3d models.
                  https://www.thingiverse.com/thing:4043256
                  And here’s a paint stirrer I drew up for mixing 5L tins of paint on a battery drill. Requires a 8mm or 5/16″ knurled rod. I have made two of these (one for me and one for the neighbour) and they work fantastically well.
                  https://www.thingiverse.com/thing:7341153
                  #853924
                  John Purdy
                    @johnpurdy78347
                    A Myford change gear rack including two 21 tooth and the fine feed cluster with dust cover.
                    https://www.thingiverse.com/thing:7376094
                    Myford Change Gear Holder
                    Gear Holder Cover
                    A lead screw swarf guard to replace the original marginally effective Myford one.
                    https://www.thingiverse.com/thing:7376087
                    Leadscrew Swarf Guard
                    A ER11/ER16 collet storage tray with cover.
                    ER11_ER16 Collet Rack
                    Cover1
                    #854165
                      I was very aware people would be looking for it on the list. It can be decapitalised ina few day’s time.
                      #854180
                      John Purdy
                        @johnpurdy78347
                        I just noticed that I forgot the link in my post above for the collet holder. Could you maybe add it to my post? Senior moment!       https://www.thingiverse.com/thing:7376090
                        Colin Heseltine
                          @colinheseltine48622
                          Neil,
                          This topic is exactly what I wanted to see.  Lots of useful ideas.
                          Thanks guys for your various ideas.
                          Colin
                          The Myford gear rack and lead screw cover are two which will be printed asap.
                          #854266
                          timdotd
                            @timdotd
                            A couple of mine, somewhat niche but who knows might be useful to someone:
                            A dividing head plate for Vevor-style heads with the missing 22, 24, 25 and 26 hole patterns:
                            https://www.thingiverse.com/thing:7345863
                            A crossing-out jig for clock wheels, based on the J Malcolm Wilding design:
                            https://www.thingiverse.com/thing:7352324
                            #856570
                            John Purdy
                              @johnpurdy78347
                              Having gotten fed up with cleaning the swarf off the tool bits stored in a plastic container on the lathe bench, I came up with this:
                              https://www.thingiverse.com/thing:7384593
                              ToolBitHolder
                              ToolBitHolder1
                              ToolBitHolder2
                              #856657
                              Mark Rand
                                @markrand96270
                                This is not my own work!
                                downloads
                                This is the work of ‘ Olfoundryman’ on another forum and presented as a series of videos by him on youtube.
                                Hopefully I’ll get the furnace going in the near future and make some, since I had a few MDF moulding boxes suffer from flooding in the pit under the shed…
                                These are my prints of his patterns, the ghastly mess on the bench is all mine as well. 😮
                                20260718_161428
