Unconventional way of making a rack
Home Forums Beginners questions Unconventional way of making a rack
  • #233551
    Ian Parkin
      @ianparkin39383
      I had the need for a longer rack (2ft) for a large fobco drilling machine
      I couldnt envisage what/how to do it with my workshop equipment
      a local gear cutter wanted £300 or so to make it assuring me that it was absolutely critical that the tooth form was perfect and any inaccuracys would lead it it jamming wearing quickly
      I think It was mr J.S who suggested cutting the teeth with my vertical mill and then setting the head over and then doing the angle
      4 end mills later (3mm ones) i had cut straight down (100 teeth)
      1st question what depth of cut and speed and feed should a 3mm endmill be able to cut in MS?
      I tried setting over the head but it was giving a dreadfull finish as the bit was moving rather than cutting
      So i bought a gear cutter suitable for a rack
      Thinking of ways to use it maybe mount a motor and gearbox on the mill spindle or a right angle drive
      Made an arbour out of 1" ms and mounted that in the lathe mounted my precut blank in the toolpost and gingerley fed into the cut….perfect 2 different heights on the toolpost and job done in 2 hours doing 5 teeth at a time before moving the blank in the toolpost
      Cutter was spinning at 210 revs…
      2nd Q is that about right for a gear cutter 3" diameter hss cutting MS?dsc00953 (medium).jpg
      This was as I progressed so I had the moving steady supporting the arbour
      turned the blank around and changed set up for the endsdsc00957 (medium).jpg
      this the finished rack and the original which is only 10 "long and a sealey one I bought which worked fine but didnt look too good
      I've motorised the bed…absolute luxury
      switch gear mounted in a moveable box if it gets in the way it can move
      Edited By Ian Parkin on 06/04/2016 17:35:01
      #8087
      Ian Parkin
        @ianparkin39383
        #233563
        pgk pgk
          @pgkpgk17461
          As I understand it mild steel cutting speed about 100-150 surface feet/min depending on exact spec steel..so call it 120sf/m. For hss it's (4 x sf/m)/diameter in inches.
          So 3mm (1/8th in) hss endmill = 4x120x8 = 3840rpm
          And a 3" cutter = 4 x 120/3 = 160rpm
          A good job
          #233569
          Ian Parkin
            @ianparkin39383
            Is that why my end mills were breaking then because I was only running at 1600?
            #233575
            John P
              @johnp77052
              Here was my solution to cut a rack 20 DP 159 teeth 25
              inches long, the head on the mill was rotated 180 deg ,a
              power take off gears down and provides a 90 deg turn
              to drive a shaft . A simple plain bearing shaft has another
              90 deg drive and is mounted on the overhanging head
              ram and is braced very securely to the mill column.Has
              a silver steel cutter made on the Eureka device at
              20 DP ,a simple cnc file drives the cutter through the
              blank and then indexes along to the next tooth.Cut
              depth set by lifting the knee.
              Photo's in album cutting racks.
              pgk pgk
                @pgkpgk17461
                Posted by Ian Parkin on 06/04/2016 19:36:02:
                So I've been told but my mill doesn't run faster than 1600 either. It's also feed-rate +/- coolant.
                I've been cutting copper with a 3mm endmill recently but I've been taking it slow with multiple shallow cuts 'cos my last milling with a 1.5mm ended up with broken endmills too.
