Setting up a long bar for between centres turning
Home Forums Beginners questions Setting up a long bar for between centres turning
Viewing 25 posts - 1 through 25 (of 26 total)
  • #7908
    Iain Downs
      @iaindowns78295
      #216015
      Iain Downs
        @iaindowns78295
        I'm looking to turn a spindle for a lathe. I've a nice piece of 40 mm steel which will fit in the 7×14 lathe I have. It's about 300mm long.
        I get the basics of centre turning, but I'm trying to work out how to get both ends centre drilled accurately.
        If I just stick the bad in the chuck I would expect it to sag a little, so it will wobble as it rotates and the centre drilled hole will likely not be on centre. Also, I'm concerned about facing off the ends. I don't currently have a steady.
        I can punch a mark in the end, but I'm unlikely to achieve particularly fine accuracy.
        I think I read somewhere that the rotation will tend to pull the bar into the centre so will auto-centre, but I can't find the reference again.
        I appreciate that this is likely to be a bit demanding for a beginner, but I do have a spare bar for when this goes badly wrong.
        Thanks for your advice in advance!
        Iain
        #216019
        mechman48
          @mechman48
          Hi Iain
          I wouldn't attempt to turn / face off that length of bar without a steady; all you'll do is push the bar out of true from the lathe axis, this will then make the bar trace an elliptical pattern & you'll end up with the bar whipping round on to the top of your tool & causing no end of trouble, try and borrow a steady. I don't know which machine you've got so can't comment on type of steady that may be available, if you can afford it buy one from the manufacturer / retailer of your machine, they're not that expensive.
          If you do get a steady… set it up so that the fingers are set on the bar near the chuck, then move the steady to the far end ( tailstock end ) close enough to give you enough working room, face off then centre drill, turn bar round & do the same for other end then you'll have the centres as accurately drilled as needed to run it between centres.
          No doubt other members will offer their own methods…
          George.
          #216024
          ega
            @ega
            Iain Downs:
            An alternative to using a steady would be to find someone with a larger lathe which will accept your bar for centre drilling purposes leaving you to do the bulk of the job yourself.
            Anyone offering to do this would need to have some idea of your location (no public profile).
            #216027
            Bikepete
              @bikepete
              Presumably you'll need to machine the material down from its current diameter anyway, so careful marking out, punching and centre drilling could well get you close enough – say to half a mm of the true centre. So long as your stock is more than say 1 mm bigger than the largest finished diameter you need, that should be fine.
              Facing the ends completely is another matter – and even more so if you want to drill out the spindle at all. Can't think of an easy alternative to using a fixed steady.
              If you can't just buy one (and for smaller lathes, check its maximum capacity first) it might be worth making one. Google 'DIY fixed steady' for inspiration.
              A cheap but temporary bodge (for centring, at least) is to fix a block of wood solidly to the cross slide (and lock the slide!), and bore it using a tool held in a four jaw chuck, to a sliding fit on your stock. Grease it before use and use low rpm to put in the centres.
              A slightly trickier version which will allow facing as well is to mount the block of wood to the lathe bed, securely but so it can still slide along when pushed by the carriage. Do this to bore it, again using a tool in the four jaw. Now you can fix this firmly to the lathe bed, mount your stock (with the other end held in the 4 jaw), put in the centres and face the ends.
              But if a 7×14 lathe is 14" between centres, and the part is 300mm long, you'll be close to the machine's capacity, so double check that there's going to be enough carriage travel available even with the steady in place… also that you have enough length available to get the centre drill mounted in the tailstock (in a drill chuck, probably) with the stock in place held by the chuck…
              It would certainly be a much easier job on a bigger machine.
              Edited By Bikepete on 12/12/2015 13:07:32
              Edited By Bikepete on 12/12/2015 13:12:29
              #216031
              Iain Downs
                @iaindowns78295
                Thanks for the advice.
                I think the fixed steady is the approach. The machine is a SPGTools 0618A (Real Bull CJ18A) and the bar fits quite comfortably.
                SPGTools (and Amadeal and others) have a fixed steady which isn't expensive. What it is however, is of uncertain capacity.
                I can't find a spec for it on either site (amadeal has a picture which makes me guess it will take 50mm, but I'm not entirely sure.
                I could make one, of course – making the tools is more fun than making the project), but for 20 quid it doesn't seem worth it.
                Anyone know what the capacity of this centre is?
                Iain
                #216049
                ega
                  @ega
                  Iain Downs:
                  Just a thought. Is your spindle intended to be drilled through the whole or part of its length and, if so, how will you do this?
                  #216050
                  Brian Wood
                    @brianwood45127
                    Hello Iain,
                    I don't like to rain on your parade, but I think you are being rather ambitious in expecting your lathe to be able to cope with a job matching it's own capacity for supporting work between centres.
                    Looking at some of the practicaliities involved; how do you plan to make a through hole in the embryo spindle? Even with the best will in the world getting a drill with at least 6 inches of reach just to get half way adds to the overall length of the job which then exceeds your 7 X 14 lathe bed length by 4 inches and that is before you add a chuck or whatever to hold it. You also have to be able to withdraw it to clear swarf.
                    You don't say if this is a copy for your own lathe or for another, if it is for your own then the work planning needs careful thought for correct sizing to an existing pattern just at the time you need the lathe to do the work!
                    Better by far to put the job out to someone else with the machine capacity to do the whole job, including reaming the taper at the chuck end as one concentric job with properly sized bearing diameters. Alternatively, buy a new spindle from the sellers and save yourself the disappointment of not being able to start on it, let alone finish it.
                    Brian
                    #216057
                    Iain Downs
                      @iaindowns78295
                      This is my own design of lathe and will not have a through hole. I certainly don't have the gear to make that!
                      I see this as an opportunity for learning rather than a well planned project with a specific end goal.
                      The next two challenges are how to bore and align the bearing holes in the headstock and how to press the bearings into place with the kit I have on hand, but I'm trying to limit my pesteration to a reasonable level!
                      I must say that the helpful responses in this forum have hugely encouraged me.
                      Although a beginner I did do Metalwork at school to a good standard and some of it appears to have stuck in the intervening 40 years. Not much, but some.
                      Iain
                      #216058
                      Ady1
                        @ady1
                        Between centres work is one of the most skilful jobs you can tackle on a lathe
                        The hole down the middle isn't critical except at the morse taper nose end if you leave enough room between the workpiece and the inner shaft diameter
                        You'll need a good fixed steady too, everything, absolutely everything, has to be spot on at the nose end plus the outer shaft has to be spot on along it's entire length
                        A real challenge that will need careful planning and preparation
                        #216064
                        Iain Downs
                          @iaindowns78295
                          And lots of help! I'm trying to design it so that it is forgiving of my fingers.
                          I have 4 150x150x20 steel plates which will form the headstock. I've got a larger front bearing (62 / 30) than rear bearing (60 / 25) so I don't have to be totally dead on in my set up (aligning the tailstock is a bit of a pain).
                          If I can assemble the headstock and bore out the bearing holes in one operation I have some hopes of accuragy. If I overbore a bit there is always superglue. If I can't bore in one operation then aligning the headstock afterwards is going to be interesting!
                          The drawing below (onshape – online and free and from the solidworks founders) is missing some bits but should provide an idea of what I'm trying to do.
                          Iain
                          drawing151212.jpgAnd lots of help!
                          #216066
                          mechman48
                            @mechman48
                            How are you going to assemble the headstock? if welding then you'll have stresses that will need to be relieved before boring out, Boring between centres would do it but have you got a boring bar to suit?, do you have the centre height to set up in line on your saddle, if bolted you could machine out bearing locations using a 4 jaw & adjust to line up with a dummy mandrel… or as mentioned… ask someone with a bigger machine .., lots of questions arising!
                            George.
                            #216070
                            Chris Evans 6
                              @chrisevans6
                              Iain, give us a clue on location, some of us have large machinery if you run in to trouble. I hate to see projects stall for wont of asking for a bit of help; credit to you for trying and coming up with a design. Is it for a wood lathe ?
                              #216073
                              Iain Downs
                                @iaindowns78295
                                HiI, All.
                                I'm in Pannal near Harrogate.
                                I was planning to pin and bolt the headstock. Welding's not something I've mastered yet (I have a stick welder but at the making a spark stage).
                                Initially I'm planning a wood lathe. If I end up with something robust, who knows where it will go!
                                Off to finish cooking a curry!
                                Iian
                                #216084
                                Brian Wood
                                  @brianwood45127
                                  Hello again Iain,
                                  I was perhaps a bit harsh in my earlier posting, having erroneously assumed you were working on the spindle for a metal lathe. The absence of a through hole alters the job difficulties a great deal.
                                  I live just ouside Thirsk and I could certainly put the centre holes in place for you, if in line boring of your new headstock would be possible on my Myford lathe I would be happy to help there too. Bolted construction with dowel pins as you have indicated for the headstock would take out alignment problems and avoid welding which would introduce them
                                  A suggestion that has just come to mind is to make a dead centre nose to the spindle when you are machining the other detail, it might be invaluable at times
                                  Brian
                                  #216091
                                  Bikepete
                                    @bikepete
                                    I think I would probably machine front and rear plates of the headstock in one operation (i.e. with them clamped or bolted together), to ensure they are the exact same size (machine all edges). Bore the bearing bores in one operation too (plates still bolted together), smallest first then open one out to the larger. Much easier to do a short compact bore like this (with the plates bolted together) than with them separated by the length of the headstock, especially on smaller machines.
                                    Assuming the remaining plates are flat or can be made flat , when you assemble the headstock the bores should still be accurately in line.
                                    #216140
                                    bricky
                                      @bricky
                                      Hi
                                      Nobody has yet mentioned that the space availiable will not allow the cross slide far enough to the end of the bed for the tool to start at the end of the bar.Before starting check this out.
                                      Frank
                                      #216142
                                      Brian Wood
                                        @brianwood45127
                                        If I may add a comment from hard won experience. By all means rough out the bores for the bearings but leave the final sizing until after the headstock box is completed, things are bound to move and settle to final positions and doing the in line alignment at the end will correct any twist or misalignment coming from the assembly stage.
                                        Bearings are fussy and unforgiving things and having to 'glue' them in at the end to allow for a very small error would be a shame.
                                        Brian
                                        #216154
                                        Ian S C
                                          @iansc
                                          Iain, I think you'll be pushing your luck with a 14" / 350 mm lathe on a 300 mm shaft, to put the centre holes in you'll need a drill chuck in the tail stock with the Slocombe / centre drill, and I don't think it will fit.
                                          If your lathe is a modern (Chinese or other), it should have come with fixed and moving steadies, if not they should be available, and if your bit of steel was much thinner than the 40 mm you have, a travelling steady would be useful.
                                          I have repaired / modified a number of wood lathes, and I bored the nose of the spindle to fit # 1 MT, because I have a # 1 & 3 MT reamers (3 too big). It's worth doing if you can, my first one was just bored with a boring bar.
                                          Ian S C
                                          #216157
                                          Iain Downs
                                            @iaindowns78295
                                            Thanks, Brian. I'm still toying with how to register the chuck / faceplate or whatever on the spindle. at the moment I'm favouring using the outside diameter of the nose as the register and putting 3 or 4 threaded holes in the end. My main concern with that is how I can get 4 accurate holes in the top of a 12 inch bar with the kit I've got. The other thought was to thread the outside of the nose or have a central hole with an internal thread. Hmm, I've just had the thought that I could put the screws in from the side rather than the end. Has it's own issues, but different ones.
                                            Bikepete – the outside diameter of the bearings is the same (62mm) – only the internal hole is different I doubted my skills at making two accurate holes of different sizes. And yes I had planned to machine the plates in one go. I hadn't thought of bolting them together, but that's an excellent idea.
                                            bricky – I've checked that the cross slide will get to the end. It does with room to spare.
                                            Brian – At the moment I don't have a boring head for my mill. My sister is delighting in telling her friends she's getting me a 'boring head' for Christmas. I can be geeky at times… I'm not sure that my mill (CMD10) and the head I'm getting will have ability to bore what is effectively a 7 inch deep hole (albeit with a 6 inch gap in the middle.
                                            I've thought of boring the holes as Bikepete suggests, pressing in the spindle and then bolting the parts together with the spindle in place, but I don't really know if that would create stresses which would put it out of kilter. But at least this way I could have some what of adjusting (shims etc) afterwards.
                                            Thanks again to all for advice. This has a better chance of success with your help! Oh – I'm expecting this to take quite some time, so if I go quiet it's not necessarily that it's so disastrous I can't show my face …
                                            Iain
                                            #216158
                                            Iain Downs
                                              @iaindowns78295
                                              HI, Ian.
                                              I'll give the morse taper some thought, I don't think my cross slide is long enough for a 2mt which is what most of my tooling is and most of the other internal taper boring approaches are beyond me.
                                              I'm also going to go out and fit my drill chuck in the tailstock and see if there is space for it. push comes to shove I can reduce the spindle length though I don't much fancy taking a lot off the plates with my poor little mill…
                                              Iain
                                              #216159
                                              Gordon W
                                                @gordonw
                                                Just a couple of ideas, I've got a slightly bigger lathe . – make a center drill holder from a morse-taper blank ( or old drill) to suit the tailstock. Drill a hole same size as the drill and stick the drill in the tailstock holder with super glue. This will give more room . I would fabricate the headstock first then mount on the cross-slide for boring, assuming there is room. Drill and tap the cross-slide .
                                                #216171
                                                Bikepete
                                                  @bikepete
                                                  Posted by Iain Downs on 13/12/2015 10:50:40:
                                                  As Brian Wood suggested a few posts below mine, if at all possible then do finish bore them in the complete headstock assembly – this would be very much better for alignment. My suggestion was intended as a bodge to work around your machinery… If it will fit, perhaps the most promising route would be a between centres boring bar on the lathe, as suggested by mechman48 and Gordon W above. If it won't fit, and you can't bore in the mill either, you may have to try the solution you describe above unless you farm it out.
                                                  A few other thoughts:
                                                  • What sort of bearings were you going to use? For metalworking lathes you'd probably favour angular contact ball bearings, so that you can preload them against each other to take out all play, with a nut on the spindle. These are the fussy ones for alignment but provide a rigid spindle which resists both end and side loads. 'Normal' deep groove ball bearings are a lot cheaper, a (very little) less fussy but aren't really designed to cope with large end loads or preload. 62×30 size deep groove bearings might well be big enough to cope fine with woodworking type end loads – I don't really know.
                                                  • How will you locate the bearings axially? One set at least needs to be fixed so that the spindle can't move along its length. Were you going to leave a shoulder at the end of one of the finished bores, add a bolt-on plate to hold them in, or e.g. add a groove for a circlip?
                                                  • You mention you're making up the headstock from four plates (front back and sides presumably). If you add a lid and base (two more plates) it'll make the whole thing immensely more rigid.
                                                  • I think you said the plates are 20mm thick steel. Just machining the edges to clean them up might be a bit 'epic' on a CMD 10: one of these presumably? I've not used one but it looks a very light machine for that sort of job. Maybe take a test run before you commit to the design?
                                                  • Bearing in mind this is a wood lathe, I can't help thinking that a design using pillow block bearings would make life an awful lot easier. They're not ideal in some ways (not specifically designed to cope with end thrust, nor of immense precision) but if you were planning on using 'normal' deep groove ball bearings anyway they'll be no worse (that's what they are, basically, in a self-aligning housing), and woodworking loads might well be within the capacity of say 35mm ID pillow block bearings (go as big as you can, given your 40mm spindle stock). And they self-align… so just need bolting to something solid. Plus they are remarkably cheap e.g. here.
                                                  #216175
                                                  Brian Wood
                                                    @brianwood45127
                                                    Hello Iain,
                                                    Just trying to hold 12 inches of material upright and then begin boring a hole down from above with a lightweight mill really is asking for trouble. The tooling alone in the boring head will only reach maybe 2 inches at most and the instablity of the whole set up is against you right from the start.
                                                    I do have other equipment to tackle some of this project for you, leaving you with the things you can manage.
                                                    I would also strongly advise against using your spindle and bearings as an assembly guide for the headstock box, you might not notice a slight misalignment as you bolt up but the bearings will and side loading of that sort will lead to rapid failure even if it turns at all when built.
                                                    Send me a PM for my address, email etc and we can take that further if you wish.
                                                    Include your email while you are doing so.
                                                    Brian
                                                    #216182
                                                    Iain Downs
                                                      @iaindowns78295
                                                      Hmm.
                                                      Much food for thought. It turns out there is space for the centre drill so that is one less worry.
                                                      Although the initial intent is a wood lathe, I'm quite keen to see if I can get something which will tackle metal too – that needs a bed and stuff which is beyond my ability to think about at the moment!
                                                      The diagram isn't complete. There are a couple of bolt on plates which will act as stops.
                                                      I've had some reasonable success with milling a nastier bigger piece of steel on the mill, though I broke it in the process! I learned a lot from that.
                                                      As mentioned earlier I'm doing this as a learning exercise and if I end taking it to bits and rebuilding it with Pillow bearings or need 2 or 3 goes to get the spindle right, I'm cool.
                                                      So I do plan on stretching myself and kit in the sure knowledge that I will cock some things up well and truly!
                                                      All your advice is much appreciated, though and improves my chances of getting something working no end!
                                                      Iain
