kasenit
kasenit
Home Forums Beginners questions kasenit
  • #6985
    roy entwistle
      @royentwistle24699
      #138388
      roy entwistle
        @royentwistle24699
        I have a plastic tub of Kasenit case hardening compound unfortunately I don't have the instructions for use Can anyone help please?
        Roy
        #138390
        Ian Welford
          @ianwelford58739
          got mine from Chronos a few years ago- might be something on their site about it. If not drop me a line and I'll try to find my leaflet and copy for you.
          Merry Christmas Ian
          #138398
          julian atkins
            @julianatkins58923
            hi roy,
            the instructions are (if i remember correctly, as my original tin has rusted) is to heat to red heat then plunge in the powder, then reheat to red and plunge in water. ive never quite understood this method. i coat the work in kasenit mixed to a paste in water (not a lot of water mind you). i heat to red heat as long as i want then plunge in water. very good quite deep case hardened surface this way and no scale either.
            look after your kasenit as it isnt available anymore!
            cheers,
            julian
            #138400
            Fatgadgi
              @fatgadgi
              Hi Roy
              Just checked my nearly full tin smiley
              1. Heat part to bright red and put into the powder. Move it around so that it sticks all over the part.
              2. Re-heat to bright red (careful, you need tinted goggles as it seems to glow incandescently). Plunge straight into cold clean water.
              For a deeper case, do step 1 twice before step 2
              (Julian, I've never needed to use water as it has always stuck straight away for me)
              Cheers – Will
              #138401
              _Paul_
                @_paul_
                Posted by julian atkins on 20/12/2013 21:42:00:
                cheers,
                julian
                Sadly true, however Blackgates do their own brand of case hardening powder witch works exactly the same as and has the same properties as Kasenit.
                I normally get mine from their stand at whatever particular event they and I are at.
                Paul
                #138403
                JohnF
                  @johnf59703
                  Roy, Broadly speaking everyone is correct but sometimes you will need to heat to full red and dip into the powder then heat some more and dip again to make sure you have powder on the component.
                  Also you then need to apply heat for several minuets obtain a sufficient case before quenching.
                  John F
                  #138405
                  old Al
                    @oldal
                    And if it dosnt 'pop' its not done.
                    Alan
                    #138406
                    old Al
                      @oldal
                      Or should I say, have a distinctive crack sound when its quenched
                      Alan
                      #138420
                      stevetee
                        @stevetee
                        I seem to recall that you can repeat the ' heat and dip' process for a deeper case. I'm sure that you will all know that of course kasenite and similar products are made so as to be able to case harden mild steels, so it's use is uneccessary on carbon steels.
                        #138462
                        roy entwistle
                          @royentwistle24699
                          Thank you all I knew someone would know May I wish everyone the complements of the season and a happy new year?
                          Roy
                          #138491
                          Ian S C
                            @iansc
                            As SteeveTee says it's unnecessary to use it on carbon steel, but the tin says it can be used on silver steel.dont knowthinking
                            Ian S C
                            #138496
                            Russell Eberhardt
                              @russelleberhardt48058
                              Posted by Ian S C on 22/12/2013 09:16:10:
                              Ian S C
                              I wouldn't use it on silver steel as the quenching process will harden it all through and could make it brittle.
                              By the way, why is "carbon steel" called that? Doesn't all steel contain carbon? wink
                              Russell.
                              #138500
                              MICHAEL WILLIAMS
                                @michaelwilliams41215
                                Hi Russel ,
                                You need to prefix low – medium – high before Carbon Steel . Preferably though the actual % Carbon or material spec .
                                Case hardening of Silver Steel shows some small benefit when the material section is big enough to retain heat in the core when quenched so that it doesn’t harden all the way through . That’s just for interest – I certainly wouldn’t advise doing it – there are much better procedures available and more appropriate steels .
                                Regards ,
                                MikeW
                                #138556
                                RRMBK
                                  @rrmbk
                                  good stuff but —
                                  make sure you store it well away from little fingers.my tin lives at the back on the highest shelf in the workshop. I think the reason it is no longer available is because it contains cyanide!!
                                  Best wishes to all for the festive season.
                                  #138559
                                  Frank.N Storm
                                    @frank-nstorm18349
                                    Brian, sorry for playing spoilsport here, but Kasenit does not contain cyanide. It contains a complex salt of Ferrocyanide (could be Ferri-, not too sure which). but one of the wonders of Chemistry is that the same name in different combinations has not the same property. You spice your meals daily with Sodium chloride, which contains Sodium (very nasty) and Chlorine (even more nasty). Will you stop doing that because they both are strong poisons?
                                    Regards, Frank
