Judt found out how to post pictures directly, so here they are.
Some more information about the lathe:
So as i said there is no type plate or anyting on the in or outside of the machine. It has a bison 160mm chuck on there, which I think isn't original. The lathe has autofeed in both directions, with 6 different feeding speeds. There is a 2 step 3 phase motor in there, 700 and 1400 rpm. 4 different sizes pully at the motor and 4 at the main shaft. Rpm range is 250rpm until 3100 rpm. It has a clutch and brake in the drivetrain, and a lock to lock the main shaft in 6 positions, each 60 degree. Oilpump is there aslo, but not working at the moment. All text is italian. I have looked the list at lathes.co.uk, but couldn't find anything.
Edited By Jurrian Mulder on 27/10/2019 13:33:27
