Charlie Q1
Charlie Q1
  • #38726
    Tony Mills 1
      @tonymills1
      Corrections to radius location on frames
      #45379
      Tony Mills 1
        @tonymills1
        The correction I am refering to relates to corrections under heading, ‘Crank axle assembly (6 lines down)’, that appeared in  Model Engineer Vol. 203 No. 4357.
        I’ve located the centre of the radius with new measurments, but the new position puts the radius about 2 mm away from the large stetcher hole: Model Engineer drawing of frames in issue Vol. 202 No. 4353.
        #45502
        nick feast
          @nickfeast85472
          Hi Tony
          I have checked my drawings and will clarify: The top edge of the frame means the top edge of the complete frame not the notch at the back.
          That should work.
          Nick
          #45967
          nick feast
            @nickfeast85472
            A message to all builders of my Q1 design. Now that I have built the valve gear  of the model being illustrated in ME I have discovered that i have not altered the drilling plan to suit mods to the valve gear. Therefore please note that if you are working to the drawing published in ME or drawings bought from Polly models up until now then the pivot for the slideshaft will be in the wrong place. This means that the loco can be timed to run forwards but will not time properly in reverse.
            I am re issuing the drawing Q1-008-L-003 as revision 5 and any orders to Polly after next week should get the latest issue. The only change is to move the pivot point 3mm up and 1mm to the back of the loco. The rear fixing hole can still be used but the bearing will need to be rotated to fall in the correct place. I will cover this point in the magazine but this artticle will not get into print until the new year by which time a few more frames may have been drilled!
            #107981
            Another JohnS
              @anotherjohns
              Nick;
              I'm going through my plans (from Polly) and want to be sure that I have this correct.
              Q1-008-L-003-Rev3.
              Drilling plan. I have the "C/L Slideshaft drill 1.5 dia" as 15mm down from the cutout, 55mm in front of the CL of the 2nd axle. Should this be 12mm down, and 54mm back?
              Generally, do you have a listing of errata to the published plans by Polly? I'm wondering if the plans I purchased (after completion of the series, IIRC) are up to date.
              Thanks;
              Another JohnS.
              #107989
              alan-lloyd
                @alan-lloyd
                John, the revised measurements are as you quote 12mm down and 54mm forward from the middle axle centre line. Have you seen the other threads on here reguarding boiler treads and the regulator flang dia, regards Alan
                #108030
                Another JohnS
                  @anotherjohns
                  Alan –
                  Thanks for the tip – I did just find it by search a few minutes ago.
                  Right now just CADing up some drawings to add to the water jet cutting next time, and might look at the wheels as an interesting CNC project.
                  I do have a few projects to finish before hand (the Worden T&C is essentially complete) and some, like injectors, will do for multiple projects. (eg, the Shay locomotive under my workbench has the injector as the biggest hurdle to completion)
                  So, I won't be steaming one this summer, but do like the size and utilitarian looks…
                  Regards to all;
                  Another JohnS.
                  #108126
                  nick feast
                    @nickfeast85472
                    Just to confirm the dimensions quoted above are correct to rev 5 of the frame drawing corrected in Dec 09. All drawings sold by Polly after that date should be rev 5. I will check with them to be sure.
                    I hope to be showing the loco built for the ME series at the London show at the Alexandra Palace on the Polly stand. This loco has been used for passenger hauling over the last year so will not be in 'exhibition' condition. It has the hydrostatic oiler option, no added handrails or guards and is in Southern Railway livery.
                    Nick
                    #108166
                    Another JohnS
                      @anotherjohns
                      Nick;
                      Just a FYI, my order for drawings went through 09/03/2012 – and it has the rev3 of that above mentioned drawing – updated by you in 2009.
                      I wonder what else is "behind the times" in my drawings?
                      Oh well! It's still great to have these drawings all in one place to page through, and, you did an admirable job in creating them.
                      Another JohnS
                      Edited By John Alexander Stewart on 07/01/2013 23:51:21
                      #108205
                      Another JohnS
                        @anotherjohns
                        Posted by John Alexander Stewart on 07/01/2013 23:50:14:
                        Also found that there was a "rev4" on the line below the "rev3" number on the frame drawing.
                        Apologies – the drawings were rolled and *really* wanted to curl up. Trying for days to get them to lie flat and put them in order, when I noted the "rev4" (also, am used to the digital age, where there would be only one revision number!)
                        The slide shaft error was still there, not sure how old the "rev4" drawing was – but it must pre-date Nick's December '09 update, as his "rev5" was sent to Polly then.
                        This is just "info" – I think Nick has done a great job with very few noted errors (golden compared to others before him) and thank Polly for being the supplier – I just want others who may be in my shoes of purchasing drawings to note that they may possibly be years behind updates supplied by the author.
                        Another JohnS.
