parts for drill press
Home › Forums › Model Engineer & Workshop › parts for drill press
  • #71186
    Old Timer
      @oldtimer90253
      Hi to you all, This is my first time on your forum, I am a wood-turner, but I have a progress number 1, drill ,that I have recently refurbished, I am missing one part, and I wondered if anyone could help, There should Be a Spring to lift the pulley cover to change the belt, but this is missing, could any one tell me if the manufacturers of my drill are still in business,or where I may purchase such a spring, the length of the spring, and also the O/D would be a useful starting place for the purchase, if you have such a drill, I would be most grateful for any information . many thanks OLD TIMER
      #38057
      Old Timer
        @oldtimer90253
        progress number one
        #71187
        David Colwill
          @davidcolwill19261
          If you can find details of the spring then there is a company in Nottingham called Kato Entex who will most likely have it in stock. You will need to know the diameter of the wire as well. I have in the past bought a range of springs around my best guess as they are not particularly expensive and they have a minimum order (£3-00 I think)
          #71188
          Old Timer
            @oldtimer90253
            Hi David, thanks for you info, as soon as I get the spring sizes I shall contact them, thank again
