Small Brushless Motors – can they generate?
Home › Forums › Electronics in the Workshop › Small Brushless Motors – can they generate?
Viewing 25 posts - 1 through 25 (of 68 total)
  • #366470
    Tim Stevens
      @timstevens64731
      Hello, me again
      I need a small generator – about the size of a bicycle dynamo – to be driven at up to 5000 rpm. The web is overflowing with drone and toy motors – and I wonder if I could use one to work 'in reverse' – generating a small output (AC, probably – this would be fine.) I can change wiring etc, if necessary.
      Regards, Tim Stevens
      #31966
      Tim Stevens
        @timstevens64731
        If driven, do they produce AC?
        #366476
        KWIL
          @kwil
          Yes Tim, I know one of the members of Malden & District ME uses 3 in his gas turbine powered locomotive.
          See  also https://www.youtube.com/watch?v=PwJ-Q-NfZg0
          Edited By KWIL on 09/08/2018 15:46:10
          #366482
            Just tried flipping a 4-wire stepper motor as used in a printer and it does make volts. I'd have to drive it with another motor and put the output into a load to see if it's efficient, but I don't see why it shouldn't be. As stepper motors are multi-pole the AC will be high frequency compared with an ordinary alternator, which might not be acceptable.
            Any motor with a permanent magnet should generate, not sure how well or for how long though. I tried spinning the motor out of a dishwasher pump with a hand-drill once and that lit a small lamp on the bench. I didn't investigate further.
            Well worth a try.
            John Rudd
              @johnrudd16576
              Tim,
              What voltage are you looking for?
              The kv of the motor will be determined by your requirements…..for example, a motor with a kv of 1000 will generate 1v when spun at 1000rpm. Other attributes of the motor have a bearing on how much current you want too….
              Edited By John Rudd on 09/08/2018 16:44:53
              #366492
              Jon Lawes
                @jonlawes51698
                If you want to keep it simple just use a bridge rectifier on two of the three output wires. It's not the most efficient way of doing it but its the most basic.
                If you don't mind making things very slightly more complicated then a 3 phase rectifier can be wired up, its very simple but not near as simple as option 1!
                Obviously this gives you unsmoothed DC, so depending on what you want to use it for you might want to add smoothing capacitors.
                #366493
                Joseph Noci 1
                  @josephnoci1
                  Tim, a brushless Rc type motor works very well as an alternator. In one of my big unmanned aircraft I use a 110cc twin boxxer engine and have fitted a large 220KV motor as alternator to power on-board electronics. The motor is about 70mm diameter and 90mm deep. At 5000RPM I get 18volts at 42amps max, and near 21volts at 5 amps.
                  Simple 3 phase bridge and a 1000uf capacitor gives very clean unregulated DC.
                  Not sure what voltage you require, but find a motor around 40mm to 50mm diametr, similar in length, divide the RPM by the desired voltage which will give you the KV motor that should be ok.
                  If you can indicate your required volts and amps, I can give better guidelines..
                  Joe
                  #366495
                  larry phelan 1
                    @larryphelan1
                    Dave,
                    Your ingenuity never fails to amaze me ! Only you could think up something like that !
                    Keep them coming !!
                    #366496
                    Tim Stevens
                      @timstevens64731
                      The application is to add a rev-counter to a vintage motorcar – an Essex of 1918, and six volt. What I need is a simple alternator driven by the engine (from the fan-drive pulley, perhaps) and the output will go to a voltmeter. The current needed is minimal, and the voltmeter can be chosen (or easily modified) to make the reading sensible. Of course, the scale will need redrawing, but that is easy, once we have run a test. So, ideally, a device where the voltage output (driving only a voltmeter) is proportional to rpm, and ideally, with ball bearings that should last long enough at perhaps 3000 miles per year. And the max revs of the Essex engine is about 3000 (yes it is that old) so there is no need for a device to run at F1 speeds.
                      Why not do it the old-fashioned way? Well, running a cable drive is complex, and long, and things get in the way. So, a drive using electrical wires is much easier and should waste less power.
                      My main concern is to know whether the switching circuitry of a drone motor is in the motor or separate, and from what you say the answer is separate, and so winding connections are accessible without destroying stuff.. So, I will invest and see how we go.
                      Thanks, everyone. Every question answered – wonderful.
                      Cheers, Tim
                      #366497
                      John Rudd
                        @johnrudd16576
                        Tim,
                        Given your criteria, it would seem a small 100 watt motor with a kv of 500- 600 would give you the required ac volts over the anticpated engine speed( for a voltage range of 0-5v if my maths is right…) ….generally brushless motors come without any electronics…. The three wires are brought out into 'the wide world'
                        Edited By John Rudd on 09/08/2018 17:40:52
                        #366500
                          Posted by Tim Stevens on 09/08/2018 17:27:44:
                          In that case I'd dump the fan driven alternator in favour of a Hall Effect or Optical Sensor. These sensors produce a voltage pulse each time they're triggered as the engine rotates. In the usual arrangement the pulses are counted and the rpm displayed on a digital display completely inappropriate for a vintage car.
                          However, you could dump the digital display and instead convert the pulses to a voltage level by integrating them with a capacitor. (The output voltage is proportional to the pulse rate. ) Simple circuit – if I can find the book, I'll post and example later.
                          A similar circuit uses a wire near the distributor input to inductively detect spark events. These also produce pulses at a rate proportional to rpm that can be integrated to drive an analogue voltmeter.
                          John Haine
                            @johnhaine32865
                            I don't think it's quite that simple is it Dave? If you just let the HE or opto device generate a pulse then the pulse width and rate are both inversely proportional to speed, so the average is constant. You need to allow each sensor pulse to trigger a constant width pulse T, so when you integrate those the average is proportional to rate up to the point where T is equal to the internal between sensor pulses. Still a simple circuit though.
                            #366512
                            Tim Stevens
                              @timstevens64731
                              Silly-old-duffer, John Haine
                              I'm not sure I understand your point(s) – I am looking at a device which moves wires through a (permanent, unchanging) magnetic field, or more likely, moves the field around the wires. Nothing is done with the output except supplying a (high resistance) voltmeter. So, doesn't Faraday's Law apply in any event, without creating pulses and then turning them back into a proportional output – the voltage from the alternator relating directly to the rate of cutting of lines of force? No generation of pulses, no average, no integration, and the only circuit is a few rectifiers and perhaps (but I doubt it) a smoothing capacitor.
                              And for the avoidance of doubt, yes, I know there will be a small non-linearity because of the diodes, but I'm sure we can take account of that in designing the scale for the voltmeter.
                              So, what am I missing, please?
                              Tim
                              #366514
                                Posted by John Haine on 09/08/2018 18:56:48:
                                Yes you're right John – it's not as easy as I first thought.
                                I found a circuit that fixes the problem with loads of discrete components – far too complicated for what it does.
                                Still looking, I half remember a simple circuit that uses an NE555 to generate constant width pulses from the input. All I have to do is find it in the muddle I call a study!
                                  Any ball raced DC motor will be fine the voltage required is tiny.
                                  My dad made an anemometer using an ordinary small DC motor and it worked for about 20 years, with nothing more clever than a variable resistor to calibrate it.
                                  Using two wires of a brushless motor will be fine.
                                  Use a 50mV or 100mv fsd meter movement and you won't be short of volts.
                                    Posted by Tim Stevens on 09/08/2018 19:42:37:
                                    Tim
                                    Hi Tim,
                                    We're discussing a simpler way of generating the rpm voltage that doesn't need the car to drive an alternator. The advantage is elimination of the need for a £ brushless motor and belt drive. Nothing wrong with your idea apart from there may be a cheaper easier alternative
                                    At it's simplest, when a stream of DC pulses are used to charge a capacitor through a resistor (Vin) , the DC voltage across the capacitor at Vout is proportional to the pulse rate.
                                    So if a sensor is arranged to emit a pulse on each rotation of your cars flywheel, then the pulse rate will be low when the engine is idling and the capacitor will only partially charge causing the voltmeter to read low. When the engine is accelerated the pulse rate increases, causing the capacitor to collect more charge. Then the voltmeter reads a higher voltage.
                                    As the voltage appearing across the capacitor is proportional to engine rpm, the voltmeter can be calibrated directly in rpm.
                                    John's pointed out it's not quite that simple because the input pulses all need to be the same width. That's achieved with some simple electronics. At least I think it is! I'm hoping to find a tested circuit rather than design one from scratch.
                                    Jeff Dayman
                                      @jeffdayman43397
                                      +1 on Neil's suggestion of an ordinary permanent magnet DC motor with decent bearings for this RPM sensing job. One out of a toy car or even a hair dryer made in the last ten years is probably made by Johnson in China and will probably work for a very long time. Connect it to a suitable DC voltmeter, make a new scale background for it displaying rpm, and there's your tach.
                                      You may be able to find an old style bicycle generator driven off the bike tire – the old style of these make a DC output varying with speed.
                                      I would not go for complex circuitry or high tech brushless motors for this job, you do not want your leisure time in the Essex car cut short by troubleshooting high tech circuits and over-complicated gadgetry gone Tango Uniform.
                                      #366540
                                      Nick Clarke 3
                                        @nickclarke3
                                        Posted by Jeff Dayman on 09/08/2018 20:36:31:
                                        I used to get pupils in O level and A level Physics classes to connect a bike dynamo to an oscilloscope when showing them how to use a scope – the output is AC and roughly (VERY roughly!!) sinusoidal not DC. The faster you spin it the higher the frequency of the output obviously.
                                        #366544
                                        Ian P
                                          @ianp
                                          As Jeff suggests almost any small PM motor will do the job (generate a voltage to drive an indicator). I would suggest looking at the meter/display end of the system and see what you need to drive that.
                                          If you use a moving coil meter it will have a FSD of milliamps at most (robust ones used in car dashboards before the introduction of digital a stepper motor driven displays were about 10 or 20mA FSD). Even the smallest motors will require a series resistor to reduce its output and not burn out the meter coil.
                                          If there is a requirement to conceal the motor (its a 'Tacho Generator' in this application) you could recess a small motor in the cavity bored into the end of some convenient rotating engine part. Even a motor out of a cellphone vibrator (4mm diameter) would have enough weft to drive a meter. Certainly no need for a motor anyway near the size you were considering and the only advantage of a stepper or brushless motor would be the elimination of brushes, in practice even a cheaply made brushed motor would last a lifetime as its doing virtually no work.
                                          Ian P
                                          #366549
                                          duncan webster 1
                                            @duncanwebster1
                                            Posted by SillyOldDuffer on 09/08/2018 19:50:20:
                                            wire the 555 as a monostable triggered by the Hall effect, then you get a mean voltage proportional to speed, no need for capacitors, the meter can't move that quickly so it smooths it out for you.
                                            See **LINK**
                                            for more info. Set the pulse length so that at max engine revs there is still a small space between, then have a series resistor to calibrate the meter
                                            Edited By duncan webster on 09/08/2018 22:29:16
                                            #366561
                                              Must it be an analog gauge to fit in with the original decor, or could the owner tolerate a digital display?
                                              For about $10 on the net you can buy a little digital tacho display unit the size of a matchbox that is triggered off a wire wrapped around one sparkplug lead. It runs off its own internal AA battery so no problem with a 6v car system etc. There are probably analog units out there that operate the same way too.
                                              Edited By Hopper on 10/08/2018 02:29:41
                                              #366565
                                              Joseph Noci 1
                                                @josephnoci1
                                                Tim, apologies for my diatribe on the big alternator in my unmanned aircraft – that obviously was not applicable to your request at all, but I suppose if you do not give enough info in the initial request as to your intended application, anything goes…
                                                As many have said, a small DC motor is the simplest, easiest and most trouble free for your needs – there are some with ball bearings – Ebay, Banggood, etc..
                                                Sorry..
                                                Joe
                                                Edited By Joseph Noci 1 on 10/08/2018 07:21:46
                                                #366569
                                                I.M. OUTAHERE
                                                  @i-m-outahere
                                                  There is a  recent video on the great scott channel  on youtube where  he tested the efficiency of , stepper, brushless and brushed motors as generators .
                                                  Tried to embed the video here but was couldn't get it to work , i will have to search on the forum as im sure the answer is there .
                                                  Edited By XD 351 on 10/08/2018 09:21:22
                                                  Edited By XD 351 on 10/08/2018 09:22:24
                                                  #366571
                                                  Les Jones 1
                                                    @lesjones1
                                                    You could use ignition pulses taken from the contact breaker and feed them into a frequency to voltage converter IC (Such as an LM2917) and connect the output from that to your voltmeter.
                                                    Les.
                                                    #366589
                                                    I.M. OUTAHERE
                                                      @i-m-outahere
                                                      Is the output of a generator or alternator purely linear in relation to the rpm ? Probably not .
                                                      I think Les has hit the nail on the head , you could also use an inductive pick up off the coil lead to drive it either way a wire is easy to hide , the only glitch i see is scaling and this would depend on how accurate you want the tacho to be .
                                                      With such a car wouldn't you want the least conspicuous fit out ? Does it have a generator on it ? If so does the generator have a cooling fan or impeller ? If yes could you use a proximity sensor to pick up the fan / impeller blades ?
                                                      I wonder how one would go using a micro to convert a voltage derived from a frequency to voltage converter to a pwm and drive the meter from that ? May help to make the meter reading track the rpm better .
                                                      Edited By XD 351 on 10/08/2018 10:32:25
