Hemingway Myford Saddle Stop kit
Home Forums Work In Progress and completed items Hemingway Myford Saddle Stop kit
Viewing 25 posts - 1 through 25 (of 26 total)
  • #31322
    Jonathan Blake
      @jonathanblake46754
      #502264
      Jonathan Blake
        @jonathanblake46754
        Hi
        Has anyone made and installed the Hemmingway multi position saddle stop kit on their Myford 7. I'm fairly new to model engineering and am having difficulty understanding the plans. In particular the main block needs to be split in a couple of places but I'm not sure where. Has anyone got any photos of the build or final product which would give me a clue?
        I've phoned and emailed Hemingway but they haven't answered.
        Any help would be much appreciated..
        Many thanks – Jonathan.
        #502267
        bernard towers
          @bernardtowers37738
          Hello Jonathan, I will dig mine out and send photos if you give me an hour or two. It’s a really good piece of kit.
          #502268
          Baz
            @baz89810
            Have made a couple of them, PM me and I will send pics etc. Would upload them here but is a bit beyond my abilities.
            #502279
              Have you got a photo of the casting – the Hemmingway site only shows the end result.
              #502289
              Jonathan Blake
                @jonathanblake46754
                img_20201020_144922905.jpgThanks for the rapid response folks.
                #502290
                bernard towers
                  @bernardtowers37738
                  cecd318d-5c33-49a2-8440-b4e7d428dbca.jpegaeb4e81a-5e1a-4101-9dd7-cf68ef8c62e0.jpeg9eeb4773-b10c-4a85-abbc-5f2be13818a9.jpeg59353935-fbe0-4c60-9d76-7ffd91b46d40.jpeg3ded9756-50dc-4438-b983-ab54b9f5448f.jpeg
                  #502291
                  bernard towers
                    @bernardtowers37738
                    Hope the images are helpful, not sure about slits but there is a t slot at the rear. I did not have a casting mine is from a block of black steel
                    #502293
                    Sam Longley 1
                      @samlongley1
                      just occurred to me —I have a brand new un used Myford stop unit for sale if anyone wants to Pm me
                      Edited By Sam Longley 1 on 20/10/2020 15:24:01
                      #502454
                      Jonathan Blake
                        @jonathanblake46754
                        Thanks Bernard. The photos are really helpful. I understand now that the slits in the drawing are showing the cuts of the Saddle and Guide rail clamps although in your version you haven't split the Saddle clamp. Is that correct?
                        Also I understand that when you use the stop you clamp the stop block to the guide rail, but how is the saddle clamp used? Is it just clamped in place when you are setting upand then release during operation?
                        Thanks again – Jonathan
                        #502458
                        Baz
                          @baz89810
                          My personal opinion is that the saddle clamp is unnecessary, Myford provided a perfectly good one on the back of the saddle.
                          #502460
                          Jonathan Blake
                            @jonathanblake46754
                            Good point Baz. That saves some machining as well.
                            #502461
                            Jonathan Blake
                              @jonathanblake46754
                              I found another thread on the forum which explains some changes which allows the kit to be used with a cross feed. It involves reducing the width of the rail so the saddle can slide over it. Has anyone tried this approach?
                              #502469
                              Martin Kyte
                                @martinkyte99762
                                Posted by Jonathan Blake on 21/10/2020 12:16:12:
                                No but I should like the details.
                                regards Martin
                                #502472
                                Jonathan Blake
                                  @jonathanblake46754
                                  #502474
                                    The brass clamp (split cotter) does need to be split, one half is threaded and the other half clearance. Then tightening the screw pulls them together clamping the bar from both sides which is better than a simpler cotter that only clamps against one side.
                                    #502484
                                    Frank Gorse
                                      @frankgorse
                                      It’s a nice project but if you want something that does the job for a fraction of the work there’s one in ‘The Amateur’s Lathe’ by LH Sparey. His only provides one length stop but it’s a simple enough modification. I fully agree with Baz,by the way,that the place for a saddle lock is at the saddle.
                                      #502494
                                        I think the saddle clamp part is 'mission creep' or adding a feature for added 'value' like those electrically operated slide out computer cup holders.
                                        Challenge: think of another feature to add.
                                        My offer for this is a flip down 5 thou shim that makes the stop stop short until the final cut when you take it out and clean up the face to dimension.
                                        #502502
                                        Martin Kyte
                                          @martinkyte99762
                                          I did buy this from Myfords at a show a few years back. It does not do a great range of length but for small parts up the chuck end it works well in conjunction with a chuck backstop. The device makes use of existing tapped holes so no modification of the lathe required. Don't know if they still have any, maybe worth an eMail.
                                          regards Martin
                                          #502521
                                          Baz
                                            @baz89810
                                            Martin, I much prefer a stop on the left hand side, if you had different length screws you could possibly get a greater range of lengths, the Hemmingway version is only any good for a couple of inches and the big downside of it is that you cannot wind the saddle towards the tailstock, the clamping block being on the right hand side of the apron limits this so it is impossible to get say a boring tool far enough away for you to be able to measure a hole.
                                            #502525
                                            Martin Kyte
                                              @martinkyte99762
                                              Actually Baz my issue with it was the screws were too long. I was turning pivots on clock arbors with the material in a Myford collet so the tool tip needed to be very near the spindle nose. The screws shown could only be wound in until they touched the mounting block. My solution as I was reluctant to cut down the nicely blacked screws was remove them all and intsall a cap head screw in one of the positions screwed right in. That gave me a dead stop with the top slide adjusting for exact length.
                                              The Myford boys were just playing around with an idea and made a few up for the show.
                                              I have never really missed not having a saddle stop until I bought this one but I can see it is handy now and again.
                                              I do have Graham Meeks Saddle handwheel which I find a great help.
                                              I guess it makes it even less likely that I will modify my Hemmingway kit but you never know.
                                              regards Martin
                                              #602542
                                              Neil Lickfold
                                                @neillickfold44316
                                                Posted by Martin Kyte on 21/10/2020 15:14:07:
                                                regards Martin
                                                Did you have to drill and tap any holes for this to fit onto your machine? Where the stop block is on the LH side by the gear box, there is a screw in there for my lathe. I am assuming it is for the alignment of the head stock to the bed. Does that set screw come out and then the block mounts through that threaded hole?
                                                On the rotating stop side attached to the saddle, does it use the top plate holes in the top cover?
                                                Thanks, Neil Lickfold
                                                #612647
                                                Former Member
                                                  @formermember96632
                                                  #612708
                                                  bernard towers
                                                    @bernardtowers37738
                                                    My Hemingway one is good for at least 6 inches and I don’t have trouble with the handwheel
                                                    #612715
                                                    Dave Wootton
                                                      @davewootton
                                                      I built the Hemingway one years ago to fit a very late ML7 only to find that the saddle will not traverse over the part that has to be fitted to the front of the lathe bed. So on some ML7's it will limit the travel and will need removing before the saddle can be traversed the full length of the bed, I did email Hemingway and they admitted that this happened on some later ML7's, with some glib comment about how useful I would find it anyway! There has never been a note put on the website to this effect, and I know from a previous forum post others have found the same. I was fortunate and sold mine to a friend and it fitted his S7 perfectly, but was still annoyed at the time wasted building something that didn't do what I needed. I think this is what ar ys means in his post.
