Bench block for small parts – ice hockey puck
Home › Forums › Hints And Tips for model engineers › Bench block for small parts – ice hockey puck
  • #429047
    Robert Atkinson 2
      @robertatkinson2
      I thought this was well known, but have found no reference on here so I'll give this tip. Ice hockey pucks are cheap, a handy size and made from hard rubber. They make great bench blocks when hand filing or fitting small parts. Enough friction to stop the work piece moving, but won't damage surfaces (or tools if ou do slip. can be easily drilled, V slot cut or similar to locate parts. Also firm enough for backing up when driving small pins or collars etc. The rubber has filler and is quite "dead" so no bounce.
      Put one no the cup of your trolley jack to stop slipping and damage.
      They can be bought on ebay or Amazon as well as sporting goods stores. I tend to buy a few when I visit North America to save postage.
      Robert G8RPI
      #30719
      Robert Atkinson 2
        @robertatkinson2
        Cheap product with many uses
        #429052
        ega
          @ega
          I wonder whether, with a suitable slot, they would be heavy enough to make a stand for a mobile phone?
          #429057
          Robert Atkinson 2
            @robertatkinson2
            Plenty heavy enough to support a phone.
            I do understand the urge to hit a "smart" phone with hammer but don't see why you need a holder to do itdevil
            #429106
              How machineable are they? Say if one needed something like a big pipe adaptor or a bung. Big BSP fittings are expensive.
              #429149
              OuBallie
                @ouballie
                Been using them for years.
                Geoff – Hadn't thought of using one for phone support 👍
                #429165
                Massimo Dalmonte
                  @massimodalmonte45801
                  Hi Robert G8RPI,
                  soon after reading your post, I bought 6 (4 of them will be used to make levelling feet for my milling machine) smiley.
                  Cheers,
                  Massimo
                  #429798
                  David Banham 1
                    @davidbanham1
                    The Toronto Society of Model Engineers web site resources page http://www.tsme.ca/resources has a Tips section.
                    The May2019 page has a tips sheet covering three items:
                    – Materials to validate CNC machining
                    – The good old hockey puck
                    – A very short rule
                    The use of a hockey puck for various activities in the workshop is discussed.
                    #429914
                      Wow … I hadn't realised how economically priced they can be: **LINK**
                      Donovan Kaardal
                        @donovankaardal43990
                        Hockey pucks are great – and they machine beautifully. I'm making some feet for my surface grinder right now.
                        #495298
                          Posted by Michael Gilligan on 21/09/2019 20:40:20:
                          I’ve just re-visited this thread, and that ^^^ link … which had some very negative reviews !!
                          Thus demonstrating … “if it seems too good to be true; it probably is”
                          Thor 🇳🇴
                            @thor
                            I used hockey pucks to make levelling feet for my lathe several years ago. Here is a photo of I took during the fabrication (not yet finished):
                            The pucks are easy to machine and has served me well for many years.
                            Thor
                            #495305
                            Raymond Anderson
                              @raymondanderson34407
                              Sacrilege…. Hockey pucks are for HOCKEY. only joking, fine to see they have a few other uses in addition to their main purpose. Another area at which the little buggers really excel at is… demolishing parts of the human body. [ been there ] smiley
                              #495306
                              Nick Wheeler
                                @nickwheeler
                                Screwed to a chunk of motorcycle tyre, they make good silencers for small bells. The good thing about this method is that the silencer does not have to be removed, just rotated around the ball of the clapper. Particularly handy for cramped bellfries with poor access
                                #495334
                                john halfpenny
                                  @johnhalfpenny52803
                                  I have use them for years as jack packers on my car lift and trolley jack (in a sensible and appropriate manner)
                                  #495579
                                  Georgineer
                                    @georgineer
                                    Posted by Nicholas Wheeler 1 on 11/09/2020 17:21:57:
                                    Nick, can you explain this a bit more, please? I've used the traditional leather buffer for half-muffling tower bells (tenor 17 cwt) but can't visualise the setup you are describing and whether it would do the same job.
                                    George B.
                                    #495586
                                    Nick Wheeler
                                      @nickwheeler
                                      Posted by Georgineer on 13/09/2020 12:43:49:
                                      George B.
                                      George, this is to completely silence the bell for training and/or use with a simulator, it does not replace leather muffles. This LINK shows how the tyres are used; we've just added the pucks for durability as after three years use on light bells the tyres are rather, er, tyred.
                                      Heavy bells are best sillenced in traditional ways, either by tying the clapper, or fitted wooden blocks. Your tenor suggests that this would be your best option
                                      #495597
                                      Nick Wheeler
                                        @nickwheeler
                                        I remembered I had this pic of a finished silencer
                                        you can just see the cross cut into the tread, which fits tightly over the flight of the clapper. Once fitted, it's simply rotated to bring it into/out of use. This is a ring of 6 with a 6cwt tenor and access is poor, so going from open to silenced with just a twist of the silencer is a real boon
                                        #495643
                                        Georgineer
                                          @georgineer
                                          Thanks Nick, that's much clearer. For single silent practice we have a wooden stay which clamps round the clapper and holds it central, but that changes the handling of the bell. Your idea could be ideal for one of the lighter bells.
                                          George B.
                                          #495655
                                          Nick Wheeler
                                            @nickwheeler
                                            Posted by Georgineer on 13/09/2020 20:35:41:
                                            George B.
                                            I should point out, that the only part of it that was my idea was how to attach the pucks. And you're right, stationary clappers on small bells does change the handling. That is how we do ours, but they're much bigger.
