Pendent control box for a VFD
Home Forums General Questions Pendent control box for a VFD
  • #404739
    Andrew Tinsley
      @andrewtinsley63637
      I need to make 4 or more pendents for various VFDs, with the usual controls. Stop, start plus forward and reverse and jog. Not forgetting the usual pot for speed control.
      Looking around for suitable switches gave me a severe pain in the wallet! Can anyone suggest a source of suitable switches that don't cost an arm and a leg.
      #26552
      Andrew Tinsley
        @andrewtinsley63637
        Pendent controls for aVFD
        #404746
        Ex contributor
          @mgnbuk
          https://www.ebay.co.uk/sch/Pushbutton-Switches/58166/i.html?_from=R40&_sop=15&_nkw=22mm+pushbutton
          A quick search on Ebay using "22mm push button" came up with quite a few options from under £2 each delivered (from China). Change the search term to "16mm" if you want more compact switches.
          Nigel B
          #404751
          Andrew Tinsley
            @andrewtinsley63637
            Thanks Nigel,
            An Ebay search didn't throw up those options, only some eye wateringly expensive equivalents!
            Andrew.
            #404752
            Cabinet Enforcer
              @cabinetenforcer
              I used chint actuators and contactors on my vfd install, though for some reason they are currently astronomically priced on eBay, other suppliers on Google look more normal.
              About 4gbp per button or so, they have a nice heft to them, and I liked how I could have a guard ring on the start button, but not on the stop control, small details like that adds a nice polish I think.
              #404760
              Clive Brown 1
                @clivebrown1
                I bought the switches, potentiometer etc for my pendant from Inverter Drive Supermarket. They stock a complete range of components, apart from a housing, and at very modest cost.
                #404763
                  Posted by Andrew Tinsley on 12/04/2019 12:45:44:
                  The cost might depend on your definition of 'suitable'.
                  The pricey sort sold by RS are the better types, including goodies such as IP ratings suitable for a hostile environment. Those sold by Inverter Drive Supermarket look to be down a notch, ie not suitable for wet work, but should be fine in a workshop where the controls are away from coolants etc.
                  Bought some cheap switches from ebay last year that have been OK for light occasional use. I doubt they'll last forever though and they look and feel cheap! Are your customers fuss-pots?
                  Mike Poole
                    @mikepoole82104
                    Telemecanique are my preferred supplier of control components, I think the Harmony buttons are excellent and worth the cost. They are extremely reliable and very suitable for the workshop environment. Not the cheapest but in my opinion they are the best.
                    #404816
                    Stuart Smith 5
                      @stuartsmith5
                      You might find something suitable here:
                      they are usually cheaper than rs.
                      #404956
                      HughE
                        @hughe
                        Cheap switches are false economy in my opinion. Over the last few years I have had to replace many on my equipment, mainly due to the plastic going brittle. I agree with Mike Poole's recommendation on make. CPC or Rapid are my first choice for these items. Only if I need them next day do I use RS or Farnell.
                        Definitely go for a protected start button variety. Also one with the correct IP rating if used in a location that is exposed to dust or liquid.
                        Hugh
                        Edited By HughE on 13/04/2019 21:57:02
                        #404959
                        Andrew Tinsley
                          @andrewtinsley63637
                          Thanks gentlemen,
                          I have now sourced some reasonable quality switches without breaking the bank. The expensive variety which were cheap and nasty were indeed a shock. But as usual good advice was given on this forum.
                          Andrew.
