Bit of a tendency to jump to the conclusion that cheap / Chinese calipers eat batteries. I think it's true only some of the time. As NDIY hints you also need to consider the batteries themselves, for example:
- All things being equal SR-types have higher capacity and better shelf-life than LR types
- Cells have a limited shelf-life, which assumes room temperature
- The quantity of chemicals loaded into a cell by the maker isn't standardised. Cheap cells are likely to contain less energy than expensive ones
- Cells made using pure chemicals have more capacity and a much better shelf life than cells made from impure chemicals
When you buy cells, have a good look at the best-before date. This isn't the date at which the cell suddenly fails, its the point at which internal degradation becomes noticeable. Cells should be consumed well before the best-before date, don't expect much from old batteries.
Unfortunately it gets worse. Cells are often mis-sold, for example by repackaging genuine but out-of-date cells, or by packaging inferior cells with a counterfeit brand-name. For that reason, check the packaging and be suspicious of bargains.
Also bear in mind that a cheap digital caliper is unlikely to come fitted with a top-quality cell. More likely it's a low-capacity variant with a short life. Don't be surprised if the first cell doesn't last long.
Finally, beware cold damp workshops. They are unkind to batteries.
Edited By SillyOldDuffer on 23/01/2018 14:20:21
