Tig
Tig
Home › Forums › General Questions › Tig
  • #322155
    Andy Sproule
      @andysproule22368
      Hi,was wondering if anyone has a Thermal arc 175 or a Parweld XTS 162 DV.I have tig torch gas a so on,it’s only for hobby work.Any opinions?Or maybe recommend a machine in roughly the same price range.
      #25574
      Andy Sproule
        @andysproule22368
        #322190
        Michael Briggs
          @michaelbriggs82422
          Hello Andy, I have a Thermal Arc 175TE. Before that I had a lift start tig and had no end of problems with tungsten contamination on lifting the electrode. It may have been my fault due to inexperience but HF start solved my problems.
          #322192
          Carl Wilson 4
            @carlwilson4
            I have an RTECH ac/dc pulse unit. They do dc only machines too similar price to the ones you mention.
            I’ve had mine 5 years with no trouble and it has done all I’ve asked of it.
            Definitely need hf start with tig.
            Doubleboost on YouTube uses RTECH gear and he has done a lot of good reviews, if you search the net.
            #322202
            Ady1
              @ady1
              Whats that?
              Dodged a Lidl Tig welder recently, stayed with inverter/rods
              Edited By Ady1 on 19/10/2017 00:20:07
              #322204
              Ady1
                @ady1
                Arc Pig
                uuhhh
                #322205
                David Standing 1
                  @davidstanding1
                  Posted by Ady1 on 19/10/2017 00:26:47:
                  Arc Pig
                  uuhhh
                  Best FAQ I have ever seen laugh
                  #322215
                  Involute Curve
                    @involutecurve
                    I'm told Thermal Arc and Parweld are made in the same factory, I have two Parweld AC DC Tig sets, (I inherited one or em) after five years one of em started to give some trouble with unstable Arc etc, this was two years out of warranty so sent it back for repair, it came back less than a week later fixed FOC, all it cost me was postage in one direction.
                    #322239
                    Carl Wilson 4
                      @carlwilson4
                      Hf start is high frequency start. A high frequency current is fed to the torch (usually by means of a device similar to a current transformer)
                      This high frequency starts the arc without the need to touch the tungsten in the torch to the work; so called lift or scratch start.
                      Scratch/lift start runs the risk of giving a tungsten inclusion in the weld. Hf start obviates this.
                      Edited By Carl Wilson 4 on 19/10/2017 10:25:17
                      #322241
                      pgk pgk
                        @pgkpgk17461
                        I noticed that screwfix are doing a special on welders at the mo' with big discounts. I can't comment on quality but at least with screwfix if it's dud gear they've always been good with taking it back for a refund.
                        #322250
                        Andy Sproule
                          @andysproule22368
                          Thank you for replies.The thermal arc goes to 5 amp the pastels to 20 any thoughts on this?
                          #322251
                          Andy Sproule
                            @andysproule22368
                            Should be Parweld.
                            #322259
                            Muzzer
                              @muzzer
                              Not a brand I'm familiar with but the Screwfix Impax 160A TIG welder for £330 inc vat sounds pretty good. It even comes with a foot pedal.
                              #322264
                              Hillclimber
                                @hillclimber
                                I use a little DC R-Tech, which works well.
                                I cant see the control panel of the Screwfix machine to see what functions it has, and no sign of a gas regulator. But the price is VERY attractive, and it includes a pedal.
                                But 2nd the idea that you really DO want HFS – forget the scratch start.
                                #322267
                                Carl Wilson 4
                                  @carlwilson4
                                  That one from screwfix looks quite good. Dc only but if that’s OK for you then fine. I think it has Hf start because it says hf in the description or product name.
