Centec2 Milling Machine
Home Forums General Questions Centec2 Milling Machine
  • #280598
    Brian Pritchard
      @brianpritchard66881
      I have a Centec 2 milling machine. There is no mechanism for raising the table apart from the lever at the rear or by turning the bolts that lock the height. Can anyone tell me how the machine was originally fitted?
      Brian
      #25046
      Brian Pritchard
        #280615
        mark smith 20
          @marksmith20
          Hi Dont know much about Centecs, but i assume you mean like at the bottom of this page link which shows a machine badged /sold as a `Granville`.
          This older centec for sale at GM also has the lever ratchet .
          http://www.gandmtools.co.uk/shop/centec-2-horizontal-milling-machine-cabinet-stand-1ph-80202694/
          Edited By mark smith 20 on 27/01/2017 16:35:17
          #280670
          Brian Pritchard
            Thanks for that, Mark,
            Brian
            #280671
            Dave Halford
              @davehalford22513
              Centec2's are a bit basic, you'll note on the GM link someone has fitted a cheapy digital readout to use the bolts that lock the height.
              Many have been modified with various forms of screw jacks under the knee. yours is clearly original.
              On the plus side gearing via belts is nice and quiet.
              #280684
              Nicholas Farr
                @nicholasfarr14254
                Hi Brian, Dave is right, the Centec 2 is the first model of the breed and is basic. If your one looks like the two photos below, then that's what you have.
                The lever on the back turns a cam, which lifts and lowers the knee.
                Regards Nick.
                #280709
                  Nick is right about that particular 'breed' – the ones with a removable overarm – which could be replaced by a vertical head (hence the pulley on the back of the machine). The predecessor, the Centec, had a fixed overarm -so was only a horizontal mill.
                  They clearly had not thought about progressing the original design or they would have called it the Centec1.
                  #280768
                  Brian Pritchard
                    Thank you Nick and Dave. My machine does have the jack, I assumed it originally had a better system.
