Forward & reverse wiring
Home Forums General Questions Forward & reverse wiring
  • #22671
    Robonthemoor
      @robonthemoor
      Robonthemoor
        @robonthemoor
        My myford super 7 lathe single phase, go's in reverse when in the forward position? Can any one help with this problem, my Electrition says he would like more info before he looks at it.
        #122429
        roy entwistle
          @royentwistle24699
          What does it do in reverse position
          #122433
          Lambton
            @lambton
            Does the lathe have a Dewhurst switch?
            #122439
            Speedy Builder5
              @speedybuilder5
              Change the label – Rev/Fwd? Or did you mean that it goes in rev in both positions. Could it be that the handle spindle is screwed into the wrong side of the rotor shaft ?
              BobH
              #122451
              Robonthemoor
                @robonthemoor
                The switch is a dewhurst & partner ltd hounslow, type A
                in forward position it reveres
                in reverse position it runs forward
                but on a rethink" off is at the back & the switch can't go round to that position so maybe that's the way it works, with the back off the lever pointing at the word.
                #122460
                Robbo
                  @robbo
                  The straight lever on the Dewhurst switch should screw right through the spindle, and the end that does so has a point on it – this points to the desired direction, and will also point to off.
                  UNLESS the switch has the shortened form of lever,in which the knob sticks up at an angle and is brazed to a collar that fits over the spindle. The same theory applies, but there is no pointer, but the knob faces the "wrong direction" and the back of the spindle faces the selected direction or off.
                  If you want the knob to face the selected direction, just unscrew the straight lever and put it back the other way, or take off the short lever and replace it the other way – you will find a grub screw at the back of the collar, which secures it.
                  Phil
                  Edited By Robbo on 16/06/2013 23:17:13
                  #122462
                  Robonthemoor
                    @robonthemoor
                    Spot on" sorted .
                    thank guys
