Copper Tube Find
Copper Tube Find
Home › Forums › General Questions › Copper Tube Find
  • #22073
    Kevin Bennett
      @kevinbennett25223
      #88884
      Kevin Bennett
        @kevinbennett25223
        Hi all a question i have found a bit of copper tube in my farther in Laws Garage and was interested to know what is was used for as i cannot find any reference to this this size or why my late farther in law had it stored for the last 40 years.
        The size is 2" 3/4 OD and is about 1.2 mm and 9 feet long
        The key question is is it just scrap and i cash in or is it good to make copper boilers and advertise it in cut lengths'
        Thanks Kevin
        #88887
        Springbok
          @springbok
          Hi Kevin
          There is a major question, in your father in law's garage find is the copper tube got a seam running down it if so no good for boiler material. If it ihas this do not sell it for scrap as I am sure that a few of the traction and 7.25g builders will snap your arm off for chimney material. I hate to see good metal going to a scrappy.
          Good luck
          Bob.
          #88890
          Kevin Bennett
            @kevinbennett25223
            Hi Bob i cannot see any seam running down it but in the morning in some good light i will clean a section to have a closer look.
            thanks Kevin
            #88907
            David Haynes
              @davidhaynes53962
              Hi Kevin,
              I am currently trying to source a short piece of 2 5/8" dia x 16g copper tube for a boiler. Your tube is 18g thick which is given as an alternative thickness on the drawing I am working to; fine, but for the 1/8" oversize to what I need! Good luck in finding a boiler builder or otherwise who can use it!
              Sub Mandrel
                @submandrel
                Hi Kevin
                That's a good size for small boilers witha single flue from 15mm water pipe.
                Would you be interested in selling off short sections?
                Kevin Bennett
                  @kevinbennett25223
                  Hi Neil yes send me a pm and lets chat
                  Thanks kevin
                  #88994
                  VC
                    @vc44480
                    Hi Kevin
                    Wish I had known you a year ago…
                    Just the right size for the Paxman traction 1-1/2 boiler, so with 9 feet you could make your own fleet of the little buggers..
                    #88999
                    Kevin Bennett
                      @kevinbennett25223
                      i have cleaned the end of the copper and it has no seams. has anyone got any ideas of cost to sell it as i have no idea all i know copper has a high price.
                      Thanks Kevin
                      #89004
                      Keith Long
                        @keithlong89920
                        Hi Kevin
                        I just did a bit of googling for "scrap price, copper, uk" and came up with a figure of about £4.75/kg. Might be regional variation and changes day to day or possibly even quicker!
                        Worth having a bit of a play to see what prices you can find.
                        Keith
                        Edited By Keith Long on 12/04/2012 21:33:18
