help 2
help 2
Viewing 25 posts - 1 through 25 (of 28 total)
  • #195539
    Danny Hegh
      @dannyhegh44921
      I don't know if this is the right place to air this problem but it is the last resort!!!
      I have subscribed to a magazine 3d create and print, I thought that it would be a good way of learning the art of 3d printing , magazine required me to download sketchupmake programme , I can not do this as I have malware loaded on to my computer (twice) I have to do a factory reset twice , I have been to sketchupmake and to the publishers to no avail, can any one help with this
      #21184
      Danny Hegh
        @dannyhegh44921
        Sketchup
        #195542
          Danny,
          That's rather worrying
          Are you downloading directly from the Trimble SketchUp website ?
          Danny Hegh
            @dannyhegh44921
            michaelg
            yes the second time I was , same result
            #195550
            Danny Hegh
              @dannyhegh44921
              I got my emial returned from the magazine and I could get any sense from the forums at sketchup and nothing at all from sketchup themselves
              #195553
              Peter G. Shaw
                @peterg-shaw75338
                Hi,
                What I'd suggest as a first step is to register with The Motley Fool, UK (www.fool.co.uk), and then ask for help in cleaning your machine via this forum "Computer, Help With This Blasted". There are some very knowledgeable people on that board. It will probably mean doing something like getting into Safe mode, then downloading and running Malwarebytes or similar to clean your computer. Once cleaned, you will be advised to use a good anti-virus and firewall of which there a few free versions available for home use.
                Don't be put off by the fact that this is a financial site, just navigate via Boards, Boards Help & Guides, Boards A-Z and then step down the listing to Computer, Help With This Blasted where you will be able to post your question after you have registered. You will need pseudonym to register, and when posting your question, it will be helpful to provide details such as computer type, make, etc, Windows version, any anti-virus etc plus what is happening.
                I would also suggest that once clean, you should perhaps try downloading SketchUp from a different site. I don't know where, but I'm reasonably sure there will be one somewhere.
                I assume, by the way, that you are using a PC and a version of Windows.
                Best of luck,
                Peter G. Shaw
                #195563
                RJW
                  @rjw
                  Danny, I've just downloaded the software and the site didn't flag up any problems, I also scanned the .exe file and it was clean, perhaps you've picked up something previously that's infecting programme files!
                  If your 'system reset' was by using 'system restore' (assuming you're using windows), then an infection could well be in your restore files, they'll just keep perpetuating everytime you install them!
                  Periodically when my computer has enjoyed a few problem free re-boots, I delete all the restore points and set a new one, they take up a huge amount of storage space anyway!
                  As others have suggested, use an antimalware programme to scan and clean your pc, Malwarebytes Antimalware, and Superantispyware are free, they've been around a long time and well worth having!
                  Would also be worth installing and running a rootkit scanner, plenty of good freebies out there!
                  John.
                  #195564
                  Danny Hegh
                    @dannyhegh44921
                    Thanks Peter for your advice Iwill try that
                    Danny
                    #195565
                    Lambton
                      @lambton
                      RJW,
                      Not a criticism in any way but why do you end every sentence with an exclamation mark?
                      #195566
                      Danny Hegh
                        @dannyhegh44921
                        Thanks too ,Steam ships ,diesel engines are ok, ask me to machine a thing agme wigit yes!! but these computers are hard to get my slow old brain around
                        Danny
                        #195569
                        Danny Hegh
                          @dannyhegh44921
                          rjw
                          You should count them
                          #195578
                          RJW
                            @rjw
                            Actually Danny, I just have and it’s even stevens, ‘5 all’ to us both by my reckoning, and I see no reason why my exclamation marks should be singled out for criticism when yours are not, at least I used single units where yours were multiple!
                            Lambton, I think you need to get out more and get a life if all you have to do is pick holes in postings made by others who have spent their valuable time trying to help others, I at least offered help and advice, where so far, you’ve offered bugger all except criticism, and yes it was! (Exclamation mark)!
                            #195584
                            Lambton
                              @lambton
                              RJW,
                              Why so vitriolic? Obviously I have inadvertently hit a sensitive spot which provoked your quite rude response.
                              As I stated in my post no criticism in anyway. I am just curious what you trying to show by using an exclamation mark at the end of each sentence.
                              #195586
                              John Stevenson 1
                                @johnstevenson1
                                #195590
                                RJW
                                  @rjw
                                  Lambton, Not vitriolic at all, just to the point, I personally have far better things to do in my life than waste it by picking holes in postings made by other members, and I certainly wouldn’t attempt to embarrass them on forum by doing so as you did, I simply made the point that perhaps you should have more important things in your life too!
                                  Why did I use exclamation marks, I should have I was thought it obvious, perhaps you should also ask the OP why he did so too …. and why in duplicate and triplicate, or come to that, why any members here use them at all!
                                  I do just wonder how many of the unseen numbers of readers of these pages are put off replying to posts precisely because of unnecessary attacks of grammar policing such as yours, and how many are dissuaded from getting stuck into model engineering because of it!
                                  I personally have far bigger issues with Americanised spellcheckers (which in this case fires up ‘corrected spelling’ with a ‘Z’ and hyphen respectively), but I just ignore it and carry on regardless, perhaps you should waste less of you life doing the same!
                                  #195592
                                  RJW
                                    @rjw
                                    Danny, just to get this thread back on track, the two links below will take you to free downloads of each programme, install and update both then run full scans on your computer,
                                    Unlike anti-virus programmes, you can keep these two on your computer, they reside happily together whereas two anti-virus programmes won’t.
                                    Good luck with it, I’m done here!
                                    John.
                                    http://www.superantispyware.com
                                    https://www.malwarebytes.org/mwb-download/sem/
                                    #195593
                                    RJW
                                      @rjw
                                      Post duplicated somehow?
                                      Edited By RJW on 02/07/2015 14:39:21
                                      #195598
                                      Lambton
                                        @lambton
                                        RJW.
                                        Well I am sure you now feel better getting that lot off your chest.
                                        I can take a bit of criticism even if it is a bit unwarranted. I would still like a satisfactory answer to my polite question. If you cannot supply one I will quite understand.
                                        #195619
                                        jason udall
                                          @jasonudall57142
                                          I may not be alone here but sometimes it seems individuals have trouble with individuals …not what they say ( or write).
                                          Now back to the op point
                                          I like trendmicro’s “housecall”..as a antivirus first check ( even with good anti virus and cautious habits).
                                          As to thimbles download page for sketchup…first decide language then 64 vs 32 bit then “make” vs ” pro” then 2014 vs2015
                                          ….thusly more than a few options.
                                          Me , I use English ,2014 ,MAKE
                                          Although prompted to upgrade to 2015 …2015 won’t work on my XP COMPUTER
                                          Best of luck
                                          #195631
                                          Enough!
                                            @enough
                                            Whatever happened to backups? AV programs have their place but restoring from a complete backup is arguably much more definitive in removing malware (and gives me at least a much warmer feeling). Routine backups are so easy to do in these days of USB drives and terrabyte HDs.
                                            I also take the time to make a temporary backup before installing most new programs (particularly, as in this case, installed via a web download) or anything else that might be the least bit risky. In that case I usually do it to another HD on my computer.
                                            (Some seem to think that Windows Restore does much the same thing. That's quite untrue – all it does is backup the registry – and a few other files – and roll it back on demand. If malware has been introduced in the meantime, it is most unlikely that it will be fixed).
                                            Edited By Bandersnatch on 02/07/2015 22:03:22
                                            #195633
                                            jason udall
                                              @jasonudall57142
                                              Backups…
                                              Can I offer a futher layer of protection?…
                                              I pull my pc hard disc..replace with minimal install on a different hd..use this “new” pc to scan the other hd..but since this pc is booted clean. the malware that might camouflage itself against a scan is exceedingly unlikely to be present. .and if that passes, the “working” hard disc this is returned to its rightful place…
                                              I used to keep a pc reserved for this at work..
                                              Too paranoid? .
                                              Maybe.
                                              #195634
                                              Enough!
                                                @enough
                                                Posted by RJW on 02/07/2015 14:33:24:
                                                It should be customisable (not customizable smiley ). Have you looked for a British-English dictionary for the browser you use? I know it's available for Firefox since I use it myself. I have to believe that there is one for IE Some of the less mainstream browsers may not have one …. although I think some can use the FF one
                                                #195635
                                                jason udall
                                                  @jasonudall57142
                                                  Of course we could use unix or whatever thats grown into nowadays
                                                  #195636
                                                  jason udall
                                                    @jasonudall57142
                                                    Spell checkers?
                                                    My biggest gripe is auto correct to the WRONG but correctly spelt word.
                                                    #195639
                                                    Enough!
                                                      @enough
                                                      On the malware front, another extremely useful tool is Sandboxie
                                                      (Forgot about that but it just popped up an update notice).
