Burgundy finish to tools with wooden handles?
Home Forums Workshop Tools and Tooling Burgundy finish to tools with wooden handles?
  • #476415
    Andrew Tinsley
      @andrewtinsley63637
      I am restoring some of my fathers old tools. The wooden handles of such things as yankee screwdrivers, Brace and bit drills and some of his planes are finished with a burgundy coloured paint, or more probably varnish.
      Having done the mechanical sorting, I would like to reproduce the burgundy finish, but I have drawn a complete blank to date on a source of the paint / varnish.
      Can anyone suggest a supplier?
      Thanks,
      Andrew.
      #19789
      Andrew Tinsley
        @andrewtinsley63637
        #476420
        Grindstone Cowboy
          @grindstonecowboy
          Pretty sure the Yankee screwdrivers have a paint finish, possibly with a clear lacquer over it, The woodwork on Stanley planes was varnished, but not AFAIK in burgundy – all mine (like you, inherited from Dad) are just clear/brown. Sorry I can't help with a supplier, but I'm sure someone will very soon. Paragon paints could probably mix whatever colour you specify.
          And I'm a big fan of Yankee screwdrivers – quite often better than a cordless driver yes
          All the best,
          Rob
          #476430
            Some form of coloured lacquer rather than paint as it is slightly transparent, My dads one has the colour you describe or what's left of it and my plastic handled one is burgundy.
            May be worth asking on one of the woodworking forums as they usually have a healthy number of tool collectors/restoreres.
            #476448
            Andrew Tinsley
              @andrewtinsley63637
              Thanks Jason,
              I think you are correct in it being a lacquer, it doesn't look right for either paint or varnish. I will try a woodworking forum and see what transpires.
              Yes you are right Grindstone, I intend to use the yankee screwdrivers, they are not just for show!
              Andrew.
              #476451
              Martin Kyte
                @martinkyte99762
                Sort yourself out with the right coloured wood stain (you can mix them to get the right shade) then lacquer or Danish oil.
                regards Martin
                #476479
                  It doesn’t answer your question, but this has a lot of useful information about the Yankee screwdivers : **LINK**
                  http://thevalleywoodworker.blogspot.com/2016/01/the-yankee-spiral-screwdrivers-family.html
                  Andrew Tinsley
                    @andrewtinsley63637
                    Hello Martin,
                    I did think of mixing woodstains to give the correct colour. but my normal make of stain doesn't do a stain that is red enough. Maybe take a look at other makes.
                    Thanks,
                    Andrew.
                    #476495
                    Former Member
                      @formermember32069
                      #476498
                      ega
                        @ega
                        I don't think the woodstain will obliterate the grain of the wood. Dipping in the appropriate paint or lacquer is the way to go.
                        #476499
                        Andrew Tinsley
                          @andrewtinsley63637
                          Hello Barrie a photo of the tool chest would be good. I would like to see the finish before going ahead. I have had to strip down the last painting job twice because of problems and I don't want to start doing it again. Once is bad enough, but twice is purgatory!
                          Thanks,
                          Andrew.
                          #476504
                          Mike Poole
                            @mikepoole82104
                            Although air tools and for the last 25 years battery tools were used on production the Yankee was still used in some places. My uncle had a Yankee without a speck of paint on the wooden handle and it was natural wood so I suspect it was not stained before lacquering, whatever they finished it with it was quite thick and would chip if abused. Perhaps Stanley would know if they are feeling helpful and you drop then a line.
                            #476535
                            Former Member
                              @formermember32069
                              #476581
                              Andrew Tinsley
                                @andrewtinsley63637
                                Thanks for that Barrie. I shall check Rustins stains to see if there is one red enough to do the job.
                                Andrew.
                                #476674
                                KWIL
                                  @kwil
                                  Just taken a look at my own Yankee driver, It was definately a black finish, woodgrain only shows where the finish has been rubbed away by use over the years. Had it since new.
                                  #476728
                                  ega
                                    @ega
                                    Posted by KWIL on 01/06/2020 13:46:27:
                                    Was it by any chance one of the early North Brothers drivers?
                                    #476799
                                    Andrew Tinsley
                                      @andrewtinsley63637
                                      Hello Kwil,
                                      One of my old man's yankees had a black handle, just as you described. Being black, meant it was easy to restore to original condition.
                                      I am not sure that I know why I am doing this. I suppose that I spent a lot of my younger years in the shed with my father. It is the memory of the tools when they were were well cared for. They were in a sorry state, before renovating them. I just get a good feeling when using them.
                                      Now for the final push and get the burgundy handle sorted!
                                      Andrew.
                                      #476806
                                      speelwerk
                                        @speelwerk
                                        Do not know a UK supplier but Clou "bright red" is very red indeed **LINK** . Niko.
                                        #476821
                                        Mark Easingwood
                                          @markeasingwood33578
                                          The one on the right, and the ratchet are mine, so a good 35 years old, the two Yankee's on the left were my Dad's, so they will be even older.
                                          The one on the right has an Ash handle, which I made, as the original one came loose and started started revolving.
                                          The colour on the ratchet is a shade darker than that on the Yankee. The Yankee colour looks similar to original Red Oxide paint. Although most of the coloured finish has gone, there still appears to be a clear gloss finish left. My best guess is they put a clear coat on before the colour coat, which may explain why the colour coat does not stay on.
                                          We did have a much smaller Yankee type with a black handle, and a burgundy plastic handled ratchet, I can't find them 'tho, or maybe another family member has them.
                                          These people **Chestnut** do a very good Black Ebonising Stain, an a Black Ebonising Aerosol, if you are going to do them black.
                                          I totally agree with your reasoning, and shed memories. Having done similar to some of my Dad's tools.
                                          #476949
                                          Kiwi Bloke
                                            @kiwibloke62605
                                            Whatever the coating is, it's brittle, and eventually flakes off in nasty, sharp-edged 'splinters', revealing uncoloured wood. I assumed it was just a coloured old-style varnish (whatever that is).
                                            #476953
                                            Nick Clarke 3
                                              @nickclarke3
                                              Posted by Kiwi Bloke on 02/06/2020 12:18:45:
                                              Coloured Shellac/French polish??
                                              #476957
                                              Kiwi Bloke
                                                @kiwibloke62605
                                                I wondered about that. Can you easily (in a factory setting) get a fairly thick coat with shellac?
                                                #476984
                                                Andrew Tinsley
                                                  @andrewtinsley63637
                                                  I have done a little research and a couple of people have used Valspar Satin, which as an exact match for thr colour.
                                                  It seems that this can be had in 400 ml rattle cans. So the search is on to find some.
                                                  Thanks for every ones help and suggestions.
                                                  Andrew.
                                                  #477039
                                                    I've alway assumed it's a shellac-based lacquer.
