Workshop Gloves
Workshop Gloves
Home Forums Workshop Tools and Tooling Workshop Gloves
Viewing 25 posts - 1 through 25 (of 50 total)
  • #475997
    Dr_GMJN
      @dr_gmjn
      All, I’ve started wearing gloves for lathe and mill work because I’m fed up of pulling chip fragments out of my fingers and/or constantly washing my hands with swarfega. I’ve got an old pair of red Skytec gloves, which have been ok, but are now worn through.
      Any recommendations for a pair of light gloves that retain feel?
      When working on cars, or painting models I use latex gloves, but I find them too ‘sticky’ when, for example turning a smooth handwheel on a lathe, or adjusting the 4 jaw Chuck with it’s keys; the polished metal doesn’t slide like it does on skin or cloth.
      Thanks!
      #19784
      Dr_GMJN
        @dr_gmjn
        #475999
        Gray62
          @gray62
          It is highly inadvisable to wear gloves of any sort when working on or near rotating machinery, this includes but not limited to lathes, milling machines, drill press etc. Wearing gloves while working on these types of machine increases the risk of being caught and pulled into the machine, the consequences can be grave.
          On a lighter note, if you are cleaning down a stationary, power isolated machine or fitting/removing chucks etc, then gloves can be worn to advantage, have a look at the site range of gloves from screwfix, reasonably prices and as good as you will get.
          #476000
            I wear thin nitrile gloves, as they would tear easily, if snagged, and are a fair bit better than latex. Nothing heavier, unless away from the machines.
            I have to be careful when winding a hand-wheel with fixed handle – replacing the handle with a rotating one is advantageous, or winding with a sliver of material around it helps to avoid ‘wind-up’.
            #476001
            Anonymous
              Do NOT wear gloves when operating machinery. If they get caught on something you'll be dragged in before you know it. I use brushes and scrapers for cleaning up swarf and rarely have problems as I don't touch the swarf.
              #476004
              Dave Halford
                @davehalford22513
                I've found food prep. vinyl gloves better than latex, they last a lot longer. Hot swarf still stings and those splinters from milling still get through.
                #476006
                ChrisB
                  @chrisb35596
                  I don't normally use gloves on the lathe, but on the mill I occasionally do wear disposable nitrile gloves. The needle type swarf gets everywhere even tho I use a shopvac to clean most of it away. Like ndiy says, you will not get caught and dragged with disposable gloves as they will tear off instantly. I prefer nitrile to latex as they offer better chemical resistance. If you find yours too sticky oil them.
                  #476009
                  Brian Wood
                    @brianwood45127
                    Hello Dr.
                    I can recommend Nitropalm gloves.
                    These are nitrile coated in the palm and fingers, thin enough to allow decent dexterity while at the same time giving a good grip in workshop use, with a woven cotton back and elasticated wrist.
                    They are comfortable wearing and make working on cold materials and machines in the winter rather more pleasant as an added bonus
                    Central Sales Marketing, Unit 1, Shaw Lane Industrial Estate, Stoke Prior, BROMSGROVE B60 4ED
                    Phone 01527 832092 Web:- centralsalesgloves,co.uk Email:- [email protected]
                    Regards Brian
                    #476010
                    Mike Clarke
                      @mikeclarke87958
                      You might find barrier cream useful. I don't use it very often but is a handy addition to the workshop. Gloves are a big no-no and simply not worth the risk given the results are only dirty hands.
                      #476012
                      Essm
                        @essm
                        For a number of years before I retired it was mandatory for all trades in the water and wastewater construction industry to wear hand protection and so I have continued the practice in the workshop.
                        I use "Polyco Matrix P Black" gloves which are readily available thro' the internet.
                        I wear them all the time – except when trying to fit 10BA nuts! – even when working on the lathe.
                        #476014
                        Chris Evans 6
                          @chrisevans6
                          I wear gloves a lot when working on the cars or old bikes. I never wear them on the lathe or mill and can't subscribe to the theory that they will tear and not do harm.
                          #476017
                          Ron Laden
                            @ronladen17547
                            I never wear gloves except for chemicals/adhesives etc and I wouldn't be so certain about nitrile gloves tearing off instantly. That may happen 9 times out of 10 but if a spinning tool grabbed part of the glove and spun it into a cord it could pull your fingers in, it may not but I wouldn't risk it. Take a nitrile glove twist up just one of the fingers and see how strong it is, you may be surprised.
                            Edited By Ron Laden on 30/05/2020 09:49:12
                            #476020
                              Posted by Dr_GMJN on 30/05/2020 08:25:00:
                              All, I’ve started wearing gloves for lathe and mill work because I’m fed up of pulling chip fragments out of my fingers and/or constantly washing my hands with swarfega. …
                              Agree with everyone else about not wearing gloves when using machine tools. Anything that could get caught is to be avoided – ties, loose clothing, rings, and long hair (not a risk here now it's all fallen out!)
                              I wear Nitrile gloves for gear changing and more rarely for dirty work like cast-iron, but otherwise avoid skin contact with swarf and dirt as much as possible. Swarf is nasty stuff, Brass in particular. Constant washing and picking swarf out of fingers suggests a change tack is advised. Instead remove swarf with a brush, magnet, or anything else that reduces skin contact, and keep the controls and adjustments clean with a fresh rag used only when the motor is off.
                              I decided eye-protection was a must after my lathe chuck flung a clump of swarf into my face. It hit me just below my left eye and drew blood. A little higher and I'd have been off to A&E.
                              Although small machine tools can and do inflict painful injuries, Model Engineering isn't a dangerous hobby. A few simple precautions keep me safe, perhaps the most important is the need to stop when tired. My concentration goes to pot!
                              Clive Foster
                                @clivefoster55965
                                As I understand it its not so much the proper, around your hands, glove part thats the real hazard.
                                More the cuff.
                                Even with a fragile nitrile or whatever glove, due to the directions of rotation and normal hand orientation, if that gets caught up its likely to roll up into several layers and become much harder to tear.
                                Generally hate working in gloves on mechanic or other appropriate jobs myself. If they are thin enough to let you feel whats happening they are too weak and tear all the time. Sweaty too.
                                I'm lucky. My hands are naturally dry and the skin toughens quickly.
                                For clean up, sweep up et al duties I buy the cheap work gloves from LiDL 'cos they have proper sizing not just S-M-L-XL. They keep changing the design but all, so far, have been fine.
                                #476027
                                IanT
                                  @iant
                                  I've started using 'Gloves in a Bottle' – purchased in Superdrug before the lockdown. Not cheap (about £9 a bottle) but I only use a little each time – so it should last a while. I think a barrier cream is a very good idea. Someone here recommended it and I thought it was a good idea in my particular case (as I suffer from minor skin irritations)
                                  I don't wear gloves when actually working on the machines but certainly do wear gloves routinely at other times.
                                  I have some cotton backed ones with some form of rubber face on the palm/fingers for any really dirty/oily handling work – like when rummaging in the scrap heap or cleaning down machines. But most of the time I wear some well made (Lidl) woven ones with reinforced finger/palm areas (not rubber) that are good for general manual work and more importantly help keep my hands warm – arthritis being a problem in the colder weather down the Shed.
                                  IanT
                                  #476030
                                  Dr_GMJN
                                    @dr_gmjn
                                    Thanks guys – The main issue is after the work is completed and I'm either removing it from the chuck, or cleaning swarf off it, or the machine – No matter how careful I am, there's always a shard of steel or brass somewhere.
                                    While using the handwheels, I've been using latex, but it's hopeless, so I tried the Skytec ones, which are better, but I appreciate it's not a great idea, hence the question. I want something light (and that will tear off) – like latex, but latex that doesn't stick…
                                    #476040
                                    Paul Lousick
                                      @paullousick59116
                                      As well as not wearing gloves near rotating machinery, I was also taught to not wear loose sleeve long sleeves, jewelry, neck ties and long hair.
                                      If a ring catches, it could rip off a finger, a neck tie will strangle you and long hair will give you an instant haircut.
                                      Paul
                                      Edited By Paul Lousick on 30/05/2020 10:32:53
                                      #476051
                                      ega
                                        @ega
                                        One use for gloves which I don't think has been mentioned is as an aid to heavy lifting; I sometimes use in addition a waist brace rather like the ones that Stirling Moss used to wear.
                                        When it comes to barrier cream I know nothing better than PR88.
                                        #476052
                                        Philip Burley
                                          @philipburley44197
                                          I was wearing some thin rubber gloves ( not nitrile) while polishing with some emery tape on the lathe , suddenly caught up and pulled my finger in , Glove wrapped round the bar , tightened on my finger , luckily the belt was slack. but I had a job reaching the off switch , Made a mess of my skin but no broken bones .
                                          Motto never wear gloves and be VERY careful using emery tape
                                          Phil
                                          #476058
                                          clogs
                                            @clogs
                                            the only time I wear gloves is when I dye my wife's hair…..
                                            yes we live in the boonies….also it's b €100 to get it done and an hours drive…..dont ask about the parking…..
                                            Cant believe all these NANCY boy's wearing them…….
                                            mind it all stems from the blokes wearing make up, special hair gel and high heeled shoes…..
                                            GET A LIFE…..
                                            #476067
                                            ega
                                              @ega
                                              Posted by clogs on 30/05/2020 11:19:38:
                                              They probably wear them in Besançon, too!
                                              #476073
                                              mechman48
                                                @mechman48
                                                Thoroughly concur with SOD. I take off my wedding ring, never wear ties in the man cave, watch off, have my warehouse coat sleeves rolled up as far as possible with cuffs out of the way but with the warm weather lately not even wearing that only shorts or T shirt & jeans at the moment. I use barrier cream ( Mach. Mart own brand, usual disclaimer ) & only use nitrile/latex gloves when machining cast iron or cleaning down & last but not least trainers with steel toe caps.
                                                George.
                                                #476082
                                                oilcan
                                                  @oilcan
                                                  I've always worn nitrile gloves when in the 'cave.' For no other reason than the pleasure of taking them off last thing and having a clean pair of hands. No more getting shouted at for leaving oily fingerprints on the door handle when I re-enter the house. Occasionally on the milling machine, I will double glove with a pair of those tight fitting rubber faced gloves. Stops any swarf penetrating, and it doesn't matter if they get oily because of the nitrile gloves. The nitrile gloves really are that thin they will tear very easily. For polishing with emery on the lathe, I have a selection of different cross sections of dowel with various grades of wet and dry glued to them, and use them as you would a file on the lathe. Being left handed, their use is quite natural.
                                                  since I've run out of gloves, and haven't replaced them yet, I can't help notice just how much of a dirt magnet my hands are!
                                                  #476085
                                                  JA
                                                    @ja
                                                    The only glove I use is a welder's glove on my left hand, either when I am silver soldering or holding something being "Dremmeled". Usually it is right handed because I cannot find the left hand glove.
                                                    JA
                                                    #476089
                                                    Rex Hanman
                                                      @rexhanman57403
                                                      Having witnessed a gloved hand get caught in a lathe I cringe at the thought of gloves anywhere near machine tools. It was an horrendous sight…arm broken in 4 places and dislocated wrist. Do it at your peril.
