VMC or 626 in bite size bits
Home Forums Workshop Tools and Tooling VMC or 626 in bite size bits
  • #469007
    Mike Poole
      @mikepoole82104
      My VMC broken down into bits two men can easily manage
      Edited By Mike Poole on 04/05/2020 10:37:02
      #19733
      Mike Poole
        @mikepoole82104
        #469009
        Vic
          @vic
          When I moved house six years ago I bought an engine hoist. I removed the head of my VMC and fixed it to one dolley, then removed the column complete from the base and bolted that to another dolley. Sadly we have a gravel drive that extends right the length of the house to the workshop but the removal guys managed ok.
          Now is the time to make detailed drawings of the collar at the top of the column in case you want to make a spacer to extend your Z. I so wish Warco made these as an accessory. My lathe is too small to make my own. Some went bonkers and made 6-8” ones (and found the Z lead screw was now too short) but I really don’t need anything more than 3-4”.
          #469010
          Steviegtr
            @steviegtr
            Looks like a substantial piece of machinery. Are you getting a new one.?????
            Steve.
            #469012
            Vic
              @vic
              I forgot to say, but one of the reasons I chose the VMC is because I knew it could easily be split into bits for house moves! smiley
              #469019
              Mike Poole
                @mikepoole82104
                Posted by Steviegtr on 04/05/2020 10:49:57:
                Steve.
                This was arrival day in 2007, it arrived fully assembled on a pallet with the base cabinet strapped to the top, the garage has a partition so the personnel door is the only easy access. Even if it was a flat run into the workshop I don’t think it would be too easy to get through the door. The breakdown is very easy and a 6’3” son was available so this is how it went. I moved it again fairly recently and you realise your strength is ebbing away when you get into your sixties, luckily No2 son was available this time now he is fully matured.
                A good point Vic, I didn’t measure up on either occasion but I haven’t run out of daylight yet, I have R8 collets if things do get a bit tight, I expect a big job will arise tomorrow and I will want a bit more height but so far it’s been ok.
                Edited By Mike Poole on 04/05/2020 11:37:37
                #469020
                Martin Kyte
                  @martinkyte99762
                  Have you learn't the trick of getting the column onto the stand? If you put a pad of wood on the floor in front of the stand and then turn the column so that it rests on it's head with the front of the base facing the stand you can lower it so that the base rests inside on stand inside the drip tray and then roll it upright so that it stands facing the front where it should be. It's amazing what tricks you come up with when you are faced with a one man lift.
                  regards Martin
