Bench grinder recommendations
Home › Forums › Workshop Tools and Tooling › Bench grinder recommendations
  • #349974
    Bram
      @bram
      Hi, looking for advice/recommendations for a bench grinder for sharpening drills and lathe tooling, lathe is a colchester master to give an idea of tool sizes. Been tentatively looking and can’t find anything (half reasonable price) with a decent tool rest!! Any suggestions welcomed
      Thanks in advance phil
      #18895
      Bram
        @bram
        #349978
        Ian Parkin
          @ianparkin39383
          I have used a record power 8 inch with 2 wheels one a 40mm wide grit and a 25mm grey grit its been ok
          Tool rests always seem to unsubstantial so I’ve made upgrades to them.
          However I’ve just finished building a large grinder using belts so its surplus to requirements
          If you can collect from sheffield you can have it for a good price
          Ian
          #349979
            Forget finding a new unit with a decent tool rest – expect to make something there. Otherwise the 10in Trojan from Screwfix seems very good value.
            #349982
            David George 1
              @davidgeorge1
              I think that this Crusen is worth the money It runs true and has reasonable tool rests but I have reinforced them with a gage plate top You get what you pay for.
              David
              #349985
              Vic
                @vic
                I’ve got a grinder but I do most of my sharpening on a belt sander.
                #349994
                  There are best part of twenty threads for a forum search of “bench grinder”. Have you read those?
                  You won’t be guaranteed to get anything good at half of a decent price.
                  Location (profile)? Someone local may have a good grinder which is surplus.
                  ‘Best you can afford’ would be my advice. Buying cheap often leads to buying twice.
                  #350016
                  Bram
                    @bram
                    Thanks for that, Sheffield bit far for a grinder! I’m in north wales (Flintshire) think I’ve just lt updated my profile to show that. (Well I think I have!!) phil
