4MM Carbide end mill marks
Home › Forums › Workshop Techniques › 4MM Carbide end mill marks
  • #484940
    BOB BLACKSHAW 1
      @bobblackshaw1
      15943992171496885420766624000176.jpgI used a new 4mm carbide end mill on mild steel using a rotary table and the results gave these marks. I used a higher speed as it was a carbide end mill rather than HSS, any ideas why this has happened, also tried a slower speeds but the same happened.
      Bob
      #16177
      BOB BLACKSHAW 1
        @bobblackshaw1
        #484944
          Look like they are at about 4degree spacing so could be related to cranking the handwheel, is there much play in your rotary table?
          #484945
          Brian Wood
            @brianwood45127
            Bob,
            I would hazard a guess at these marks being evidence of vibration or tool snatching. Rotary table braking to stiffen the action might improve it and a lot will depend of whether you were 'climb' milling
            Regards Brian
            #484953
            Tony Pratt 1
              @tonypratt1
              Are you 'climb milling' i.e. the cutter rotation tends to pull the work around?
              Tony
              #485041
              BOB BLACKSHAW 1
                @bobblackshaw1
                Thanks for the advice, my rotary table is a Soba and its new and has no play and it feels tight, I was not climb milling but I done a fine cut .05mm and got the marks out, Perhaps my first cut .3mm caused the cutter to vibrate.
                Thanks Bob
                #485044
                old mart
                  @oldmart
                  I have had some problems like that with the drill mill but not the Tom Senior. Two possibilities spring to mind, either the spindle bearings in the DM are not as good, of the speeds being different can affect vibration and some kind of resonance.
                  These problems are difficult to diagnose without a lot of time consuming testing.
                  Even taking the tool out of the collet and refitting it might make a difference.
                Home › Forums › Workshop Techniques › Topics
