Mating a drillchuck to an arbor
Home › Forums › Workshop Techniques › Mating a drillchuck to an arbor
  • #133489
    Clive Hartland
      @clivehartland94829
      I am about to fit a fit a B16 arbor to a keyless drill chuck, what should I look out for?
      #15668
      Clive Hartland
        @clivehartland94829
        #133495
        Versaboss
          @versaboss
          Don't quite understand your problem, but maybe check that the chuck also has B16 taper (and not one of the Jacobs tapers).
          Greetings, Hansrudolf
          #133497
          Robbo
            @robbo
            Clive,
            About the only precaution is to check that the arbor runs true before you glue it into the chuck, rather than find out afterwards.
            Phil
            #133504
            Nobby
              @nobby
              Hi
              To check if they are same .with finger put on some high spot blue and gently fit the arbor into the chuck and
              See how it touches. MY son was a fitter in the RAF and he sugested to his dad on a job like this use a black felt tip pen and when dry try as i said with the high spot
              Nobby
              Edited By Nobby on 23/10/2013 23:27:56
              #133522
              Clive Hartland
                @clivehartland94829
                I ask because I have previously had a problem with a smaller chuck that would not stay on the arbor, even though the taper showed no fault when blued and offered up. It was finally fixed by knocking it onto the arbor with a hide mallet.
                #133525
                speelwerk
                  @speelwerk
                  Degrease arbor and chuck, than place the arbor in the fridge for a while to obtain a better grip. Niko.
                  #133542
                  Sub Mandrel
                    @submandrel
                    This worked for me once.
                    #133555
                    Geoff Theasby
                      @geofftheasby
                      Clive,
                      That worked well for me, after taking advice from a local club member.
                      #133564
                      KWIL
                        @kwil
                        In the old days when we used to replace CI valve guides in car engines, we knocked out the old, but put the new ones in the freezer, made a depth guage and merely placed the new ones. Worked a treat, no hammering and always in the right place.
                        #133578
                        Clive Hartland
                          @clivehartland94829
                          Thanks for all the info, I will freeze the arbor and do it that way.
                          #134467
                          clogs
                            @clogs
                            HI Guy's …I've a few old drill press's bought used and the chuck's used to work loose after a while….
                            I used 222 Locktight or screw – lock to keep them together…..clean the chuck and its mating face…just a couple of drops of the fluid, hand fit…spin to check for run out…once ur satisfied place a block of wood under the chuck and hang a weight on the operation arm to keep the chuck tight…overnight shoud do it……one of mine was real bad, had tram lines in it, used a little extra fine valve grinding paste to lap it in, a good clean up and Locktite…it's never come of…….only do this if u'll never want the chuck off again say for say MT drill bits….
                            Frank in France
                          Home › Forums › Workshop Techniques › Topics
