Metric Screwcutting on Super 7B with 127 Tooth gear
Home Forums Manual machine tools Metric Screwcutting on Super 7B with 127 Tooth gear
  • #112083
    Nigel Bennett
      @nigelbennett69913
      Well, I've acquired a Myford 127T gear. Apart from using it as an occasional table, the intention was to pair it with a 100T gear to convert the Imperial gearbox to Metric (when needed). Using this will give exact metric threads within the original accuracy of the leadscrew. Obviously, the clasp nuts will have to remain closed – it's crying out for Graham Meek's wizzo widget!
      It's apparent that the Gearbox Cover won't close on it when fitted.
      Has anybody actually used one on a Super 7B? Is the metric conversion banjo large enough to accommodate it, or is it a case of making a special one?
      #12085
      Nigel Bennett
        @nigelbennett69913
        #112089
        John Stevenson 1
          @johnstevenson1
          No you have to run case open or removed depending on if it's a S7 or ML7 due to size
          #112090
          Swarf, Mostly!
            @swarfmostly
            Hi there,
            When my ML7 was new (to me) and I was all super keen, one of the goodies I bought was a 127 tooth change wheel. I have to confess that I've never used it.
            I haven't checked the tables but I seem to remember that there was an alternative method that used 2-off 21 tooth wheels.
            Best regards,
            Swarf, Mostly!
            #569191
            noel shelley
              @noelshelley55608
              This thread was started 8 years ago and got no real answers ! Like Nigel and Swarf Mostly, I got hold of a 127 change wheel ! Can any body give us instructions as to using it ? Does one have to make a new banjo, what calculations does one need to do to work out the gear train, are they listed somewhere ? Noel.
              #569194
              John Olsen
                @johnolsen79199
                Well, I can't really help much, since I have had my ML7 with a 127 tooth gear and have never used it either. My father also had it for a few years before that, and to the best of my knowledge he never used it either. The gear itself was salvaged along with a set of change wheels from a lathe that had gone for scrap. I don't know what the lathe was but the change wheels are the right DP for Myford, albeit with smaller holes and greater width, which was easy enough to fix.
                The main reason I have never tried to use it is that it would need a slot cutting in the stand the lathe sits on, and acceptable accuracy is available just using the 63 tooth approximation, which is close enough for anything I will ever be likely to need. But the 127 tooth dinner plate looks impressive hanging on its nail on the wall.
                Doug Bauld
                  @dougbauld76775
                  Gearing of Lathes for Screwcutting by Brian Wood. ISBN 978-1-78500-250-2. Covers this topic extremely well, Chapters 1 & 2 .
                  Doug.
                  #569196
                  Steviegtr
                    @steviegtr
                    Confused as i bought the 34 & 36 tooth gears to cut most metric sizes , without touching the gearbox. Never used them but i have all the data somewhere explaining how it is done.
                    Steve.
                    #569199
                    John Olsen
                      @johnolsen79199
                      Hey Steve, The 127 tooth gives a precise conversion to/from metric since it is the smallest prime factor of the ratio between inches and millimetres. (The end result will still only be as good as the leadscrew.) There are other approximations using more reasonable size gears that work perfectly well for all normal purposes. So yours will be fine for anything you are likely to want to do.
                      regards
                        One great proponent of the 127 tooth gear was Martin Cleeve … but he, very wisely, used a reduced pitch on his ML7.
                        Ref. https://www.model-engineer.co.uk/forums/postings.asp?th=113302&p=3
                        Edited By Michael Gilligan on 01/11/2021 06:27:54
                        #569210
                        DC31k
                          @dc31k
                          Posted by noel shelley on 31/10/2021 23:18:54:
                          This thread was started 8 years ago and got no real answers ! Like Nigel and Swarf Mostly, I got hold of a 127 change wheel ! Can any body give us instructions as to using it?
                          You need to be very specific concerning your machine details to receive any meaningful answer.
                          Particularly, if it is a changewheel-only (non-gearbox) machine, the solution will be different to whether it has a gearbox.
                          #569211
                          noel shelley
                            @noelshelley55608
                            Myford S7 Late 60s X2 ! One change wheel and the other with a gearbox!. Many thanks, Noel.
                            #569224
                            John P
                              @johnp77052
                              The problem when using a 127 gear on a Myford 7 changewheel machine
                              is simply the size of the gear if you have it as 20 DP,the lead screw centre
                              distance to tumbler stud = 3.785" and is equal to the size od a 149
                              tooth gear .As a pair of gears in line maximum that can be fitted in is a
                              20 tooth and 127 tooth .
                              As Michael G pointed out ,One great proponent of the 127 tooth gear was
                              I have gone down this same route using a 0.8 module 127 and 60 tooth
                              gear with the exceptions of 2 pitches the rest can be done using only
                              the remaining standard changwheel set supplied with the machine
                              using the standard banjo and being able to shut the cover.
                              Here is the screw cutting chart a horizontal version is in the album
                              "gears" as this is easier to print out in nearly A4.
                              #569227
                              speelwerk
                                @speelwerk
                                127 works fine, just be careful where you put your fingers when you have the cover off. Niko.
                                #569230
                                  When I had a ML7, a 127T gear soon became part of my Changewheel collection. (Just in case ) But, as far as can be recalled, never found the need to use it.
                                  However, the first Metric thread that I cut was 1 mm pitch, fortunately on my lathe which includes a 120/127T compound in it the feed to gearbox.
                                  #569239
                                  IanT
                                    @iant
                                    I have a 127t gear for my old Super Seven.
                                    Not used it for a good while but it worked well for the metric thread I required from what I recall. You do need to keep the door open but I didn't find that a problem in practice. BTW – I don't have a 100t gear but used a 50t one instead as part of the gear mix.
                                    IanT
                                    Edited By IanT on 01/11/2021 10:21:25
                                    #569261
                                    Glyn Davies
                                      @glyndavies49417
                                      I don't have a 127 tooth gear, but looking at my gearing spreadsheet and using the metric conversion set, with:
                                      Tumbler stud – 30t
                                      Gearbox input gear (gear X) – 127t
                                      First stud driven – 60t
                                      First stud driver – 80t
                                      Gives exactly:
                                      A1 – 1mm pitch
                                      B1 – 0.5mm pitch
                                      C1 – 0.25mm pitch
                                      A4 – 0.8mm pitch
                                      B4 – 0.4mm pitch
                                      C4 – 0.2mm pitch.
                                      The arrangement looks like it will fit the standard metric conversion banjo.
                                      The standard metric conversion set using the 63t gear gives an error of .00125mm per 10mm of thread length in all the metric pitches.
                                      #569344
                                      bernard towers
                                        @bernardtowers37738
                                        Steviegtr, surely you mean 33 and34 teeth.
                                        #569441
                                        Pete Rimmer
                                          @peterimmer30576
                                          Posted by John P on 01/11/2021 09:27:1
                                          My lathe uses 16DP gears except for the metric set which utilises 127 tooth. They are 32DP. I expect that a Myford 7 would get away with 40DP conversion gears but 32DP would do just as well being ever so slightly finer than 0.8MOD.
                                          Edited By Pete Rimmer on 02/11/2021 16:36:55
                                          #569453
                                            Posted by Pete Rimmer on 02/11/2021 16:36:19:
                                            To the extent that, in some circles, they are considered interchangeable and meshable !
                                            … purists, of course, cry: “perish the thought”
                                            John Haine
                                              @johnhaine32865
                                              I'm not sure if anyone in this thread has yet pointed out that for most practical purposes you don't need a 127 tooth gear to get acceptable accuracy metric threads for fasteners. There are a number ot tables around giving gear combinations for this. I also bought a 127 tooth gear for my S7 once, it languishes in a draw with all the rest of the change gears since I just use the CNC….
                                              #569458
                                              Pete Rimmer
                                                @peterimmer30576
                                                There are indeed combinations that give results closer than standard leadscrew maufacturing tolerances.
                                                #569760
                                                John P
                                                  @johnp77052
                                                  Posted by Pete Rimmer 02/11/2021 16:36:19
                                                  The gear chart for the 127/60 gears i find much
                                                  easier to use that the pair of 21 tooth gears that
                                                  i have had for as long as i have had the Myford.
                                                  Since the 60 and 127 gears are always in the same
                                                  places setting up only requires changing perhaps
                                                  one or two gears,for instance to change from
                                                  .075 to 1.00 and1.25 mm pitch only requires
                                                  a change on the tumbler from 30 to 40 and 50 tooth
                                                  and reposition the banjo,i only use a few pitches
                                                  anyway mostly 20 tpi 1 mm and .75 mm and since
                                                  the half nuts have to remain closed for metric cutting
                                                  i use a mandrel handle so it is useful to be able to
                                                  keep the gear change door closed.
                                                  I nearly made a 20 dp 127 gear but realised quite
                                                  early on that fitting and using it may turn out to be
                                                  a real problem ,i doubt if you would be able to do the
                                                  full range of metric pitches using one , if you know different
                                                  i am sure you will let me know.
                                                  Anyway the chart is there for you to use if you wish, it
                                                  would only suit .8 mod or 32 dp .All of the pitches
                                                  have been set up on my machine so they will fit in
                                                  some are a tight squeeze even with .8 mod gears.
                                                  DC31k
                                                    @dc31k
                                                    Posted by John P on 04/11/2021 11:15:20:
                                                    Anyway the chart is there for you to use if you wish…
                                                    As a general observation (i.e. I have seen it enough now to be bothered to ask the question), why is it that you produce a metric threading chart that includes pitches that are never used and are entirely non-standard (e.g. 2.25mm, 3.75mm, 1.3mm, 1.1mm)? I have seen it with metric thread dial indicator charts as well.
                                                    How many imperial threading charts do we see that include 6 1/2 tpi or 15tpi or 9 1/2 tpi?
                                                    #569797
                                                    John P
                                                      @johnp77052
                                                      Posted by DC31k 04/11/2021 15:03:01
                                                      as well.
                                                      9 1/2 tpi?
                                                      The chart replicates all of the metric pitches in the Myford
                                                      handbook and a few extra , the Myford chart only goes to 3.5 mm.
                                                      I suppose if i had missed any of these out someone else
                                                      would have pointed out that the chart would have been incomplete.
                                                      The 3.75 came out as i had transposed some gears when setting
                                                      up ,as it came up as exactly 3.75 i just left it in the chart.
                                                      As a matter of interest my Warco lathe has on its screwcutting chart
                                                      4 3/4, 5 1/2, 5 3/4 , 9 1/2, 11 1/2, 13 1/2 and 15 tpi and also includes
                                                      2.25 mm and 0.313, 0.625, 0.875 module.
                                                      As i said here ,
                                                      if it is of no use to you ignore it.
