Which Lathe
Which Lathe
Home › Forums › Manual machine tools › Which Lathe
  • #11663
    Anthony Spencer 1
      @anthonyspencer1
      #51559
      Anthony Spencer 1
        @anthonyspencer1
        Hi
        I am looking to move up from my present Myford Super 7.
        I need a lathe with at least 1.75″ bore in the spindle.
        Suggestions on lathes and rough estimate on what I am looking at cost wise would be appreciated.
        #51560
          Probably something like a Harrison M350 or M390 or a Colchester Mascot the good thing is you may well pick one up for what Myfords charge for a good spec Super 7.
          What are you making on that, nice traction engine by any chance?
          Jason
          Edited By JasonB on 09/05/2010 18:59:56
          #51584
          Anthony Spencer 1
            @anthonyspencer1
            Hi Jason
            No not a Traction Engine.
            I have some 28″ lengthz of 1.5″ steel that I need to thread very accurately.
            I will mount a Spider both front and rear of headstock spindle  then adjust till I get ,.0005″ runout
            This will be an ongoing project.
            #51597
            Clive Foster
              @clivefoster55965
              Probably £1,000 to £2,000 range should turn up something private / E-bay depending on your luck and exactly what condition will do.  Rather more from a dealer. Need to factor moving expenses too.  Colchester Triumph 2000 is the common one to easily take over 1.5″ in the bore.  Big lump for the home shop and, being well known, usually a bit pricey relative to condition.  Master 2500 is 1 17/32 bore, which maybe just enough, and seems to go relatively cheaply on flea-bay.  Elliot Omnispeed seems to be a good buy at the moment, if I recall correctly the spindle bore is bigger than on the older, Cardiff, equivalents.
              #51600
                Or you could just get something with a long bed and hold one end in a chuck, the other supported in a fixed steady.
                Jason
