bolts
bolts
Home Forums Beginners questions bolts
  • #520765
    Mike Brett
      @mikebrett89695
      I have some miniature brass door knobs that take a threaded rod which measures 1.85 mm or .073 inches across the threads. I need to order some more of the rod , anyone know who would stock this size . Not sure if this is a BA size or not.
      #10641
      Mike Brett
        @mikebrett89695
        wanted threaded rod
        #520771
        noel shelley
          @noelshelley55608
          possibly 9 Ba ! Thread gauge would be the answer, 65 Tpi Or 1.8mm X .35 Good luck, Noel
          #520773
            Depends on the provenance of the miniature door knobs., UK , possibly Europe, or North America.
            9 BA is 1.9 mm OD, 0.39mm pitch, or 65.1 tpi So, 1.85 mm could be a gnat's undersize. (0.025 mm is not much, 0.002" in old money )
            1 – 64 ANC is 0.073 OD
            1 – 72 ANF is 0.073 OD,
            So you need to measure the pitch of the thread . The ANC /ANF threads will be 60 degree thread form
            The BA thread will be 47.5 degree thread form, so they are not interchangeable!
            If that is any help
            #520776
            Brian H
              @brianh50089
              If it turns out that the thread is BA then I could let you have some pieces. I've been cutting down some 9BA x 1" screws to 1/4" long and have saved the cut off pieces.
              Brian
              #520782
              Jeff Dayman
                @jeffdayman43397
                As Howard said, could be #1-72, if made in USA.
                #520808
                Mike Brett
                  @mikebrett89695
                  Thanks for replies. I tried my thread gauge, but the thread size is so small its not easy for me to see. It seems to fall between 0.6 and 0.7 in metric.
                  #520815
                  Anonymous
                    Just musing but it ought to be possible to determine whether it's a 47.5 or 60 degree thread by eyeball through a reasonably powerful eye-loupe (or whatever).
                    Oh, woe …. the passing of the shadowgraph.
                    #520817
                    duncan webster 1
                      @duncanwebster1
                      could it be M2? 9ba is unlikely, it has been a 'non preferred' size for many years
                      #520820
                      Andrew Tinsley
                        @andrewtinsley63637
                        Hi Peter,
                        The shadow graph hasn't passed. I have one in my workshop and for jobs like this, you can't beat it!
                        Andrew.
                        #520823
                          0.6 mm pitch is 42.33 tpi 0.7 mm pitch is 36.2 tpi Both too coarse to be 1 ANF or 1 ANC, and certainly not 9 BA
                          48 tpi would be 0.529 mm pitch. 60 tpi would be 0.423mm pitch
                          The thread could be special, or maybe one of the lesser known ones used in watches and clocks?
                          #520835
                            M2 Coarse has a 0.4 mm pitch, and M2 Fine has a 0.25 mm pitch, So both too fine for a pitch between 0.6 and 0.7
                            Taking the coward's way out would it be feasible to drill and tap out to
                            8 BA? 2.2 mm OD, 1.68 mm core 0.43 mm pitch Tapping drill 1.85 mm
                            7 BA 2.5 mm OD, 1.92 mm core 0.48 mm pitch Tapping drill 2.1 mm (Non preferred size )
                            6 BA is 2.8 mm OD, 2.16 mm core, 0.53 mm pitch Tapping drill 2.35 mm
                            #520836
                            mgnbuk
                              @mgnbuk
                              There's inflation for you – 0.025mm used to be 0.001" smile
                              Nigel B.
                              #520846
                                Absolutely right Nigel.
                                Do you know of a good proof reader?
                                #520859
                                Mike Brett
                                  @mikebrett89695
                                  It did cross my mind to drill and tap, this is what I would normally do. But the parts are so tiny and I do not have a watchmakers lathe. They are only door knobs so not critical. I will just fit in what I can with loctite and leave it at that.
                                  Cheers Mike
