Round column milling machine basics
Home › Forums › Beginners questions › Round column milling machine basics
  • #10332
    Jeremy Smith 2
      @jeremysmith2
      #485939
      Jeremy Smith 2
        @jeremysmith2
        I restored an Rf30 milling machine a while back, and now I am learning how to use it. Keep in mind I am a rookie.
        i trammed the head to the table as close as i could get it. My next question is – when you clamp parts down, do you retram the part to the head, and shim under the part if needed, to get it square, or just keep the part flat on the trammed base of the mill?
        Maybe I am overthinking this. These questions are all in regards to removing material from the top of a part, parallel to its base. How about with a milling vise…retram the actual part to the quill (after it is clamped in the vise) before making any passes?
        anybody have a how to guide on milling for dummies lol?
        Edited By Jeremy Smith 2 on 16/07/2020 06:09:54
        #485941
        John Haine
          @johnhaine32865
          The whole point of the mill is to make flat surfaces parallel to the table. Once you tram the head, leave it alone (unless it shifts). The vice base on which you mount the part should be parallel to the table if the vice is s good one. Mount the part in the vice on parallels if needed to get the surface to be milled above the jaws, then off you go.
          I strongly recommend that you buy a book on milling, all this will be explained! I think Harold Hall has written a good one and there was a series in MEW a few months back.
          #485943
          Nicholas Farr
            @nicholasfarr14254
            Hi Jeremy, I suppose it all depends on the accuracy you are wanting to achieve, personally my mill head is trammed to the table and the work is either clamped to the table or in a vice or even a rotary table, but I don't tram to the vice or the R/T.
            Regards Nick.
            #486067
            old mart
              @oldmart
              The drill mill at the museum is similar design to the pictures of RF30's that came up by googling. It has no way of tramming the head to the table and I would be interested to find out how you did it. There is a joint between the column and the base, but it would be difficult in the extreme to successfully make any adjustments there.
              #486075
              Martin Connelly
                @martinconnelly55370
                Shim the joint between the column and the base.
                Martin C
                #486081
                Brian H
                  @brianh50089
                  Posted by Martin Connelly on 16/07/2020 17:34:04:
                  Martin C
                  Exactly what I did with my second hand Graham Eng. mill drill.
                  Brian
                  #486138
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi, I also shimmed my Chester Champion to get it to it's best, which was slightly out in the Y direction.
                    Regards Nick.
                    #486144
                    Stephen Spindler
                      @stephenspindler87715
                      I have an old worn RF25 and when I stripped it the base/column had a shim inserted. I reshimmed when I reassembled and its close enough for the type of work I do. The main thing to remember is think through operations and tool lengths to avoid needing to raise or lower the head and losing datum.
                      #486162
                      Jeremy Smith 2
                        @jeremysmith2
                        The machine was actually dropped at one point, and took some abuse. I had the base welded up, with a reinforcement plate also structurally bonded to the top, over top of the weld.I shimmed it the best I could get it. I will have to get the top of the table surface ground at a machine shop, as it was pretty rough when I got it.
                        #486172
                          Are you sure? It may not be smooth, but may be level and flat.
                          #486209
                          Robin
                            @robin
                            I shimmed my column and discovered a little bit of adjustment from the torque of the bolts holding it down so I was able to aim for perfection.
                            You may need to modify the tapered Gibb strip adjustors. Mine had a bit of slack so the slides were tight in one direction loose in the other.
                            I heard rumours of XY slides not being perfectly at right angles on later production but that could be fake news, mine are fine.
                            #486303
                              Once the head is trammed,parallel to the table in X and Y planes, the problem is is maintaining position after the head is moved up the column.
                              Stan Bray advised having a cheap laser mon the head, aimed at a line on the furthest wall.
                              With a cheapie laser line. from a DIY shop, aimed at a pencil line ten feet away, it keeps things within a thou or so.
                              For greater accuracy, you need to be consistent whether you use one side or the other, of the centre, of the pencil line. the further the line is from the machine, the more accurate you can be.
                              DON'T ever look at the laser if you value your eyesight!
                              One day I'll proof read before SEND!
                              Edited By Howard Lewis on 17/07/2020 17:23:31
                              #486309
                                Posted by not done it yet on 17/07/2020 08:38:06:
                                … It may not be smooth, but may be level and flat.
                                Sorry, ndiy …
                                I’ve been pondering that statement all day, and I still can’t get my head around it.
