A polite question – from a beginner :) Drilling a NONE wandering hole
Home › Forums › Beginners questions › A polite question – from a beginner :) Drilling a NONE wandering hole
Viewing 25 posts - 1 through 25 (of 58 total)
  • #473544
    Lainchy
      @lainchy
      Hi group!
      Seeing the note RE beginners questions… I have one that troubles me….
      When trying to drill a hole, centred in a part, I mark up, edge find in the mill, centre drill….. all good, hole STILL in the middle, but, when drilling, it wanders!
      I know there's some reasons why a drill will wander, but haven't worked it out yet.
      Any suggestions regarding going up from a centred centre drill, to a bigger hole? Is there some theory other than not trying to poke a 1/2" drill into something that doesn't want to be drilled? I have sometimes managed to get things square again, with a 12mm endmill in one instance, but say I just needed to drill a 3/32 hole, or a number 30, or an 1/8 and get it to remain on the centreline?
      Ta.
      Ian
      #10247
      Lainchy
        @lainchy
        #473545
        Gary Wooding
          @garywooding25363
          One reason why a drill will wander is if the cutting flutes asymmetric – usually because of poor sharpening. To minimise the effect it's often beneficial to first drill with a small drill that's just a little bigger than the web of the big drill, which will then be persuaded to follow the path already cut.
          #473548
          Former Member
            @formermember32069
            #473550
              Not sure about that Garry as first hole could wander and second drill follow, you may be getting mixed up with advice on getting a drill to cut to size, by doing it with two drills it does not matter if the second is asymmetric about it's point as the point is not being used.
              I'll let a few others have a stab at it.
              #473553
              Nick Clarke 3
                @nickclarke3
                Well aware of recent posts I am a beginner and have been one for a very long time.
                I am an expert in drills wandering too, but recently I have started to use a commercial spotting drill in the same way as Barrie, only 3mm in my case, and it seems to be more successful. I will keep practising.
                #473558
                Former Member
                  @formermember32069
                  #473563
                    Posted by Barrie Lever on 21/05/2020 13:54:39:
                    Posted by JasonB on 21/05/2020 13:31:30:
                    There you go again.
                    B.
                    Sorry if you have a problem Barrie, I thought that I had been posting rather a lot lately and would give others the chance to reply, as you said many answers will be forthcoming, may even offer a few more later myself.
                    #473568
                    Former Member
                      @formermember32069
                      #473579
                        I know it's warm today, but let's keep cool
                        Lainchy
                          @lainchy
                          OK, so, I'd be drilling mild steel… maybe 3/32" – 1/4" thick.
                          I have been centre drilling these with a BS1 or 2 centre drill, but I have also read that a spotting drill should be used to start, not a centre drill. Perhaps I'll get a 3mm spotting drill to try to improve, so many thanks for that. The drill's I've been using are all still factory fresh, all be them not "high quality" named brands, but not also the cheapo cheapo sets.
                          I'm also drilling with a Warco WM14 mill, which so far is proving to be great, even if not a huge throat. I do tend to try also to drill with very little of the quill out and the tables/head locked.
                          I am currently building Juliet II and my concern is mainly for when I need to drill and ream the coupling rods. The Baker valve gear is mostly made, but with some wandering on the levers, so not too critical I hope. on the whole… pretty ok, but just… OK. I really want to improve my drilling accuracy.
                          Ta
                          #473583
                          Lainchy
                            @lainchy
                            There's no secret in drilling a pilot hole smaller than the centre flat on the next drill up?
                            #473589
                            Martin Connelly
                              @martinconnelly55370
                              Ian the issue of spotting drills v centre drills has come up in the past. A lot of old books say use centre drills because spotting drills are a relatively new thing that came into use with CNC. Creating a dimple with a centre pop was no longer feasible in the middle of a machining program. They started off as an expensive option but the price has come down to the point where they are good value for home machinists. They are far stronger than centre drills, I have broken many centre drill tips. They are far stiffer than similar diameter drills as they are not fluted over a multiple of the diameter. The final thing is the angle of the hole they create. The centre drill hole is suited to lathe centres where support against side loads is important so they are steep sided. They are steeper than the angles of a standard drill so the first thing that makes contact with the workpiece is the outer part of the drill cutting edge against the sharp lip. This then digs in and the distance from the centre of rotation is enough to give leverage to push the drill off centre. Spotting drills create a shallow sided hole and the drill point makes first contact where the torque is low due to the fact it is nearer to the centre of rotation. It is also not a sharp edge against a sharp edge so does not grab as much.
                              I have some spotting drills and use them when drilling both on the mill and in the lathe tailstock. I keep my centre drills for what they were designed for which is creating a centre hole for a lathe centre to go in. I haven't broken any for a while now.
                              Martin C
                              Oops, put centre instead of spotting in the last paragraph.
                              Edited By Martin Connelly on 21/05/2020 15:08:29
                              #473591
                              Lainchy
                                @lainchy
                                Thanks Martin. I'll order one and see how I get on with it. Many thanks. Fingers crossed.
                                #473592
                                John Baron
                                  @johnbaron31275
                                  Hi Lainchy, Guys,
                                  There are a multitude of reasons why a hole doesn't get drilled where you want and expect it to be. Drilling a small pilot hole isn't always the answer. For hole starting a good centre punch helps.
                                  The most common reason for holes drifting off, particularly deep ones, is as already been mentioned is rigidity. Not necessarily in the machine, but the drill. Applying too much pressure to make the drill cut will cause it to flex. Only a few thou, but enough to cause a hole that starts off perfectly to then end up some distance from the place you expected it to come out.
                                  Just another thing, drills whether cheap or dear are not always ground well. I've spent a lot of time learning how to grind drills properly, and built machines to do it. If you have a choice of drill, choose four facet ground ones. A bit more expensive but not a lot more.
                                  #473599
                                  Lainchy
                                    @lainchy
                                    Thanks John, I'll bear this in mind also, I hadn't thought about the pressure, but will remember that.
                                    #473610
                                    John Haine
                                      @johnhaine32865
                                      The ideal drill would have a split point to start drilling accurately and be very rigid. I have a number of "Pilotpoint" drills that have an end like a slot drill (but not the sharpened flutes), with something like a small ordinary split drill point at the centre. So for example a 10 mm drill will have say a 4 mm pilot drill formed in its centre. These are excellent, they start accurately and drill to size, and being very rigid (because they're big) they don't wander. I suspect a lot of problems arise because people start with a small drill which isn't stiff enough to keep straight, and the resulting pilot hole leads all the later drills astray.
                                      #473620
                                      Former Member
                                        @formermember32069
                                        #473621
                                        roy entwistle
                                          @royentwistle24699
                                          On 21st OP posted "OK, so, I'd be drilling mild steel… maybe 3/32" – 1/4" thick."
                                          I wouldn't expect a drill to wander much through that thickness, or am I missing something smiley
                                          Roy
                                          #473625
                                          Lainchy
                                            @lainchy
                                            Perhaps it's not the right terminology Roy, but it definitely doesn't stay on centre anyway.
                                            #473634
                                              A few thoughts.
                                              You mention marking out if this is a heavy scribed line and even more so if followed up by a dot & ctr punch mark then if that is not in exactly the same place as what is likely to be a more accurately located position from edge finding and use of handwheel & dro then if there is any play in the machine it will pull the drill over as it starts and its downhill from there. Either locate the punch mark on the mill by ctr finding or what I tend to do is just use the mill to get the location from edges the DRO makes this even easier, a simple sharpie mark is enough as a double check you have the hole in the right place.
                                              As said above I just keep ctr drills for when I need the 60deg cone otherwise it's a dimple with a spot drill.
                                              Good sharp drills help a lot, as you need to replace them get good ones at least in the common sizes ideally with split or four facet ends these seem to cut easier which means you are putting less force into the quill lever that may flex the machine. I don't bother to try and sharpen small ones.
                                              On the smaller bench top machines I would tend not to drill larger than 6mm straight off anything larger use pilot first, not too small as thin drills can wander more. Again less force needed to drive a 12mm drill into say a 6mm then 9mm hole so less strain/flex on machine.
                                              In the desire to get zero tram the column base is often shimmed which can work very well however the factory may have set the machine up for good all round use, you also need to take into account if the vertical Z movement is in line with your now shimmed column or perpendicular to the table. Like wise is the quill moving perpendicular to the table too. You may need to come to a good all round compromise as if one of these two is out then the further up the head goes to accomodate a long drill the further from the spot drilled position it will be in X&Y. Same with quill the further it gets extended the more it becomes out of line.
                                              With the above in mind I'm also a fan of stub length drills, again in the common sizes and split point, they save having to risk errors by reducing head movement and they also save you having to keep cranking up the head to get long drills in.
                                              Use your ER collet holder where you can as its probably truer than the average drill chuck and shorter too.
                                              Make sure your work is tapped down flat in the vice particularly if using a drill vice as the moving jaw can lift so you are starting your drill on a slope which it will want to wander down and the hole won't be perpendicular to the surface so it may actually be straight but as it was drilled at an angle will seem wonkey
                                              #473640
                                              old mart
                                                @oldmart
                                                Any time I have to drill a perfect hole, I look for a new quality drill first. I can't sharpen a drill to anything like the precision of the makers, and my efforts are bound to wobble and drill oversize.
                                                #473643
                                                  If I wanted a perfectly ‘drilled’ hole, first thing I would consider is whether the part would fit the 4 jaw chuck.🙂 Not always appropriate, of course, but for one-off holes it can help…
                                                  #473644
                                                  Mick B1
                                                    @mickb1
                                                    Some have mentioned using light pressure to avoid wander – I'd just add this is especially important at the start, before the drill's full diameter is engaged and it's riding on its cylindrical land. If it's deflected to one side during that part of the cut, some degree of wander has become inevitable.
                                                    So give it time to be cutting as uniformly as possible all round during that period. once it's fully engaged, and especially when you've reached half-a-diameter or so depth, you can apply a bit more gentle pressure.
                                                    Edited By Mick B1 on 21/05/2020 17:08:31
                                                    #473658
                                                    Martin Kyte
                                                      @martinkyte99762
                                                      Generally for drilled holes there should not be a perticular issue but if tight tolerance is required you could:-
                                                      Create a good centre as large as reasonable. Use a small drill to extend the pilot through the work.
                                                      Either drill to size with the final sized drill or do it in the smallest number of steps. Use a quality neat cutting fluid, fit the drill into the chuck to full depth, tighten all 3 positions of a jacobs chuck.
                                                      Failing all that you are into hardened drilling buttons accurately positioned.
                                                      regards Martin
