Yet another what is it
Home › Forums › General Questions › Yet another what is it
  • #353357
    William S
      @williams
      Hello all
      The nearby car boot sale turned up a few bits for the workshop;
      img_0731.jpg A Belco 0-1/4'' drill chuck, shame about the surface staining but the moving parts had oil on them so all good
      A pair of large V block stirrups (is that the right name?) No makers name so could they be apprentice pieces? There was no sign of the V blocks so redundant I suppose, still might be useful.
      Also a Chinese 80mm self centering 4 jaw lathe chuck minus the other set of jaws, for £12 might come in useful one day, would have to come up with a backplate on the Myford but it does fit the Axminster sc2 mini lathe with minimal run-out so might remain on there just in case!
      Then there is this item, was wondering if anybody can shed a light on its use would appear to be a jig to hold something but what I am unsure;
      The pin is spring loaded
      the vertical line is a V
      And this is the clamping knob on the rear of the tool.
      It looks to be home made for quite a specific task, it came from the same box as the drill chuck and V block stirrups if that helps in anyway.
      There was also flexispeed meteor 2 lathe there in quite original condition with the vertical slide, fixed steady, 3 4 way tool posts, little drill chuck and a few other bits, didn't ask about the price but I can think it wouldn't of been cheap if they had done a bit of research! (they were also dealers)
      Then there was a G.Boley watchmakers lathe in its box and looked quite complete. However the £400 asking price is going to put quite a few people off.
      Many thanks for reading and any ideas on that unknown part would be good.
      William
      #25974
      William S
        @williams
        Mondays boot fair finds
        #353490
          Interesting one, William.
          It looks like the long bar clamps a small, cylindrical object in the vee, at a position decided by the stop and the angled (scriber?) marks or aligns with it.
          Clearly made to a high standard for a specific and presumably quite precision job.
          #353570
          John McNamara
            @johnmcnamara74883
            I think the angled sides are a clue. Maybe a jig for grinding facets on some sort of cutting tool?
            Edited By John McNamara on 11/05/2018 14:49:20
