X1 Mill speed control
Home › Forums › General Questions › X1 Mill speed control
  • #103305
    magpie
      @magpie
      Hi Folks
      I hope someone on here can help with a new fault my X1 mill has developed. I have had the mill about 8-9 years and only had one problem in all that time, which was the drive gear had the center ripped out because the key was only 3mm long ! Now when i turn on i have to turn the speed control up fully, and it then takes a second to wake up and move. The speed is also rather erratic. I have checked the motor, brushes OK, comutator looks OK, so not being very clued up on electronics i am now stumped. Could it be the pot, or is it more likley to be the board. I could just about afford a new pot, but if it's the board it will have to wait till funds permit, which could be a while as my state pension is c**p.
      Cheers Derek.
      #22313
      magpie
        @magpie
        #103307
        maurice bennie
          @mauricebennie99556
          Hi Derek .Could be the pot needs cleaning, there is a spray which I use that can be found in electronic shops, or radio repair shops .See if you can scroung a squirt from some one .
          Best of luck Maurice
          #103310
          magpie
            @magpie
            Thanks for that Maurice, i have a tin of that stuff i bought from "RS" years ago, i will give it a try.
            Cheers Derek.
            #103312
            Ketan Swali
              @ketanswali79440
              Hi Derek,
              Please checkyour 'My Messages' box. I have sent you a personal message.
              Ketan at ARC.
              Edited By Ketan Swali on 10/11/2012 17:29:26
              #354748
              Conrad Thompson
                @conradthompson83955
                Hi folks,
                I need some help.
                The speed control on my Sieg X1 mill is misbehaving. If I switch to the forward or reverse position with the potentiometer switch in the Off position, the motor idles at a low rpm, with little torque. When the pot is switched on the speed control works as normal with good torque. The power light is not working and I know this is sold as a spare so it may be faulty. Anyone experienced this type of problem? Is it the board or the pot or both? or forward / reverse switch (which is also sold as a spare)
                Any thoughts and help greatly appreciated.
                Thanks
                Conrad
