What’s this for?
What’s this for?
Home › Forums › General Questions › What’s this for?
Viewing 25 posts - 1 through 25 (of 32 total)
  • #321428
    John MC
      @johnmc39344
      Hopefully 3 images should appear with this post. Its something that I can remember seeing in my fathers toolbox 35+ years ago, its now in my workshop. It's a top hat shaped bit of metal with a rubber sucker in the middle.
      I've googled "Dagplate" and "Buck and Hickman" and when I've been able looked at their catalogues and found nothing. I've even asked B&H reps if they know what it is.
      So, its over to you to satisfy my curiosity.
      John MC
        @johnmc39344
        #321444
          I think it's for holding a glass blank during some sort of optical process like polishing. DAG might stand for 'Diamond Abrasive Grinding'
          #321456
            Except you wouldn't use diamond to polish glass.
            #321458
              @mike89748
              ….and it's clearly meant to be used as in the last picture, otherwise the Buck & Hickman plate would be upside-down.
              #321461
                Posted by Neil Wyatt on 14/10/2017 18:58:05:
                Or would you…
                #321462
                Watford
                  @watford
                  Does the rubber insert remove, and does it reveal anything interesting – like a thread?
                  What, approximately is the major diameter?
                  #321465
                  Bazyle
                    @bazyle
                    Dag is used in some circles as short for Daguerreotype the early photographic technique. It is quite possible it was a device (or part of) to hold photographic plates for polishing. As pointed out by Mike it must have been used that way up. I suggest if the rubber is slightly proud of the surface it would grip a plate placed on it while the top surface of said plate was being polished.
                    #321522
                    John MC
                      @johnmc39344
                      Sorry, should of given some indication of size. The two diameters are 100mm and 75mm, height is 30mm.
                      The small rubber sucker gives very little holding force. When "sucked" down on to my glass surface plate the device moves around quite easily but stays in contact with the plate.
                      Removing the rubber sucker reveals nothing more than a cavity to accommodate it.
                      Roger Provins 2
                        @rogerprovins2
                        There's no mention of it in the 1958 B&H catalogue.
                        #321541
                        mark smith 20
                          @marksmith20
                          Looks like something off a metallurgical sample lapping machine,you dont say the size of it??
                          #321544
                          Watford
                            @watford
                            A Google on "patent dagplate" produced a possible answer.
                            A Daguerreotype or Dag plate was a silver coated copper plate used in early photography to capture the image. The plate needed to be very flat and smooth..
                            The Dag Plate holder was used (in several forms, some of wood) to hold the plate whilst it was buffed and polished.
                            I suspect that John's Dagplate, marketed by Buck and Hickman, was such an example and is probably a very rare beast.
                            Edited By Watford on 15/10/2017 10:59:55
                            #321545
                            Watford
                              @watford
                              The daguerreotype was the first successful commercial photographic process, and was well within the timescale for Buck and Hickman to be producing such kit.
                              Daguerrotypes were current from 1839 to around 1860. B&H started around 1830.>>
                              Mike>>
                              Edited By Watford on 15/10/2017 11:17:06
                              #321548
                              Ian S C
                                @iansc
                                It says patent applied for, is it possible to search for that sort of thing on line?
                                Ian S C
                                #321549
                                Ian S C
                                  @iansc
                                  Ian S C
                                  #321558
                                  mark smith 20
                                    @marksmith20
                                    I just dont think this thing is any older than the 1960s ,1950`s possibly , so daguerreotype is doubtful.
                                    Also they didnt open any branches until 1901.
                                    Edited By mark smith 20 on 15/10/2017 11:49:10
                                    #321565
                                    John MC
                                      @johnmc39344
                                      Many thanks for the replies. I think the daguerreotype connection unlikely, the process was more or less forgotten about by the mid 19th century.
                                      The "hammerite" paint finish would probably date it to the early 1960's.
                                      Bizibilder
                                        @bizibilder
                                        Could it be the top of some kind of test tube shaker? It does look a bit too "heavy" for that but who knows? The idea of the shaker is that you put the base of the test tube in the "sucker" and an eccentric causes the whole metal lump to vibrate thus stirring the contents of the tube.
                                        #321577
                                        mark smith 20
                                          @marksmith20
                                          the patent i can find is for some sort of pressure instrument but cant see the full patent.
                                          #321580
                                            Posted by John MC on 15/10/2017 12:14:17:
                                            I thought the same
                                            #321586
                                            Rik Shaw
                                              @rikshaw
                                              Buck and Hickman very clever ladies. Also known as Bing & Grondahl in the US. Produced to save space in the shop the customer simply soaks the item in water overnight to get one of these:
                                              Honest !!!!! blush
                                              Rik
                                              #321587
                                              ega
                                                @ega
                                                Posted by Roger Provins 2 on 15/10/2017 09:24:00:
                                                Nor (according to the index) in the 1964 catalogue.
                                                #321590
                                                  May not be be popping up in catalogues because the item was usually included with a machine; it's not a hand tool.
                                                  As I said earlier, I think it supports something like an optical blank. In use, (I guess), the blank is placed on the plate and loosely held by the suction pad. Then the plate plus blank is inserted in something like a lens grinding machine and the door closed on it. After a few hour of carefully guided mechanical grinding the plate plus new lens is removed from the machine. Possibly the lens is turned over on the plate to grind the other side, or put through a sequence of machines whilst still on the same carrier. No sticky fingers allowed on the glass.
                                                  Did Buck & Hickman ever sell optical grinders, precision grinding or lapping equipment?. If so, the plates may have come with one of them, and wasn't sold as separate item.
                                                    Posted by SillyOldDuffer on 15/10/2017 15:03:57:
                                                    In use, (I guess), the blank is placed on the plate and loosely held by the suction pad. Then the plate plus blank is inserted in something like a lens grinding machine and the door closed on it. .
                                                    But surely the plate would need to be securely and accurately located, and all its potential 'locating' faces are hammerited.
                                                    Sandgrounder
                                                      @sandgrounder
                                                      Posted by ega on 15/10/2017 14:20:57:
                                                      Or the 1971-72
