Westbury/ Mason Mastiff Engine
Home Forums General Questions Westbury/ Mason Mastiff Engine
  • #26045
    Neil Bradshaw
      @neilbradshaw24930
      Nearly Completed Engine – Bearings Mystery
      #359126
      Neil Bradshaw
        @neilbradshaw24930
        Hello Everybody
        Has anybody built a Mastiff Engine but changed the bush bearings for ball bearingsI picked up an engine of ebay but the crankshaft and camshaft bearibngs have been replaced by ball bearings.
        While looking at the engine I could not find any oil ways to feed the bush bearings
        This has now caused quite a headache, It ha been modified by drilling a hole in the side of the crankcase and fitting the oil pressure release valve.
        The crankshaft has been drilled so I can feed oil through it
        My main idea is to drill the oil ways slightly offset so ass to feed the ball races on the cam shaft and the front ball races next to the flywheel, the machine a rear bearing out of phosfor bronze and drill a feed hole into that and then into
        the crankshaft
        My only other thought was to feed 2 spray heads into the top cover this would fill the crankcase with a mist and hence lubricate every thing.
        Any advice or help would be gratefully received
        I can post pics if anybody wants to see what Im working with
        Im also interested in any other mastiff mods and if any cooling system mods or fitted a radiator water pump system has anybody got a spare carb.
        Thanks Neil
        Edited By Neil Bradshaw on 23/06/2018 03:44:28
        #359160
        Ian S C
          @iansc
          There is one currently being built, and a write up on Model Engine Maker/ MSM.
          Ian S C
          #359352
          Neil Bradshaw
            @neilbradshaw24930
            Hello Ian.
            Thank you very much for pointing me in he direction of the Model Enine Maker website.
            There is so much information there what a very useful site
            Cheers
