Vertical boiler drawing/plan.
Home › Forums › Help and Assistance! (Offered or Wanted) › Vertical boiler drawing/plan.
  • #252565
    Mark P.
      @markp
      Hello all, I am trying to find a set of plans for a vertical copper boiler for my 3″ scale tractor/lorry. I have looked at the usual drawing suppliers Reeves, Blackgates etc but can’t find anything suitable. The drawings I have are for a horizontal welded steel boiler I feel that a vertical one would look a lot better, and I would be able to build it myself.
      Regards Mark P.
      #32766
      Mark P.
        @markp
        #252569
        Mark P.
          @markp
          Further to my above post I have trawled the internet until I lost the will to live and didn’t turn anything up! I know that there are plans out there but blowed if I can find one.
          Mark P.
          #252570
          Bazyle
            @bazyle
            Have you seen the Clayton lorry drawings?
            #252577
              Haining's "Countryman's Steam" has verticals for a Sentinel, Caradoc and 3" Merryweather.In steel but these couild be a basis for a copper version
              As well as the Clayton mentioned there is the 3" Atkinson from Reeves
              There is also the Reeves RV62 drawings that build into a nice 6" dia vertical copper boiler that could be adapted from static to vehicle use
              Edited By JasonB on 27/08/2016 18:30:59
              #252578
              Mark P.
                @markp
                Hello Bazyle, I did come across the Clayton drawings but I don’t need a full set just the boiler. I’m not really to fussed about a superheater as the drawings I have don’t have one.
                Mark P.
                #252589
                duncan webster 1
                  @duncanwebster1
                  Unless you're a coded welder (to te appropriate code), you might find difficulty getting insurance if you weld it yourself. Ask whoever is going to do the final inspection before you set off down that road
                  #252592
                    If you don't want to buy a whole set of drawing look through teh various ME and EMI indexs to see which issues the boilers were covered in and get the mags on e-bay or one of the second hand mag sellers
                    #252600
                    Mark P.
                      @markp
                      Jason had a look at the RV62 drawing don’t know how I missed it, but I think it may fill the bill. How much can you deviate from the origional design?
                      Duncan I don’t intend to build a welded steel boiler, hence the reason I would like a copper one.
                      Mark P.
                      #252612
                        I suppose if you don't increase pressure or any surfaces areas and don't go thinner with any of the materials you should be OK but run it past whoever will certify the boiler before cutting metal.
                        There is a very good build of the Rv62 on MEM forum with lots of photos but you will just need to join to see them as they are posted as attachments.
                        #252614
                          Also some verticals on MHS
                          #252719
                          Mark P.
                            @markp
                            Hello Jason, I have ordered John Haining’s book. As my wagon is based round his Suffolk dredging tractor it is apt.
                            Mark P.
