upgrade variable speed motor
Home › Forums › General Questions › upgrade variable speed motor
  • #591040
    Richard Callaghan 1
      @richardcallaghan1
      Hi
      I am looking to upgrade my Clarke cl430 to a variable speed motor. I have seen that the pre-wired CL750 by Newton-Tesla which includes control unit has been recommended. Looking on their website I can’t see this listed. Does anybody know of an alternative variable speed motor that would fit my lathe?
      Kind regards
      Richard
      #28632
      Richard Callaghan 1
        @richardcallaghan1
        #591042
        John Haine
          @johnhaine32865
          Not all their packages are listed. I just fitted a 550w unit to a S7, they only list half and 1 hp on the website. Give them a call to ask.
          #591044
          Richard Callaghan 1
            @richardcallaghan1
            Thanks John, I will give them a call.
            #591049
            Adrian R2
              @adrianr2
              Some people have used industrial sewing machine motors (DC, lots of torque and IIRC much cheaper than an inverter setup) – I remember reading the threads fairly recently but can't find them now
              #591059
              Richard Callaghan 1
                @richardcallaghan1
                I have been keeping my eye out for such a motor for a while as it would be much cheaper this way. Nothing has popped up that I think would be suitable.
                I had a budget in mind before purchasing this lathe and I bought it fairly cheap which leaves me with some excess cash to spend on it. I think/hope that the tesla motor may add value, not that I would ever sell it.
                #591065
                Adrian R2
                  @adrianr2
                  Found it – see page 3 of this thread:
                  https://www.model-engineer.co.uk/forums/postings.asp?th=177038&p=3
                  Edited By Adrian R2 on 22/03/2022 10:46:06
                  #591066
                  Richard Callaghan 1
                    @richardcallaghan1
                    thanks Adrian, i will have a look at this.
                    #591070
                    John Haine
                      @johnhaine32865
                      One issue with these motors is that their maximum speed is usually ~5000 rpm, at which they presumably develop maximum power. You may therefore need another reduction stage to ~1500 rpm to match the lathe design – I assume that the existing motor is probably a 4-pole single phase induction motor, as will the NT replacement be, with a max speed of ~1500 rpm or a bit less (1800 for the 3-phase motor which they run off 60Hz).
                      #611579
                      Richard Callaghan 1
                        @richardcallaghan1
                        I know it’s been a while but thanks for all the replies and advice on this. with the help of a friend, we did manage to get a variable speed motor fitted Jack 563A Industrial Sewing Machine Heavy Duty 1HP Servo Motor for Most Machines | eBay and so far, so good.
                        I now have the old motor leftover and its for sale along with the mill drill attachment which I took off when I first bought the lathe. I notice that there is no for sale section on the forum so I will probably list these on FB market place if nobody is interested on here?
                        #611582
                        Andrew Tinsley
                          @andrewtinsley63637
                          There certainly is a "for sale" section! Run down the right hand side of the forum pages and you will come to it.
                          Andrew.
                          #611620
                          Richard Callaghan 1
                            @richardcallaghan1
                            thanks Andrew,i dont know how i missed this
