Another test….
I copied the TurboCAD 2024 Deluxe drawing via a USB stick from my WIN-11 PC to my other computer, running TC 2019 Deluxe on Win-7. And perfectly happily.
It would not open: I don’t know if by Microsoft or IMSI, or both.
However, using a partial drawing already on the TC2019 library, I could produce a new 2D sketch of those cylinder covers without difficulty, even solving the aesthetic problem of making 2 unequal discs share a central stud – the mismatch loses a mere 0.03″ from one side.
Crucially, the dimensions worked as they should.
I saved the drawing, copied it back to the USB stick and opened in TC2024 for printing. Which it did – but I could not dimension the rectangle (the cylinder block outline) in TC2024: that snaps/dimensioning conflict again.
The dimensions and snaps in the 2024 edition I have, will not work together.
Those in TC 2019 on a different computer, do work.
Result shown below: ignore the coloured fragments.
So “Sit-Rep” as they used to say… whoever “they” were. Characters in Z-Cars perhaps.
One WIN-7 PC with fully working edition of TurboCAD (2019 Deluxe), but no printer.
One WIN-11 PC holding TurboCAD 2024 Deluxe, Alibre Atom, plus A4 printer.
BUT
The former cannot read the latter’s drawings but the latter can read, and print, the former’s.
The two CAD programmes’ file type menus share only one industry-common format, for 2D images only, and with no guarantee of success.
The TurboCAD 2024 dimensioning does not work.
Me able to operate:
TurboCAD sufficiently for orthographic drawings of parts and general-arrangements (assemblies) of fairly complicated machines, perhaps 3D models of simple, single parts, but not 3D assemblies. Also to print the drawings, though I find the method very confusing and difficult.
Alibre Atom just enough to model single components in 3D, derive and print their elevation drawings, though not easily; but not 3D Assemblies of more than a very few, very simple Parts*.
So at least I can get by, switching between computers and the rival CAD programmes as necessary. Despite one-way compatibility between the two TurboCAD / OS editions on separate PCs, and none between TurboCAD and Alibre even on the same PC.
*The two work in very different ways. Alibre Atom assembles copies of Parts from existing, individual files. TurboCAD necessitates creating each part on the assembly itself, though you can copy it within the same drawing. If it is possible to create separate part files other assembly drawings can share, I have not discovered how.
