Tramming – what is acceptable?
Home › Forums › Beginners questions › Tramming – what is acceptable?
  • #144115
    ChrisH
      @chrish
      Decided to check my mill this afternoon -it's a circular column Warco 'Economy' mill/drill.
      It was not too far out, measured on the table in four corners roughly approximately equal to the spacing of the four holding down bolts I got readings from 0.000 at the start reference to +0.003" max. Shims steel available is 0.001, 0.003, 0.004 and 0.006 thou.
      After a couple of hours adding and taking away shims I now have from my 0.000 start reference back left, to -0.0015 front left, -0.0015 front right to -0.001" back right. I could live with that, but feel it could be better.
      Question: What is the acceptable error on Tramming, can I expect to get it better on this sort of mill?
      Chris
      Edited By ChrisH on 16/02/2014 18:03:32
      #7042
      ChrisH
        @chrish
        #144117
        Roderick Jenkins
          @roderickjenkins93242
          Chris,
          It depends on the distance of your indicator from the spindle axis. Those distances you've quoted over a 3 inch radius would keep me happy.
          HTH
          Rod
          #144120
          ChrisH
            @chrish
            Hi Rod,
            Just been out to the shed to measure the radius, from the spindle axis to the indicator – it's a 4 inch radius, so presumable that is a good result but I can't help feeling it should be better.
            I will leave it until tomorrow and recheck, see if it holds at that.
            Chris
            #144123
            Tony Pratt 1
              @tonypratt1
              I would say that is pretty good, I have spent many happy hours 'tramming' turret mills and if I got it within a thou over 4" I would be good to go. On a knee type of mill you can have perfect squareness quill to table but still have faint steps in the work face due I believe to the table being out of square to the column movement?
              Tony
              #144124
              MICHAEL WILLIAMS
                @michaelwilliams41215
                When tramming a mill/drill it is nescessary to distinguish between the column being crooked and the spindle/quill being crooked – different things .
                Bit of a puzzle to get good test results for the two things but worth persevering .
                Regards ,
                Michael Williams .
                #144131
                ChrisH
                  @chrish
                  Oh Michael, now you have introduced a whole new bag of worms!
                  How do you determine if the column is crooked and/or the spindle/quill is crooked, and if any of them are, how do you correct other than by renewing? Other than by Tramming the column to the table that is.
                  Chris
                  #144138
                  Anonymous
                    As far as tramming is concerned, assuming that the head moves in straight line on the column, I don't think it matters if the column isn't perpendicular to the table. If the spindle is trammed to the table it stays trammed. The spindle will move in X and/or Y as Z changes, but that's a separate issue.
                    #144214
                    MICHAEL WILLIAMS
                      Hi ChrisH ,
                      Sorry if I caused you any headache .
                      Tramming is not nescessarily the best or only way to find out whether a small machine of the mill drill type is accurately aligned .
                      A functional test often gives more meaningful information . After all it’s the way the machine actually cuts that matters .
                      If you want to do some tests then these are my suggestions :
                      (1) Put the machine back into standard condition without shims .
                      (2) Mount a sizeable piece of thick Aluminium plate on table on parallels and take some trial cuts .
                      (3) Specifically :
                      A surfacing cut using a cutter smaller than the dimensions of the block so that several passes are needed to cover surface . Do one trial feeding front to back and one end to end .
                      Observe whether cut surface in each case is uniformly flat or is shows series of steps where cuts meet .
                      Further observe whether block after machining is constant for thickness or whether it tapers off in any particular direction .
                      With a bigger cutter skim sides of block all round . Observe whether edges are square to skimmed top face .
                      Bore a reasonably large hole through and see if its going through square to top surface .
                      Note and mark the orientation of block on machine .
                      (4) From above observations infer where any errors in alignment of machine are and correct if nescessary .
                      Notes :
                      If nescessary to realign colums only use shims for assesment of amount of error . Once determined scrape mountings back to get hard metal on metal bedding again . Permanent use of shims for alignment can cause all sorts of problems .
                      Personally I would not chase perfection of aligment on this type of machine .
                      If it performed reasonably well on test and did the work I want to do ok then I would use it as supplied .
                      Regards ,
                      Michael Williams .
                      Edited By MICHAEL WILLIAMS on 17/02/2014 13:51:07
