In a former post, i showed a problem with a cylinder for a Stuart Victoria that i bored out of true. I was able to correct this by over boring but the bore is now 1.1" instead of 1" and the remaining 'meat' on the cylinder walls is also about 100 thou which i think should be ok.
Now – i happened to purchase another Victoria single and will therefore make the two singles into a twin engine.
Question is – should i bore the second cylinder to drawing at 1" or should i deliberately overbore this also to 1.1" to match the other side? Does it matter if there is a difference from one side to the other on this size of engine?
Another option is i could try sleeving the first cylinder and then re-boring to the correct size. If i did this, what material should i use as a sleeve as i don't want different expansion rates cracking the cylinder.
Thanks
Matt
