Thread change gears
Thread change gears
Home › Forums › Manual machine tools › Thread change gears
  • #99652
    Terryd
      @terryd72465
      Hi All,
      I have a Warco WM280V-F metric lathe. I have not used it for cutting a thread to date but now I intend to cut an imperial thread. The change gear chart included shows the necessary gears and set up so no problem so, however on the chart it shows one of the gears as 'H' (see chart) and I am not certain as to what it refers to. I have copied the chart below in the hope that someone can enlighten me.
      Any advice appreciated
      Best Regards
      Terry
      #12005
      Terryd
        @terryd72465
        #99655
        Mark P.
          @markp
          Hi Terry I have a WM250 lathe which is similar to yours, the 'H' is for the spacing collar. You should have a couple in with the change wheels. You might find one on the lathe on the end of the leadscrew. Hope that this helps you out
          #99660
          Terryd
            @terryd72465
            Thanks for that, yes I have the two spacing collars, I can now get on and cut metal,
            Best regards
            Terry
            Edited By Terryd on 29/09/2012 16:37:39
