Thinning solder paste
Home Forums General Questions Thinning solder paste
  • #630730
    WorkshopPete
      @workshoppete
      Good Evening All
      I have 800 dummy rivets to fit into tanks of of my current loco project and simply want to paint the inside with solder paint heat up until it flashes. unfortunately the paint is too thick. The question is what can use to thin it so I can use a brush to paint it on?
      Thanks
      Workshop Pete
      #29010
      WorkshopPete
        @workshoppete
        #630734
        Frances IoM
          @francesiom58905
          the usual applicator is a small syringe to place a spot of paste(flux + powered solder) onto a board on top of which the component to be soldered is placed in industry by using a pick + place machine – the paste holds it in position while the board is brought up to the melting point of the solder – is it not possible to spot the paste and then place the dummy rivet on top – or have I misunderstood what you are trying to do
          #630736
            You could mix some bakers fluid in with it. Though the problem with thinning is you will "dilute" the solder content and may not get enough to seal the rivits.
            I would probably tin the inside in strips first and then fit the rivits before using a small artists brush to apply a bit of the paste to the back of each rivit rather than paste the whole area.
            #630738
            WorkshopPete
              @workshoppete
              The idea is to drill holes in the brass laser cut tank sides (this easy using the Model Engineers Laser drilling jigs) fit the rivets into the holes then paint the inside of the tank and protruding rivet stems with solder paint, heat and the solder melts retains the rivets as well as sealing the holes, but to do this the solder paint has to be thin enough. Jason the bakers fluid idea may work I feel a little experiment may be required!
              #630741
              Phil P
                @philp
                I seem to remember last time my solder paste had gone rock hard, I broke it up and crushed into a powder using a pestel and mortar, then added a bit of water to a small amount of it to mix it into a paste again. I have kept most of it as a powder so I can mix it as required in future.
                It seems to work just the same as it always has done using this method.
                You do need to make sure it is stored in an airtight container so it does not dry out. I use old 35mm film containers for that purpose.
                Phil
                #630742
                old mart
                  @oldmart
                  Solder paste is probably water based, but it might be worth experimenting with a little paint thinners, acetone or solvent based brake cleaner. The thinning would be temporary as the solvents evaporate.
                  #631342
                  Simon Johnson 2
                    @simonjohnson2
                    I would buy a syringe of easy silver solder paste from a jewellery supplier such as cooksongold.com. Unlike the poor service of another well known jewellery supplier criticised on here recently; their customer service and delivery times have always been spo-on when I have ordered from them.
                    Jewellery silver solder paste is much 'softer' than Fryolux type soft-solder paint and very controllable in application (its primarily used to repair very fine jewellery where there is a risk of either melting the item or there oo difficult to control 'normal' silver solder pallions
                    It can have porosity issues so whilst I wouldn't recommend it for 'structural' situations like caulking, it should be perfect for your rivets
                    #631346
                    WorkshopPete
                      @workshoppete
                      Thanks Simon
                      The problem with using silver solder is the heat required on sheet brass it nearly always distorts no mater how carful it is heated and clamped. From the above I tried water but it simply beaded on the surface of the paste but using white spirit (paint thinner) it mixed easily and on a trial piece of surplus boiler cladding flowed beautifully. Problem solved just need to drill 800 plus 3/64 holes!
                      Thankyou everyone for all your help.
