The super 7 now in pieces but a bearing and clutch question
Home Forums Manual machine tools The super 7 now in pieces but a bearing and clutch question
  • #97375
    mike mcdermid
      @mikemcdermid41977
      Ok so the super 7 now lies dismantled.
      Does anyone know the part numbers or bearing numbers for the rear angular contact bearings and where i can get some cheaper than 25 quid ea
      Secondly
      I cannot remove the clutch
      It is the old style clutch cone inside the pulley ,Will come out 90 percent of the way relatively easily then gets stuck solid right at the point where it feels like the shaft should be leaving the cone ie just enough not to come out rotating it makes no difference
      Im very surprised theres no woodfuff key in there to tie the clutch body to the shaft or should that be that there is a woodruff key and its become unseated just enough now to stop the outer clutch coming off
      any one ever had one to pieces? im now mystified and cannot find instruciones
      #11990
      mike mcdermid
        @mikemcdermid41977
        #97382
        David Clark 13
          @davidclark13
          Hi There
          Ask Ketan at Arc Euro Trade about bearings.
          regards david
          #97385
          Ady1
            @ady1
            I believe it was made in such a way that the far eastern copy people never even figured it out
            It always remained as a myford product
            #97389
            Ady1
              @ady1
              I knew I'd seen it SOMEWHERE
              Many tried…
              but all failed miserably… to copy the coutershaft clutch
              So treat it with the reverence it deserves, you are handling sacred engineering
              Users in the UK report that the lathes were accurate with one professional gunsmith, who used his for over 25 years, reporting no problems.
              Other versions were also made including a  Super 7 – with a strange mixture of ML7 and Super 7 but with a roller-bearing headstock, no clutch on the ML7-type countershaft,
              Yet another Chinese-built Myford copy but this time a curious mixture of ML7 and Super 7 with parts (resembling those) from the latter including the tailstock, a roller-bearing headstock, hinged covers over headstock and changewheels – whilst from the former the simpler form of cross and top slides was used and there was no clutch fitted to the countershaft
              • They were very capable people… but that coutershaft clutch was a bit of a bugger
              Edited By Ady1 on 30/08/2012 00:52:33
              #97394
              mike mcdermid
                @mikemcdermid41977
                Sorry ady I believe that's the new one my clutch is in the middle of the actual countershaft 4 pulley nest not the drive pulley it comes out nice and smooth tile a finger in a yoghurt but the stops dead and it feels like a solid not soft stop
                #97395
                John C
                  @johnc47954
                  I wanted to replace the angular contact bearings in my Super 7 headstock. The
                  bearings did not seem unduly worn, but as I had the headstock apart it seemed a
                  good idea. On removing the old bearings one was stamped RHP 7205 and the other
                  was R7M LJT25 The RHP bearing was missing a ball! The Myford description in
                  the manual in the files section of this site is RHP 7205. Searching under
                  angular contact bearings suggests that RHP bearings without a suffix have a 20
                  degree contact angle. I could not source any of these through a number of
                  bearing suppliers but was able to order a pair through Myford (RDG) sales. They
                  duly arrived and are marked NSK 7205 BEAT 85. The B suffix on many bearings
                  indicates a 40 degree contact angle. I asked Myford (RDG) directly if these
                  were from the Myford (Beeston) stores and the answer was yes. I also spoke to
                  NSK (UK) who took over RHP. They confirmed that the B suffix indicated a 40
                  degree contact angle, and that they had been supplying Myford with these
                  bearings since 1995.
                  The exact same bearings are available from RS components…..at a significantly
                  cheaper price!!
                  Rgds,
                  Tomfilery
                    @tomfilery
                    Mike,
                    Re the clutch – I assume you've removed the pushrod and all of the operating lever parts and double checked that you have removed all of the grub screws (some of which fit into machined flats on the shaft).
                    I had some difficulty with mine when I took it apart and the shaft can only go one way – i.e. I knocked mine out from the righthand side of the headstock (chuck side). Someone had previously bashed the end of the shaft with a hammer, so it took a little work with a file to remove the distortion.. Even then, I had to drift it out (and back in again after inspection/ repair) with a wooden dowel. It most definitely was not a sliding fit through the bearing in the cone pulley.
                    Hope this helps you.
                    Regards Tom
                    #97411
                    mike mcdermid
                      @mikemcdermid41977
                      John many thanks for that the moderator should make that info available somewhere? sticky
                      Tom yes theres nothing left to come out completely stripped of all the screws cone internal and external are both loose and the vee pulley is also loose up to a point sliding the shaft out toward the headstock will come out all the way nearly then seems to catch on the vee pulley and upll the lot together
                      looking down the bore the shaft is clear of all the bearings (needle rollers) and probably could do with a tap,im only hesitant because it is a nice sliding fit and im questioning wy all of a sudden with maybe 75 mm left it stops solid ,its not a banding more a positive dead stop like a slide hammer?
                      #97412
                      John C
                        @johnc47954
                        Hi Mike,
                        There is a thread on the cone clutch on the Myford lathe Yahoo group:
                        http://groups.yahoo.com/group/myfordlathes/message/5500
                        You may have to join to see it, but there is lots of info within the group which would be of use.
                        Edited By John Corden on 30/08/2012 11:55:36
                        #97416
                        mike mcdermid
                          @mikemcdermid41977
                          John absolute blinder!!!!
                          first page and i see what is stopping said shaft being removed …time for a hammer.
                          #97432
                          mike mcdermid
                            @mikemcdermid41977
                            A quick up date parts are dissasemble by carefull persuasion with the hammer it seems the ball bearing race is a slightly smaller dia than the torrington needle race …and so needs drifting out for a good 10mm
                            phew
