Tension Indicator Fastener
Home › Forums › The Tea Room › Tension Indicator Fastener
  • #35163
    Vic
      @vic
      #349293
      Vic
        @vic
        Clever:
        Thor 🇳🇴
          @thor
          Yes indeed Vic, never seen it before.
          Thor
          #349303
          Bazyle
            @bazyle
            Product has been around for a while perhaps not the video. Have you seen the priceteeth
            #349311
            not done it yet
              @notdoneityet
              $20US for a fairly standard bolt (as a pack of 10), for a fixing that comes loose is, indeed, pricey. It means that the bit of kit has likely not been designed with sufficient care to prevent it falling to pieces!
              Spigots, dowels, more fixings – and other safety clamping devices – should be incorporated to prevent fretting. A drop of loctite would be cheaper if it is simply the bolt falling out!
              It is always better to avoid trouble, than continually fix it, IMO
              #349316
                Not the same [because these were developed to indicate actual failure rather than lack of tension] but it reminded me of the 'bleeding bolt': **LINK**
                [disclosure of the ludicrously long URL omitted, for clarity]
                #349319
                Hopper
                  @hopper
                  Wonder if he got the bleeding bolt idea from telltale holes in boiler stays? Same principle, just the bolt contains its own supply of telltale liquid rather than boiler water doing the job.
                  #349323
                  richardandtracy
                    @richardandtracy
                    I investigated both with a job a few years ago, where we needed bolts to shear off at a known load. It proved to be rather difficult to make sure that they broke a reliable load (within 5%). In the end we had to get the bolts made, then reduced in diameter with a rounded slot, the diameter being read off a table dependant on the tensile strength of the batch. Makes for expensive bolts, but no commercial system we could find was reliable enough.
                    The bleeding bolts are good for fatigue, and the dot ones are tensile indicators, but a known fracture load is surprisingly difficult. Most materials have a known minimum strength, but rarely is the maximum tightly controlled.
                    Richard.
