Posted by Will D on 13/03/2019 08:41:39:
Thanks for the advice I like the idea of the easy sharpening of the eccentric engineering tool holder but I’ll probably stick to hss for now. Although will my insert tools be better to get under the skin of a casting or should I stick to my hss?
Before HSS lathe tools were made of the same sort of carbon tool steel used to make knives and razors. This type of carbon steel can be heat-hardened, sharpened, and it holds a good edge. (Unlike mild-steel which can't be heat-hardened, and won't hold an edge.) The problem with carbon-steel tools is they lose hardness rapidly if the temperature rises above about 150C, which is easily done on a lathe. The tools work well, but the operator has to work slowly, and flood cooling is essential. A great deal of time is wasted resharpening and heat-treating cutting tools.
High Speed Steels are alloys containing Chromium, Molybebdum, Cobalt, Vanadium, Tungsten. Various mixes are used to optimise HSS to a purpose, but the essential effect is to increase the temperature the tool can cut at without softening – up to 400 or 500C. This means HSS can cut metal faster and for longer than Carbon-steel. It out performs tool-steel by about 5:1, and it it rendered most lathes made before 1900 obsolete; they couldn't take the extra stress. HSS isn't harder than tool-steel, but it stays hard when it gets hot. If HSS is overheated whilst cutting when grinding, then it too loses it's hardness, and has to be resharpened. Usually this softening only happens near the cutting edge and – with care – the tool-bit can be ground back to good metal. Industry don't care much for tools that need resharpening because they slow down production which wastes a lot of money. In a home workshop, the main disadvantage of sharpening is the need to own a grinder and know how to use it. The Eccentric holder deskills grinding, and it cuts well.
Carbide is like HSS except it's harder and even more heat-resistant. A further advantage is that it can be cast into standard precision shapes, and the inserts can be changed very quickly without having to reset machines. It out-performs HSS by at least 5:1 but there are a number of new gotchas that reduce it's usefulness in a home workshop. Most serious is that carbide's high performance is good enough to change the tool geometry and the way it's used. HSS is usually sharp and it cuts like a knife. Carbide is usually blunt and it levers metal off rather than cutting it – ideally the point of the tool runs in the empty space created by the wedging action. This way of removing metal is fast and efficient but it means the machine has to have plenty of power, good rigidity, and high rpm. Running carbide too gently is likely to spoil the finish: it works best taking heavy cuts at high-speed.
Might sound as if carbide is useless on an ordinary hobby lathe – not so. The convenience of exchangeable inserts compared with grinding HSS is considerable. They come in all shapes and sizes, round, triangular, sharp, blunt, rectangular, threading etc etc. Carbide punches through hard materials like the skin on cast-iron much better than HSS. Although you may have to experiment it is possible to get a good finish at lower speeds and gentle cuts.
Experience with HSS may be an obstacle to getting the best out of carbide. For example, when HSS chatters, it makes sense to back off by reducing speed, depth of cut and feed rate. Carbide likely requires the exact opposite: more speed and deeper, faster cuts. It follows that chaps brought up on Carbide are liable to misuse HSS! Older tools (designed for HSS) tend not to do well with carbide because they are too slow.
80-90% of my lathe turning is done with carbide, and I only use HSS to make finishing cuts, either for looks, or to remove tiny amounts of metal on a precision job. Other way round on my milling machine; on that I use carbide for roughing out but most work is done with HSS. Horses for courses. I don't think it's wise to generalise about HSS vs Carbide, so much depends on the operator, his machinery, and the type of work he's doing. Nothing wrong with starting with HSS and trying carbide later, or the other way round. Quite likely you'll find as I have that both have their place.
