Supplier of 12SWG Inside diameter brass tube
Home › Forums › Materials › Supplier of 12SWG Inside diameter brass tube
  • #720332
    Mike Quinn 1
      @mikequinn1
      Hello
      i have 12SWG (2.64mm) piano wire and I need some brass tube that is a sliding fit over it.  I can only find K&S, Albion Alloys and the like that are slightly too loose of a fit.
      Any ideas of a suitable supply?
      Thanks
      #720341
      DC31k
        @dc31k
        What length do you need?
        You could try annealing the tube and rolling it between two flat plates. In principle, it should become longer and thinner.
        Think through how they draw wires. Poke in your 12SWG wire and pull the assembly through a die to squeeze it together.
        Can you find something with a smaller ID and make a spade drill or D-bit out of some spare wire?
        #720347
        Bo’sun
          @bosun58570
          Hello Mike,
          Have you tried radio controlled model suppliers/shops?
          #720362
          bernard towers
            @bernardtowers37738
            elite models advertising 12g id brass tubing, thats from a google search
            #720371
            DC31k
              @dc31k
              Would it be this one?
              https://www.elitemodelsonline.co.uk/Modeling/Building-Materials/K-and-S-Metals/Brass-Tube/87348-/12ga-ID-SWG-12in-Brass-Tube-1
              It appears to be supplied by K&S Metals, which he mentions in his original post as being too loose. So, while it is sold as 12G, it does not sound as if it is suitable for his requirements.
              Hence, if there is a different one you have found, that has 12G in its description please shout out its location as it might help.
              #720474
              Mike Quinn 1
                @mikequinn1
                Hello
                thanks for the feedback.  I’ll check out the 12SWG ID tube from JP.
                Thanks
              Home › Forums › Materials › Topics
