Sufrcae Prep of Aluminium
Home › Forums › General Questions › Sufrcae Prep of Aluminium
  • #126612
    Roger Yarwood
      @rogeryarwood66088
      Hi all, i'm looking for advice as to how to surface prep thin sheet aluminium.
      The material will be aluminium sheet between 1 & 2 mm thick, in squares up to 400mm square (approx 16&quot
      The requirement is to get the sheet material as flat as possible, and reasonably smooth, so there are no dents or blemishes. Also to provide a key for later coating, so ideally the process would leave the plate as clean as possible.
      What machinery could be used to achieve this?
      My knowledge of modern machinery is limited so any help would be much appreciated.
      Many Thanks
      Rog.
      #22760
      Roger Yarwood
        @rogeryarwood66088
        #126619
        ken king, King Design
          @kenkingkingdesign
          Hello Roger. I should say that the only way to avoid dents is to not inflict them. Once in, virtually impossible to remove. I'd suggest belt or orbital sanding to clean surfaces and remove small blemishes, flipping the material frequently to treat both sides in parallel (no pun intended). If you can find a vacuum pump and make a simple, flat, vacuum hold-down table it will be well worth doing for the convenience it brings. Suprisingly, supported thinnish MDF provides a good surface and allows sufficient airflow through its structure to act as desired without the need to drill perforations. Just mask off the area outside your job with parcel tape or similar.
          Sanding, particularly with fine grades, will harden the aluminium surfaces somewhat, which can be useful or annoying, depending upon your intentions.
          Good luck,
          Ken.
          #126621
          Roger Yarwood
            @rogeryarwood66088
            Ideally i would be looking for an automated method of achieving this. Getting someone to do it for me, rather than equipping myself – at this stage anyway.
            I would need a reasonably large quantity of plates.
            So the question should perhaps be "how would this be done in a production environment?"
            I am aware that i would need to start with essentially flat material.
            #126623
            John Stevenson 1
              @johnstevenson1
              In which case you need to talk to metal polishing companies.
              Tell them what you want and let them sort the machinery out, after all they should know their job better than you. wink
              #126627
                You may be better off buying it with a brushed or annodised surface with a plastic protective sheet on the top.
                J
                #126637
                Sub Mandrel
                  @submandrel
                  I take it you want a soft surface for your blank disks?
                  If so you will want an unanodised (soft) polished plate. You should be able to get this. Leave the plastic on until the moment you need it.
                  Roger Yarwood
                    @rogeryarwood66088
                    Can you buy pre-ground aluminium sheet that's suitable for my purpose.
                    If so who does it??
                    Thanks
                    R.
                    #126668
                    Hopper
                      @hopper
                      Why do you want it ground? Is the surface of virgin sheet aluminium not flat enough? At 1 to 2mm thick, it is going to flex all over the place anyhow. And you are going to paint it anyway, which is not going to be any flatter than unmachined sheet if paint is thicker in one place than another.
                      Tell us a bit more about the application for the these plates and someone might know just what you need.
                      #126679
                      David Jupp
                        @davidjupp51506
                        All I recall about grinding and aluminium is being told very forcefully that it should never be done – soft metal clogs the stone and can lead to it shattering. Now there may be some specialist process that avoids that – others may know?
                        Rolled aluminium will be flat to a pretty high standard. Keeping protective coating in place until late in the day will reduce chances of marking.
                        You don't mention what coating is planned – for paint an etch primer is typical on aluminium. Others have already suggested anodising, which might work well for some coatings (be aware there are several variations on anodising with differing end properties).
                        The cutting technique used may introduce variations in flatness.
                        #126689
                        Weldsol
                          @weldsol
                          Hi Roger talk to Orion alloys as they fairly near to you
                          Paul
                          #126693
                          Ian S C
                            @iansc
                            Roger, you won't improve on the plate as bought, and unless it is going to be anodised, or painted with some sort of coating, a layer of oxide will form on exposure to air. Ian S C
                            #126699
                            Ian P
                              @ianp
                              Apparently it is possible to grind aluminium. Its just one of the processes that can be used preparing ultra flat aluminium platters for computer hard disks.
                              This link briefly outlines one process of one maufacturer of HDDs, I once read a very detailed description of every stage or making a platter but I cannot find the link.
                              **LINK** (Its safe to click on)
                              One thing I have never quite understood is why two platters dont 'wring' together. The surface finish and flatness is surely equal to guage blocks? but I cannot detect any grip between any of the ones I have removed from old drives.
                              Ian P
                              Edited By Ian Phillips on 11/08/2013 11:04:31
                              #126719
                              Ian S C
                                @iansc
                                Ian, just had a try with the 4 platters I have here, I can just about detect some indication that they might wring together , and they might if they were absolutely clean, and dust free. It might be either the magnetic properties in the disc, or the teflon type lubricant layer on the surface of the disc that keeps them apart.     Ian S C
                                Edited By Ian S C on 11/08/2013 14:34:35
                                #126724
                                Speedy Builder5
                                  @speedybuilder5
                                  One of the ways we "polished" aluminium in the aircraft factory was to put the component onto a large bed , loaded water and marble chips on top of it and then the table was mechanically 'shaken'. The marble gently polished the surface to remove stress raisers etc. – The panels were about 40 ft x 5ft and saved a lot of time than some of the other processes available.
                                  #126760
                                  Douglas Johnston
                                    @douglasjohnston98463
                                    Just noticed the posting by Ken King where he mentioned using thin MDF board for making a vacuum table. How thin are we talking about here and how much grip do these tables give? Is it possible to do light milling on an aluminium sheet or would that be rather dodgy.
                                    Doug
                                    #126768
                                    jason udall
                                      @jasonudall57142
                                      As to grip of a vac table…think ..at limit of say 5psi of vacumm and 1 foot dia disc…thats 113 square inches and 565 pounds of grip…
                                      #126810
                                      Billy Mills
                                        @billymills
                                        The reason for not grinding Aluminium is that many people have been injured by trying to grind on a conventional bench grinder. The soft metal very rapidly cloggs the stone then can weld to the job so the stone can shatter and do a lot of damage to the people around the machine. The spinning stone has a lot of kinetic energy that gets released in miliseconds.
                                        Specialists know exactly how to grind Alloys but they do it under carefully controlled conditions which are not available in the home workshop.
                                        The OP is looking to produce Ali blanks for direct disc cutting – LP style. So the requirement is to have the surface locally smooth to idealy well under a tenth of a micron. Milling or turning might not quite do…!!!!
                                        Billy.
                                        #126817
                                        Sub Mandrel
                                          @submandrel
                                          Not much help here, but this is interesting info on the mastering process: **LINK**
                                          Ed Duffner
                                            @edduffner79357
                                            I'm not sure Roger mentioned what he was using the plates for ?
                                            Sheet ally is "reasonably" flat as is.
                                            • Anodizing would require a polished surface if scratches/blemishes are not to be visible. Probably the same for powder coating.
                                            • For painting I'd use a self etch primer and wet sand and polish the painted finish.
                                            • If it's for recording onto i'd be looking at chemical degreasing and sonic water cleaning before an electrolytic coating process. But I'd question the size of the plate if it's spinning. It would require some pretty fine balancing if mounted on a spindle.
                                            My first job at HP was building disk drives and all parts for the drives except the platters and circuit boards were cleaned using sonic water tanks and surfactants. The platters were bought in already plated with the magnetic coating.
                                            #126858
                                            Ian S C
                                              @iansc
                                              Turn his 16"sq into a disc, and you have the size of the old 16" recording disc that Dad was using when he was a technician with the NZ Broadcasting service in the 1940/50s after his Air Force service during WW2. These discs were coated with a layer of wax, and the recording made on that. There's one out in the workshop that Mum used as a lid on the jam pan. Ian S C
                                              #126863
                                              John McNamara
                                                @johnmcnamara74883
                                                Hi Roger
                                                It is a pity you want 2mm thick material, You can purchase aluminium sandwedge panel as used to face buildings and by sign writers, it is supplied ready coated with baked enamel and in various plain metal and anodised finishes. and colours. It is very flat and quite strong being two layers of aluminium bonded with a high density plastic core, typically 4mm thick overall although I did see a few links showing 3mm material. Maybe by asking around there are thinner materials.
                                                If you purchase it from a sign writers supply company it is reasonably priced.
                                                I have a piece on my desk waiting for an idea to use it. The OZ company who gave me the sample have a CNC router and were happy to machine it for an extra charge. I guess there are similar companies in the UK with similar facilities. CNC routing would be a good way to cut your disks. Circular shearing as done by sheet metal workers would be likely to raise a burr and distort or stretch the edge. Laser cutting (Yes cutters with more recently built machines can cut aluminium) or water jet cutting would be good alternatives.
                                                You sometimes see this material on buildings with a neat folded corner. This is done by "V" routing the back layer of aluminium and the core then folding the piece. a very neat bend is created
                                                Sheet sizes start at 1200 x 2400.
                                                Sub Mandrel
                                                  @submandrel
                                                  Roger's other thread is about feedscrews for a disk mastering machine.
                                                  Ian S C
                                                    @iansc
                                                    Don't know if there's been a change, but is aluminium not all in imperial sizes, and gauge thickness for sheet? Ian S C
